    TC coupler stall detection. custom.how?
    Firmware installation
    617
    • engikeneerundefined
      engikeneer @dutti
      @barbarossa-cologne it seems E3D have changed their support pages over from dozuki to zendesk
      https://e3d-online.zendesk.com/hc/en-us
      I'm sure someone here might be able to help you though 🙂
      i3 clone with a bunch of mods
      duttiundefined 1 Reply Last reply Reply Quote 0
      • duttiundefined
        dutti @engikeneer
        @engikeneer
        OK thanks a lot. I´ll try to solve as much as I can by myself.
        R.G.
        • duttiundefined
          dutti @dutti
          @barbarossa-cologne
          Would be nice if anybody can take a look over my config. Maybe it´s a small mistake of me.
          jannauundefined 1 Reply Last reply Reply Quote 0
          • jannauundefined
            jannau
            a homec.g file is needed. It contains the instructions to drive the C axis until the stepper drivers detect a stall. E3D's sys files are on github, see their homec.g file
            • duttiundefined
              dutti @jannau
              @jannau ok thanks
              I saw it´s for rrf2. Does this matters?
              • duttiundefined
                dutti @dutti
                @barbarossa-cologne Found it for rrf3 ... sry
                • jannauundefined
                  jannau @dutti
                  @barbarossa-cologne stall detection seems to be missing for the C motor, see E3D's config.g
                  • duttiundefined
                    dutti @jannau
                    @jannau
                    ok it´s done. Homing is working.
                    thanks a lot
                    R.G.
                    duttiundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • duttiundefined
                      dutti @dutti
                      @barbarossa-cologne
                      How can I add a general offset?
                      I have defined offset for my tool (between nozzle and z switch) but I have also offset between my z switch/nozzle and the endstops (50mm) (x,y).?
                      G10 P0 X30 Y28.25 Z45 ; set tool 0 axis offsets without a P parameter?
                      And how can I allowed the printer to move outside of my axis limits to collect the tools?
                      Do I have to define the size of the bed seperately or do I do this with axis minimum and maximum?
                      Thanks
                      R.G.
                      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 16:15:35 GMT+0200 (Mitteleuropäische Sommerzeit)
                      G90                                                        ; send absolute coordinates...
                      M83                                                        ; ...but relative extruder moves
                      M550 P"Duet 3"                                             ; set printer name
                      M552 S1 P192.168.2.108                                     ; Wifi
                      G4 S4
                      M574 C1 S3
                      M915 P1.2 C S0 F0 R1
                      M569 P0.0 S1                                               ; physical drive 0.0 goes forwards
                      M569 P0.1 S1                                               ; physical drive 0.1 goes forwards
                      M569 P0.2 S0                                               ; physical drive 0.2 goes forwards
                      M569 P0.3 S0                                               ; physical drive 0.2 goes forwards
                      M569 P0.4 S0                                               ; physical drive 0.2 goes forwards
                      M569 P0.5 S0                                               ; physical drive 0.2 goes forwards
                      M569 P1.0 S0                                               ; physical drive 0.2 goes forwards
                      M569 P1.2 S0                                               ; physical drive 0.2 goes forwards
                      M569 P121.0 S1                                             ; physical drive 121.0 goes forwards
                      M569 P122.0 S1                                             ; physical drive 122.0 goes forwards
                      M569 P123.0 S1                                             ; physical drive 123.0 goes forwards
                      M584 X1.0 Y0.0:0.1 Z0.2:0.3:0.4:0.5 C1.2 E121.0:122.0:123.0     ; set drive mapping
                      M350 X16 Y16 Z16 E16:16:16 I1                              ; configure microstepping with interpolation
                      M92 X160.00 Y160.00 Z640.00 C91.022 E409.00:409.00:409.00          ; set steps per mm
                      M566 X900.00 Y900.00 Z60.00 C3000 E3000.00:3000.00:3000.00       ; set maximum instantaneous speed changes (mm/min)
                      M203 X12000.00 Y12000.00 Z6000.00 C5000 E6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z300.00 C400 E250.00:250.00:250.00         ; set accelerations (mm/s^2)
                      M906 X1300 Y1300 Z2500 C300 E1000:1000:1000 I30                 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                                    ; Set idle timeout
                      M208 X-10 Y-10 Z10 S1                                      ; set axis minima
                      M208 X850 Y850 Z850 S0                                  ; set axis maxima
                      M574 X2 S1 P"^io3.in"                                      ; configure active-high endstop for high end on X via pin ^io3.in
                      M574 Y2 S1 P"^io1.in"                                      ; configure active-high endstop for high end on Y via pin ^io1.in
                      M574 Z1 S1 P"^io2.in"                                      ; configure active-high endstop for low end on Z via pin ^io2.in
                      M558 P0 H-5 F300 T300                                       ; disable Z probe but set dive height, probe speed and travel speed
                      M557 X10:10 Y10:10 S20                                     ; define mesh grid
                      M308 S0 P"temp0" Y"thermistor" T100000 B4138               ; configure sensor 0 as thermistor on pin temp0
                      M950 H0 C"out0" T0                                         ; create bed heater output on out0 and map it to sensor 0
                      M307 H0 B0 R0.243 C586.2 D33.87 S1.00 V0                   ; disable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                                    ; map heated bed to heater 0
                      M143 H0 S120                                               ; set temperature limit for heater 0 to 120C
                      M308 S1 P"121.temp0" Y"thermistor" T100000 B4138           ; configure sensor 1 as PT1000 on pin 121.temp0
                      M950 H1 C"out1" T1                                         ; create nozzle heater output on out1 and map it to sensor 1
                      M307 H1 B0 S1.00                                           ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S250                                               ; set temperature limit for heater 1 to 250C
                      M308 S2 P"122.temp0" Y"pt1000" R2200                       ; configure sensor 2 as PT1000 on pin 122.temp0
                      M950 H2 C"122.out0" T2                                     ; create nozzle heater output on 122.out0 and map it to sensor 2
                      M307 H2 B0 S1.00                                           ; disable bang-bang mode for heater  and set PWM limit
                      M143 H2 S250                                               ; set temperature limit for heater 2 to 250C
                      M308 S3 P"123.temp0" Y"pt1000" R2200                       ; configure sensor 3 as PT1000 on pin 123.temp0
                      M950 H3 C"123.out0" T3                                     ; create nozzle heater output on 123.out0 and map it to sensor 3
                      M307 H3 B0 S1.00                                           ; disable bang-bang mode for heater  and set PWM limit
                      M143 H3 S250                                               ; set temperature limit for heater 3 to 250C
                      M950 F0 C"121.out1" Q500                                   ; create fan 0 on pin 121.out1 and set its frequency
                      M106 P0 S0 H-1                                             ; set fan 0 value. Thermostatic control is turned off
                      M950 F1 C"121.out2" Q500                                   ; create fan 1 on pin 121.out2 and set its frequency
                      M106 P1 S1 H1 T45                                          ; set fan 1 value. Thermostatic control is turned on
                      M950 F2 C"122.out1" Q500                                   ; create fan 2 on pin 122.out1 and set its frequency
                      M106 P2 S1 H-1                                             ; set fan 2 value. Thermostatic control is turned off
                      M950 F3 C"122.out2" Q500                                   ; create fan 3 on pin 122.out2 and set its frequency
                      M106 P3 S1 H2 T45                                          ; set fan 3 value. Thermostatic control is turned on
                      M950 F4 C"123.out1" Q500                                   ; create fan 4 on pin 123.out1 and set its frequency
                      M106 P4 S1 H-1                                             ; set fan 4 value. Thermostatic control is turned off
                      M950 F5 C"123.out2" Q500                                   ; create fan 5 on pin 123.out2 and set its frequency
                      M106 P5 S1 H3 T45                                          ; set fan 5 value. Thermostatic control is turned on
                      M950 F6 C"out4" Q500                                       ; create fan 6 on pin out4 and set its frequency
                      M106 P6 S1 H-1                                             ; set fan 6 value. Thermostatic control is turned off
                      M950 F7 C"out5" Q500                                       ; create fan 7 on pin out5 and set its frequency
                      M106 P7 S1 H T45                                           ; set fan 7 value. Thermostatic control is turned on
                      M563 P0 D0 H1 F0                                           ; define tool 0
                      G10 P0 R0 S0                                               ; set initial tool 0 active and standby temperatures to 0C
                      M563 P1 D1 H2 F2                                           ; define tool 1
                      G10 P1 X0 Y0 Z0                                            ; set tool 1 axis offsets
                      G10 P1 R0 S0                                               ; set initial tool 1 active and standby temperatures to 0C
                      M563 P2 D2 H3 F4                                           ; define tool 2
                      G10 P2 X0 Y0 Z0                                            ; set tool 2 axis offsets
                      G10 P2 R0 S0                                               ; set initial tool 2 active and standby temperatures to 0C
                      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"         ; set voltage thresholds and actions to run on power loss
                      @jannau
                      duttiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      • duttiundefined
                        dutti @dutti
                        This post is deleted!
                          dc42 administrators @dutti
                          @barbarossa-cologne, I tried to get stall detection working for the coupler motor. Unfortunately that motor gets quite hot during use, so stall detection parameters that work when the motor is cold don't work when it is hot.
                          duttiundefined 2 Replies Last reply Reply Quote 0
                          • duttiundefined
                            dutti @dc42
                            @dc42 ok but that's not a problem in my case ?
                            Should I use different ways to home coupler?
                            Thanks
                            R.G.
                            • duttiundefined
                              dutti @dc42
                              I just wanna know about the offsets x and y. Coupler is working fine. Thanks a lot
                              R.G.
                                Phaedrux Moderator @dutti
                                @barbarossa-cologne said in TC coupler stall detection. custom.how?:
                                If the print head can leave the printable area to pick up the tool you can either change the M208 limits such that the minima goes into the negative enough to allow for the full true range of motion while keeping the 0,0 point on the printable area. Or if it's on the positive side you could extend the maximum range temporarily. Or even just allow movement outside of the bounds temporarily.
                                Can you show us a diagram illustrating your offsets?
                                duttiundefined 3 Replies Last reply Reply Quote 0
                                • duttiundefined
                                  dutti @Phaedrux
                                  @phaedrux
                                  I hope that is understandable...
                                  that´s the last thing ( I hope) before start printing first time. thank you guys
                                  • duttiundefined
                                    dutti @Phaedrux
                                    @phaedrux
                                    this iy my tool offfset.
                                    tool is in front of coupler (nearer to y0). So is it rigth to have a positiv number for the offset)?
                                    Example; IN REAL. when x axis switch it at x100/y100 the nozzle is at x70/y71.75.
                                    Thank you
                                    R.G.
                                    • duttiundefined
                                      dutti @Phaedrux
                                      • duttiundefined
                                        dutti @dutti
                                        @barbarossa-cologne
                                        Problem solved!
