    Tool board - no response
    791
      How is the PT1000 connected?
      Is it actually a PT1000?
      Photos of your toolboard wiring?
      duttiundefined 2 Replies Last reply Reply Quote 0
      • duttiundefined
        dutti @Phaedrux
        @phaedrux
        It's the original tool changer thermistor.
        Is it a pt100?
        Oh no...
        • duttiundefined
          dutti @Phaedrux
          duttiundefined 1 Reply Last reply Reply Quote 0
          • duttiundefined
            dutti @dutti
              dc42 administrators @dutti
              @barbarossa-cologne I've seen that crazy temperature value once before when a tool board was configured for a PT1000 sensor but the sensor wasn't connected.
              • duttiundefined
                dutti @dc42
                @dc42 that's what I checked another time 2 minutes ago. It's definitely connected.
                  @barbarossa-cologne have you measured its resistance, to verify that it is a PT1000, not a PT100 or a thermistor?
                  • duttiundefined
                    dutti @dc42
                    @dc42 connected a different thermistor = same problem
                    • duttiundefined
                      dutti @dc42
                      Yes. Now I connected a typical Chinese thermistor and it shows the same number for temperature:/
                        @barbarossa-cologne the config.g file you posted was for a PT1000, not a thermistor. Specifically, this line:
                        M308 S1 P"121.temp0" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin 121.temp0
                        • duttiundefined
                          dutti @dc42
                          Eeeehm ok.
                          Yes
                          That was the problem...
                          SOLVED
                          thanks a lot
