    New heated enclosure printer
    230
    23.0k
    • mrehorstdmdundefined
      mrehorstdmd @Phaedrux
      @phaedrux It's looks so obvious now. It's weird how some things just don't register. Getting old...
      • Luke'sLaboratoryundefined
        Luke'sLaboratory @coseng
        @coseng
        This is exactly what I do on my large printers - Predefine the filament length between box and head, to separate motion from filament travel. well done.
        Luke
        http://lukeslab.online
        • cosengundefined
          coseng @mrehorstdmd
          @mrehorstdmd A few years ago I had a client project that needed a swappable fiber optic switchboard and we went through several design iterations with and without feed tubes before getting one without feed tubes and with a spring loaded retract system that worked for ~1M cycles. So I've a bunch of relevant experience with the situation!
          Chris
          Cosentino Engineering
          cosengundefined 1 Reply Last reply Reply Quote 1
          • cosengundefined
            coseng @coseng
            Sorry not to update more but a bit busy on other parts of the bike project. The bellows from Centryo came in and looks nice as did some waterjet cut parts for the XYUV motor mounts.
            I'll try to get the Z axis armature fabricated this weekend, then next week my helper will start laying out the PCBs on a panel so that we can power up and test axis by axis as they are installed.
            Chris
            Tinchusundefined 1 Reply Last reply Reply Quote 1
            • cosengundefined
              coseng
              Also forgot to ask if a thermistor (leftover from hot ends when replaced by PT1000) is good for a chamber sensor. I was going to connect two in series for the reading but was unsure if the housing was too much thermal mass to make it responsive enough.
              Any suggestions on locations?
              Chris
              • cosengundefined
                coseng
                The Z axis fixture is mostly fabricated, it needs to be welded up then the linear rails shimmed into alignment.
                The steel channel will be faced to clean it up, then the short arms will serve as mounts for the Z carriage assembly.
                This will be some high temp CF sheet bonded/riveted together to provide a box-like structure that the build plate will sit on with a 3 point support system. The middle point (X0) will be a spherical bolted joint to provide a fixed point. The second support point will have a pin in a groove aligned with the fixed support to allow linear expansion but no rotation. The third point will be a plain support. This configuration should give the build plate repeatable thermal behavior.
                The two horizontal arms will fit through two slots in the insulation so the only parts in the heated chamber will be the CF assembly, which should minimize thermal growth issues.
                Next week should see this completed and the XYUV assemblies started.
                Chris
                laelundefined 1 Reply Last reply Reply Quote 0
                • laelundefined
                  lael @coseng
                  Awesome project! I'm looking forward to seeing it all come together. I am curious, why did you choose to have the Z axis rails inside the chamber rather than putting a slit into the rear wall and running the cantilevered bed supports through the wall?
                  cosengundefined 1 Reply Last reply Reply Quote 0
                  • cosengundefined
                    coseng @lael
                    @lael said in New heated enclosure printer:
                    The insulation was not shown in the image but those spars are going through slots in the insulation to keep them out of the heated chamber.
                    Chris
                    • laelundefined
                      lael @coseng
                      @coseng Can't wait to see it completed! What reference points did you use for working out how to route and design the CoreXY IDEX?
                      • cosengundefined
                        coseng @lael
                        Thanks! Me too, glad to be into the mechanics of it which means tweaking is not far away. I did a bunch of internet research and when I came across @mrehorstdmd's explanation of his Core XY layout, I didn't see any reason to reinvent the wheel so used it with minor adjustments for fitting to my enclosure.
                        Chris
                        • cosengundefined
                          coseng
                          I finished most of the fab on the XYUV axis assembly and just have top weld up some adjustable mounting brackets to weld to the top of the enclosure.
                          So far so good with the rough alignment and the X axis rail seems stiff enough on its own.
                          Its about to start getting together pretty quickly, then commissioning and setup of the Duet Hardware happens.
                          Chris
                          • cosengundefined
                            coseng
                            Some more progress on the XYUV axis assembly with bracing done and XY belts installed. I made all the long braces from steel to match expansion rates with the linear motion components. This thing will move around enough when it heats up, I'd rather not have to deal with twisting due to differential thermal expansions.
                            A little tweaking is needed to keep the belts happy but nothing major. Not sure if I will need some idler pulleys on the long runs to prevent vibrations. Now it is just sitting on top of the enclosure and points are being marked to weld in the mounting/alignment system.
                            Chris
                            • cosengundefined
                              coseng
                              I have a little paid client work coming in for the first time (yea!) in a while so printer fab is delayed a little (boo!).
                              In the meantime, I am doing a little thinking about the build surface and how removing large prints with lots of support and a raft/brim could be a bit difficult, to say the least.
                              Right now my plan for the build plate is a 5/16" thick piece of cast aluminum tooling plate with a full size Keenovo heater/silicone foam insulation stuck to the bottom and a 3 point support to the Z axis carriage.
                              I have (4) sheets of 350mm square PEI self adhesive film that was going to be used as the final build surface but I am thinking twice about that. One possibility is to put the PEI film on some thin aluminum sheet that would then be edge clamped onto the 5/16" aluminum plate. I'm trying to achieve the results like flexible steel build plates for resin printers provide.
                              Any thoughts/ recommendations?
                              Chris
                              • laelundefined
                                lael @coseng
                                @coseng A number of people are having great success with high temp garolite - NEMA G14. Good adhesion across a number of materials using PVP glue stick. It's relatively cheap for high temp work and is durable. The other option is Carbon Fibre, which visionminer popularised, just make sure the epoxy binders used are high temp rated as most CF is low temp rated epoxy. I haven't tried G14 yet, but G11 works wonders for Nylon and works well for PC. I haven't tried much ABS, but it was fine, I wouldn't say excellent. I can try some more in the near future for you if you are interested. G11 needs a surface sand with 180grit prior to use to get a dull surface, then a thin layer of PVP gluestick. G11 and G14 are both less stiff than CF plate.
                                https://www.mcmaster.com/3909N23/grade~g-14/ultra-high-temperature-impact-resistant-garolite-sheets/
                                https://www.mcmaster.com/8181K16/ - note temp rated to 190F / 90C, which is unlikely to suffice. However, is 3x the price.
                                Looking at the data, it looks like CF has 90-140,000psi flexural strength vs 45-60,000 for G14 and G11 is 42-58,000 by comparison. I would suggest 6mm / 1/4" if you go the garolite path.
                                • cosengundefined
                                  coseng @lael
                                  @lael I'm not concerned so much with getting it to stick while printing as getting it to unstick when done. Lots of people have good results with ABS using a PEI build sheet, but most of those printers have removable build plates which make removal a lot easier if it does not pop off when cooling and contracting. Due to the size, heater, etc., my build plate main structure is fixed in the machine so I have to get the print off without too much strenuous activity or make a removable secondary layer that does not inhibit heat flow.
                                  Chris
                                  • laelundefined
                                    lael @coseng
                                    @coseng yep, that's fair. I think most materials won't inhibit heat flow that much. CF and CF are insulators, but that just means they take a couple of mins to get to temp. Once they are at temp, they maintain it fine.
                                    In terms of plates, I would think removable would make life easier, regardless of what that is, unless the plate is wider than the door 🙂
                                    • cosengundefined
                                      coseng @lael
                                      Well, not really. A temperature is one thing, but in a 3D printing situation we are more concerned with heat (energy) flow, which is driven by a temperature difference and limited by thermal resistance of the materials it is being transmitted through. With a thermally isolating build plate material you would need a higher build plate temperature to be able to get the same energy transfer to the part being built.
                                      That's because they do not want to give up the energy they were just given! And that is a problem because we are only heating the build plate to get heat (energy) into the part being built.
                                      That is why I am surprised that the popular nozzle material is brass. Yes, it is easy to machine but it also a relatively poor thermal conductor and significantly limits the amount of heat that can be transferred from the heating element to the filament inside the nozzle bore, which limits the melt rate, which limits the overall print rate.
                                      Yes, I agree. The aluminum plate can't come out because the heater and its wires are glued to the bottom. That's why I was thinking a secondary thin aluminum sheet with the PEI on it could be removed and not limit heat transfer from the plate into the part.
                                      Chris
                                      • cosengundefined
                                        coseng
                                        Making some small progress on the printer in between a bit of actual paying work!
                                        For a little cross-pollination, I used my LCD resin printer with Siraya Sculpt Ultra White high temp resin to print a bracket for the printhead that holds the PCB, BL Touch, water cooling lines and filament tube anchor. It sits on top of the heated chamber, so didn't want to use a normal FDM plastic part.
                                        The resin says good to 220C. It was tested to about 130C with a 30 min soak, well higher than it should ever experience. I loaded it a bit by pushing on it while at temp in the oven, and was impressed by the part's strength. When cool, it feels just like Bakelite.
                                        I have to print another one due to forgetting a wire harness feature, so will put the old one in and test as hot as my toaster over will go to see if I can get a failure.
                                        Chris
                                        roiki11undefined 1 Reply Last reply Reply Quote 1
                                        • roiki11undefined
                                          roiki11 @coseng
                                          @coseng
                                          You might want to check the temp rating on the linear rails. Most of them are rated around 85c and the plastic parts are nylon which melts at around 120. It's possible the thermal expansion binds them beyond that.
                                          You'll also want to use grease that works at high temperatures and doesn't melt away.
                                          • cosengundefined
                                            coseng @roiki11
                                            @roiki11 said in New heated enclosure printer:
                                            I am keeping an eye out on it. The 4 Z carriages are insulated from the chamber and have a fan and cool air path. The Z leadscrew nut is all metal just in case. The dual Y rails sit a couple of inches above and to the side of the chamber and are in clear air. The X carriages are the biggest concern as they are directly above the heated chamber, but are isolated by at least the bellows. There is a fan output available on the LC1 board, so if needed ducting and active cooling for the carriages can be done.
                                            Chris
