    After updating to 3.4.0beta2: faulty heater 1, -273.1C.
    Beta Firmware
    11
    121
    6.6k
      dc42 administrators @Serge
      @serge what were the values reported by M308 S1 before and after you ran the M308 S1 H999 command?
      Sergeundefined 1 Reply Last reply Reply Quote 0
      • Sergeundefined
        Serge @dc42
        @dc42 H-8 L-13
        after the calibration, H51 L-13, but i can't calibrate with M308 S1 L999
          @serge said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
          @dc42 H-8 L-13
          Thanks. Do you mean you can't calibrate because you can't easily short the pins TEMP0 together?
          • pixelpieperundefined
            pixelpieper @dc42
            @dc42 I went through your Procedure, I hope it helps:
            Send M308 S1 (assuming the tool board thermistor is Sensor 1) and record the result, in particular the H and L values.
            Sensor 1 (Hotend) type PT1000 using pin 121.temp0, reading 20.8, last error: sensor not ready, R:2200.0 L:-8 H:-12
            Send M122 B121 and record the reported VIN value
            VIN: 24.4V
            Switch the tool board firmware to 3.4beta2.
            Send M308 S1 again, check that it reports the same H and L
            Sensor 1 (Hotend) type PT1000 using pin 121.temp0, reading 6.6, last error: sensor not ready, R:2200.0 L:-8 H:-12
            Send M122 and check tna the reported VIN value is the same as before
            VIN: 24.3V
            Run the calibration procedure described at https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings on the tool board thermistor input. If it's tricky to do the short-circuit calibration test, just do the open-circuit calibration, which should be sufficient to correct the reading at room temperature.
            H: works
            L: M308 S1 L999
            Error: M308: Computed correction is not valid. Check that you have placed a jumper across the thermistor input.
            (I did jumper the input and I verified that it shorts correctly)
            Send M308 S1 again to see the new H and L values
            Sensor 1 (Hotend) type PT1000 using pin 121.temp0, reading 2000.0, last error: short-circuit in sensor, R:2200.0 L:-8 H:52
            Check whether the readings are now correct.
            NO, the temperature actually dropped by 2 degrees.
            Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
            Voron V0.250 / Duet 2 Maestro
              pixelpieper
              @dc42 one more point: I did downgrade the 1LC V1.1 back to 3.3 and repeated the calibration procedure, worked without issues.
                dc42 administrators @pixelpieper
                @pixelpieper thanks for that data. That gives me something to work on.
                CadetCundefined 1 Reply Last reply Reply Quote 0
                • CadetCundefined
                  CadetC @dc42
                  @dc42 said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
                  I don't know if more information is needed, but I would also like to confirm the temperature problem .
                  recorded temperature at room temperature - RRF3.4b2
                  recorded temperature after change to RRF3.3
                  I performed the following actions
                  1.Send M308 S1 (assuming the tool board thermistor is Sensor 1) and record the result, in particular the H and L values.
                  2.Send M122 B121 and record the reported VIN value
                  3.Switch the tool board firmware to 3.4beta2.
                  4.Send M308 S1 again, check that it reports the same H and L
                  5.Send M122 and check tna the reported VIN value is the same as before
                  6.Run the calibration procedure described at https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings on the tool board thermistor input. If it's tricky to do the short-circuit calibration test, just do the open-circuit calibration, which should be sufficient to correct the reading at room temperature.
                  7.Send M308 S1 again to see the new H and L values
                  8.Check whether the readings are now correct.
                  M308 S1
                  Sensor 1 (Hotend) type Thermistor using pin 121.temp0, reading 21.4, last error: success, T:100000.0 B:4138.0 C:0.00e+0 R:2200.0 L:-7 H:-12
                  M122 B121
                  Diagnostics for board 121:
                  Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
                  Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                  VIN: 24.9V
                  M308 S1
                  Sensor 1 (Hotend) type Thermistor using pin 121.temp0, reading 3.1, last error: sensor not ready, T:100000.0 B:4138.0 C:0.00e+0 R:2200.0 L:-7 H:-12
                  m122 b121.0
                  Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09)
                  VIN: 24.9V
                  thermistor disconnected
                  M308 S1 H999
                  Measured H correction for port "121.temp0" is 47
                  jumper across each thermistor input
                  cM308 S1 L999
                  Error: M308: Computed correction is not valid. Check that you have placed a jumper across the thermistor input.ode_text
                  M308 S1
                  Sensor 1 (Hotend) type Thermistor using pin 121.temp0, reading 21.4, last error: success, T:100000.0 B:4138.0 C:0.00e+0 R:2200.0 L:-12 H:47
                  reading at room temperature seems to be OK.
                  but how i can be sure about high temps?
                    dc42 administrators @CadetC
                    @cadetc thanks for your test results. I recommend you revert the tool board firmware to 3.3 and recalibrate, until I have identified and fixed the problem. You can continue running 3.4beta2 on the main board.
                    • CadetCundefined
                      CadetC @dc42
                      so if iI go back to 3.3 for toolboard and if in config-override.g i'll put this line then i should be OK? (original factory values before calibration done in RRF3.4b2)
                       M308 S1 L-7 H-12
                      Hot to store this back in to nonvolatile memory?
                        @cadetc said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
                        If you ran M308 S# H999 (where # is the sensor number) then it has already been stored. Similarly for M308 S# L999.
                          dc42 administrators @dc42
                          @CadetC @pixelpieper @Serge I am still trying to determine why I don't see this issue on my tool boards. Please can you each run M122 B# where # is the tool board number, and tell me what bootloader version it reports.
                          CadetCundefined pixelpieperundefined 2 Replies Last reply Reply Quote 0
                          • CadetCundefined
                            CadetC @dc42
                            M122 B121
                              @cadetc thanks, it's not the bootloader version then.
                              @CadetC @pixelpieper @Serge I have identified a possible cause of this issue. Please try the new tool board firmware at https://www.dropbox.com/sh/cq7q3g8coymo9s3/AABtPYEzV1_unETpKEMPInSia?dl=0. If with this version you find the temperature error is much reduced, then please re-run the temperature calibration and report the new H and L values. If you still get large errors with this version, then just revert the tool board firmware to 3.3.
                              pixelpieperundefined 1 Reply Last reply Reply Quote 0
                                pixelpieper @dc42
                                @dc42 I installed the firmware, I get a temperature rise from 35 to arround 65 degrees with the 3.3 H & L values. When trying to calibrate:
                                M308 S1 H999
                                Measured H correction for port "121.temp0" is 48
                                M308 S1 L999
                                CadetCundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  pixelpieper @dc42
                                  @dc42 For the bootloader version:
                                  M122 B121
                                  Never used RAM 2460, free system stack 2789 words
                                  Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
                                  Last reset 00:00:46 ago, cause: software
                                  Last software reset time unknown, reason: AssertionFailed, available RAM 3392, slot 1
                                  Software reset code 0x0120 ICSR 0x00000000 SP 0x2000415c Task Freestk 129 bad marker
                                  Stack: 00000544 00022ffc 00019b65 20003134 00016cff 20003134 000163d1 20000ed0 00000000 00000001 00008275 200071c8 200071c8 200071e0 00000000 20000f50 00011647 000223b8 00022474 00021ac8 00019b05 200071c8 200071c8 20000f50 000083ed 200071d8 000009c7
                                  Driver 0: position 0, 655.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 71, reads 23059, writes 12, timeouts 0, DMA errors 0, steps req 0 done 0
                                  Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                  Peak sync jitter -2/8, peak Rx sync delay 193, resyncs 0/0, no step interrupt scheduled
                                  VIN: 24.4V
                                  MCU temperature: min 46.9C, current 46.9C, max 47.2C
                                  Ticks since heat task active 176, ADC conversions started 46170, completed 46170, timed out 0, errs 0
                                  Last sensors broadcast 0x00000006 found 2 181 ticks ago, loop time 0
                                  CAN messages queued 590, send timeouts 0, received 436, lost 0, free buffers 37, min 37, error reg 110000
                                  dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                  Accelerometer detected: yes, status: 00
                                  I2C bus errors 0, naks 0, other errors 0
                                  • CadetCundefined
                                    CadetC @pixelpieper
                                    @pixelpieper said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
                                    I my case tool temperature reported in 3.3 =20.4C
                                    after 3.4b2-1 installed reported temperature dropped to 0.6C - and is very unstable - jumping from 0.5 to 2.5C - L &H values unchanged - same as in 3.3
                                    After calibration done in 3.4b2-1 :
                                    H- 48
                                    L- calibration -error
                                    M308 S1 L999
                                    so I reverted back to 3.3 and "old" L&H values
                                      M308 S1 H999
                                      M308 S1 L999
                                      Thanks, still not right then. Please share your confif.g file.
                                        pixelpieper @dc42
                                        @dc42 Here you go:
                                        ;; system and network --------------------------------------
                                        M550 PMunin	; hostname
                                        M552 S1 P"M"
                                        M586 P2 S1 R23 T0 ; enable telnet
                                        M586 P1 S1 T0	  ; enable ftp
                                        ;M555 P2		  ; set Marlin output mode
                                        G21			; millimeter units
                                        G90			; absolute tool coordinates
                                        M83			; relative extruder coordinates
                                        ; constants of the device geometry
                                        global max_x = 252
                                        global max_y = 256
                                        global z_stop_x = {global.max_x-24.5}
                                        global z_stop_y = {global.max_y-3}
                                        global mag_probe_x = 51
                                        global mag_probe_y = {global.max_y}
                                        global mag_probe_z = 1.7
                                        global QGL_probe = 2 ; 1 = inductive, 2 = magnet
                                        ; speed & acceleration settings mm/min
                                        global xy_accel = 2000;
                                        global z_accel = 1000;
                                        global xy_speed = 60000;
                                        global z_speed = 6000;
                                        ;; enable paneldue
                                        ;M575 P1 B57600 S1
                                        ; Mini 12864
                                        M918 P2 E-4 R3 C100       ; Enable FYSetc Mini 12864
                                        M150 X2 R255 U255 B255 S3 ; FYSETC Neopixel background: set all 3 LEDs to white
                                        ;M950 P0 C"io3.out" Q500  ; generate PWM pin (red on mini12864 V1.2)
                                        ;M42 P0 S0 ; turn off
                                        ;; geometry ------------------------------------------------
                                        M667 S1                 ; corexy mode
                                        M208 X0 Y0 Z-3 S1	; S1 = set axes minima
                                        M208 X{global.max_x} Y{global.max_y} Z235 S0  ; S0 = set axes maxima
                                        M557 X20:240 Y25:235 S20    ; configure z probing grid for mesh compensation
                                        ;M98 P"/macros/zprobe/use_mfast.g"
                                        ;M98 P"/macros/zprobe/use_ifast.g"
                                        ; mechanical switch
                                        M558 K0 P5 C"io4.in" I0 H0 R0.1 F1200 T99999 A1 B1
                                        G31 K0 X0 Y0
                                        ; inductive probe
                                        M558 K1 P8 C"121.io2.in" I1 A3 H12 R0.1 F800 T99999 A1 B1
                                        G31 P1000 K1 X0 Y25 Z0.318
                                        ; magprobe
                                        M558 K2 P8 C"121.IO1.in" F150 T1000 H2
                                        G31 P1000 K2 X-2.5 Y38.5 Z7
                                        ;; drive ---------------------------------------------------
                                        ;; Motor layout:
                                        ;;  E0 E1
                                        ;;  YB XA
                                        ;;  Z2 Z3
                                        ;;  Z0 Z1
                                        M584 X2 Y1 Z5:4:3:6 E121.0				; motor bindings
                                        ;;M574 X2 Y2 Z0 S1        			; endstops
                                        M574 X2 S1 P"!io6.in"   ; X min active low endstop switch
                                        M574 Y2 S1 P"!io5.in"   ; Y min active low endstop switch
                                        ;M574 Z1 S1 P"io4.in"   ; Z min active high endstop switch
                                        M671 X-65:-65:315:315 Y-10:325:325:-10 S20	; Z leadscrews positions
                                        M569 P0 S1      ; E0 motor direction
                                        M569 P1 S0      ; Y motor direction
                                        M569 P2 S1      ; X motor direction
                                        M569 P5 S0      ; ZFL motor direction
                                        M569 P4 S1      ; ZBL motor direction
                                        M569 P3 S0      ; ZBR motor direction
                                        M569 P6 S1      ; ZFR motor direction
                                        M84 S3600                           ; motor idle timeout
                                        M906 I50                            ; motor idle current percentage
                                        M350 X16 Y16 Z16 E16 I1             ; set microstepping
                                        M92 X80 Y80 Z400 E655             	; set microsteps per mm
                                        ;; velocity, acceleration, and current settings are in these macros
                                        M98 P"/macros/drive/xy_fullcurrent.g"
                                        M98 P"/macros/drive/z_fullcurrent.g"
                                        M98 P"/macros/drive/e_fullcurrent.g"
                                        ;; firmware retraction -------------------------------------
                                        ;; Choose one as your default:
                                        ;M98 P"/macros/retraction/quiet_nozhop.g
                                        ;M98 P"/macros/retraction/quiet_zhop.g
                                        M98 P"/macros/retraction/pa_nozhop.g"
                                        ;M98 P"/macros/retraction/pa_zhop.g"
                                        ;; thermal -------------------------------------------------
                                        ; Sensors --------------------------------------------------
                                        M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bedmat"; configure sensor 0 as thermistor on pin temp0
                                        M308 S1 P"121.temp0" Y"pt1000" A"Hotend"  ; configure sensor 1 as thermistor
                                        ;M308 S1 P"e0temp" Y"thermistor" T100000 B3950 A"Hotend"
                                        M308 S2 P"121.temp1" Y"thermistor" T100000 B3950 A"Chamber"	;Chamber fan
                                        M308 S3 Y"mcu-temp" A"Board"
                                        ;M308 S4 P"e1temp" Y"thermistor" T100000 B3950 A"Bedplate"
                                        ; Heaters --------------------------------------------------
                                        ;Bed
                                        M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 4
                                        M950 H1 C"121.out0" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                                        M140 H0
                                        ;PID Settings
                                        M307 H0 A301.0 C845.3 D1.4 S1.00 V23.6 B0
                                        M307 H1 A482.6 C291.7 D5.5 S1.00 V23.6 B0 ;V6
                                        ; Monitors & Limits
                                        ;M143 H0 P1 T0 A2 S130 C0                     ; Regulate (A2) bed heater (H0) to have pad sensor (T0) below 110°C. Use Heater monitor 1 for it
                                        ;M143 H0 P2 T0 A0 S135 C0                     ; Fault (A0) bed heater (H0) if pad sensor (T0) exceeds 135°C. Use Heater monitor 2 for it
                                        M143 H0 P0 S120                            ; Set bed heater max temperature to 120°C, use implict monitor 0 which is implicitly configured for heater fault
                                        M143 H1 S400                                  ; set temperature limit for heater 1 to 275C
                                        M912 P0 S-8 ;MCU tempurature sensor correction
                                        ;; fans -------------------------------------------------
                                        ;Parts
                                        M950 F0 C"121.out2" Q500
                                        M106 P0 S0 B0.1 L128 C"Part"               ; part fan
                                        ;Hot End
                                        M950 F1 C"121.out1" Q500
                                        M106 P1 T60 H1 C"Hotend" ; hotend fan PWMED DOWN
                                        ;Board cooling
                                        M950 F2 C"out3" Q500
                                        M106 P2 S0.5 C"Board"; On when MCU temp (H3) reaches 45C
                                        ;H2 L180 X255 T30:50
                                        ;M106 P2 S255 C"Board"
                                        M950 F3 C"out4" Q500
                                        M106 P3 S0 C"Exhaust"
                                        ;; tools ---------------------------------------------------
                                        M563 P0 D0 H1       ; bind tool 0 to drive and heater
                                        G10 P0 X0 Y0 Z0     ; tool offset
                                        G10 P0 S0 R0        ; tool active and standby temp
                                        T0                  ; activate tool 0
                                        ;; Accelerometer
                                        M955 P121.0 I05
                                        ;; filament sensor ---------------------------------------
                                        ;M591 D0 P3 C3 S0 R75:125 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 85% to 115% tolerance, 3mm detection length
                                        ;M591 P5 C"e0stop" S1 ; Laser Filament Monitor
                                        ;; Buttons on the toolboard
                                        M950 C"121.button0" J0
                                        M950 C"121.button1" J1
                                        M581 P0 T2
                                        M581 P1 T3
                                          @pixelpieper thanks.
                                          I've run your configuration on my bench system and I still don't get a significant error in the temperature reading. A 1K resistor (simulating a PT1000 sensor) gives me a reading of -1.4C which is close enough to 0C. I re-ran calibration and ended up with H-7 L-13 which are within the normal range. So the issue doesn't appear to be configuration-dependent.
                                          Please run the following two commands on your system, with firmware 3.4.0beta2 installed on the tool board, and report the responses:
                                          m122 b121 p1007 a{0x806020}
                                          m122 b121 p1007 a{0x4200442c}
                                          • CadetCundefined
                                            CadetC @dc42
                                            as my problem is very similar to pixelpieper's, here are my results
                                            Address 0x4200442c value 0x00000607
                                            Address 0x00806020 value 0x19149fbe
