DUET 3 mini 5+ Your Duet rejected the HTTP request
Hi Everyone !
yesterday i had the : Your Duet rejected the HTTP request: page not found Check that the SD card is mounted and has the correct files in its /www folder" Error
Just after a print when trying to upload a gcode.The duet 3 mini 5+ is fairly new.
Connected over USB here is what the board tells :
RepRapFirmware for Duet 3 Mini 5+ version 3.2.2
Warning: Cannot initialise SD card 0: Card is unusable
Ethernet is disabled.
RepRapFirmware for Duet 3 Mini 5+ is up and running.
M39
Error: M39: No SD card mounted in slot 0
ok
M21
Error: M21: Cannot initialise SD card 0: Card is unusable
ok
M21
ok
M39
okSD card is in the slot and I tried another SD card on the second M21 command = same result.
Of course I have verified if all the files are on the SD cards and yes they are.
Today, i replaced the board as i had one laying around, and i put the same SD card as when i had the problem, and it's working.
i guess there's a chance the original board has a hardware problem, but if there's anything else i can do to get it back running i would be thanksful !
@p_vnct when are where did you purchase the mini 5+?
one for @Phaedrux or @droftarts -
Purchased @ Ratrig with some Vcore 3 kits
@p_vnct
got everything in at the end of july -
Can you tell from the silk screen on the board itself what hardware version it reports?
Can you gather and share the results of sending M122 from the terminal?
It does seem like it's not reading the card slot correctly and should be replaced under warranty. Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Sorry for the inconvenience.
It is a Mini 5+ v1.0 - 202101-0598
here is the results of m122 (with an sd card in the board not connected to ethernet)
M122
RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus Ethernet (standalone mode)
Board ID: FPMG7-9096U-D65J0-40KM4-MR03Z-RXK10
Used output buffers: 1 of 40 (1 max)
Static ram: 98732
Dynamic ram: 100904 of which 612 recycled
Never used RAM 44968, free system stack 124 words
Tasks: NETWORK(ready,544) HEAT(blocked,367) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,123) MAIN(running,620) IDLE(ready,20) AIN(blocked,272)
Owned mutexes: USB(MAIN)
Last reset 00:00:41 ago, cause: power up
Last software reset at 2021-07-30 11:28, reason: User, GCodes spinning, available RAM 43684, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Cache data hit count 85187108
Slowest loop: 3.81ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 0.2MBytes/sec
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = -1 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.24ms; fastest: 0.01ms
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages queued 210, send timeouts 209, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
ok
- Ethernet -
@p_vnct said in DUET 3 mini 5+ Your Duet rejected the HTTP request:
That's not right, the speed should be much higher. Either the SD card is bad, or there is a fault in the SD card interface circuitry of the Duet. As you have already tried a different SD card, please follow the instructions given by @Phaedrux to claim a replacement under warranty.
