    duet exp3hc lost connection with main board
    392
    • danny777undefined
      danny777
      Re: Duet 3 Expansion looses connection while printing
        Please add more detail.
        • danny777undefined
          danny777
          HI,
          Thank you for your response,
          Attached my config,
          My printer is (self build)1000X1000X1000mm config.g
          I have 4 z stepper motors for Z(nema23)
          2 steppers for Y(nema 17)
          1 for X (nema 17)
          1 extruder
          As I said It worked perfect for for few days (about 5 hours consecutive evry job ) until the exp3hc lost connection with main board,
          for now I work only with main board Duet 3 mb6hc , because the exp3hc board is not connecting to main board,
          M; Configuration file for Duet 3 (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jul 27 2021 22:03:56 GMT+0300 (שעון ישראל (קיץ))
          G90                                            ; send absolute coordinates...
          M83; ...but relative extruder moves
          M575 P1 B57600 S1
          M550 P"DANNY YOSEF"                             ; set printer name
          M552 P0.0.0.0 S1                               ; enable network and acquire dynamic address via DHCP
          M586 P0 S1                                     ; enable HTTP
          M586 P1 S0                                     ; disable FTP
          M586 P2 S0                                     ; disable Telnet
          M569 P0.0 S1                                   ; physical drive 0.0 goes forwards                                  ; physical drive 0.1 goes forwards
          M569 P0.1 S0
          M569 P0.2 S1                                   ; physical drive 0.2 goes backwards
          M569 P0.3 S0
          M569 P0.4 S0
          M569 P0.5 S0
          M584 X0.0 Y0.1:2 Z0.3:4 E0.5                       ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z800.00 E461.00            ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
          M906 X800 Y1200 Z1600 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
          M84 S30; Set idle timeout
          M564 H0
          M208 X0 Y0 Z0 S1                               ; set axis minima
          M208 X900 Y900 Z900 S0                         ; set axis maxima
          M574 X1 S1 P"io3.in"                           ; configure active-high endstop for low end on X via pin io3.in
          M574 Y1 S1 P"io4.in"                           ; configure active-high endstop for low end on Y via pin io4.in
          M574 Z1 S1 P"io1.in"                           ; configure active-high endstop for low end on Z via pin io1.in
          M558 P0 H5 F120 T6000                          ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:215 Y15:195 S20                       ; define mesh grid
          M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
          M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
          M307 H0 B0 R0.162 C464.9 D14.33 S1.00 V24.0
          M140 H0                                      ; map heated bed to heater 0
          M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
          M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp0
          M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
           M307 H1 B0 R1.953 C202.4 D4.78 S1.00 V24.0
          M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S260                         ; Set temperature limit for heater 1 to 260C
          M950 F0 C"out5" Q500                         ; create fan 0 on pin out7 and set its frequency
          M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"out4" Q500                         ; create fan 1 on pin out8 and set its frequency
          M106 P0 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0                               ; define tool 0
          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
          T0
          M997 S1
            Please keep your posts together in this thread.
            Please connect the expansion board and send M122 and M122 B#, where # is the can bus address of the expansion board and copy and paste the resulting report here.
            What LEDs are lit on the expansion board?
            Can you post a photo of your wiring on the expansion board?
            M997 S1
            You probably shouldn't have this command in config.g Not sure why you would need or want to flash the wifi firmware at boot up, especially on a board that doesn't have a wifi module.
            • danny777undefined
              danny777
              Unfortunately when I connected the
              Exp3hc to the power and can, I saw Smoke from the endstop conectors area, (never used them),dont think its right to use it,
              I did conect only red and black and the can cable,
              Any idea?
                Can you post some photos of the wiring and damage?
                • danny777undefined
                  danny777
                  Attached photo,
                  The exp3hc is not conect now to main board /power
                  I used the exp3hc only for X axis and extruder '
                    Can you show a closer photo of the circled area with more light?
                    What LEDs are lit on the expansion board if any when it is connected?
                    • danny777undefined
                      danny777
                      WhatsApp Image 2021-08-18 at 22.53.39.jpeg WhatsApp Image 2021-08-18 at 22.53.50.jpeg
                        Can you describe for us how and what you had connected to the expansion board at the time it failed?
                        • danny777undefined
                          danny777
                          -power from main board (+-) as shown in the photo
                          -X stepper was conect to driver 1
                          -extruder stepper was conect to driver 2
                          -RJ11 cable was conect to can in from main board
                          nothing else was connect to that board
                          I did use for cables connectors that I got with the board
                            The connections sound pretty standard. This may be a case of premature component failure.
                            When and where did you purchase the board? It may be covered by warranty.
                            • danny777undefined
                              danny777
                              I bought it from "Rav Meimad"
                              The Israeli reseller on 22.7.21
                                Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                                • danny777undefined
                                  danny777
                                  HI,
                                  Can I we posts together in this thread?
                                    Phaedrux Moderator @danny777
                                    @danny777 Let's stick to your other thread.
