    Assistance reading diagnostics after failure- 3.3
    520
    • oozeBotundefined
      oozeBot
      We just experienced a print failure where the printer reset. I grabbed the diagnostics in hopes it contains useful information on what just happened. This is a 6HC running 3.3 stable with an attached SPC. Thanks
      RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6J1DD-3SJ6S-TB62H
      Used output buffers: 3 of 40 (40 max)
      Static ram: 150904
      Dynamic ram: 62836 of which 140 recycled
      Never used RAM 137456, free system stack 114 words
      Tasks: SBC(ready,75.9%,314) HEAT(delaying,0.9%,325) Move(notifyWait,10.5%,250) CanReceiv(notifyWait,0.8%,774) CanSender(notifyWait,0.6%,366) CanClock(delaying,0.3%,339) TMC(notifyWait,112.5%,59) MAIN(running,59.1%,922) IDLE(ready,0.0%,29), total 260.6%
      Owned mutexes: HTTP(MAIN)
      Last reset 51:53:37 ago, cause: software
      Last software reset at 2021-08-14 07:26, reason: User, none spinning, available RAM 137620, slot 2
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x04
      Aux0 errors 0,0,0
      Step timer max interval 156
      MCU temperature: min 41.0, current 47.6, max 48.0
      Supply voltage: min 2.4, current 23.5, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 0.4, current 12.1, max 12.2, under voltage events: 1
      Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/2032/1938, gc cycles 1
      Driver 0: position 42141, standstill, reads 5320, writes 68 timeouts 0, SG min/max 0/1023
      Driver 1: position 296, standstill, reads 5366, writes 22 timeouts 0, SG min/max 0/0
      Driver 2: position 7510, standstill, reads 5320, writes 68 timeouts 0, SG min/max 0/1023
      Driver 3: position 0, standstill, reads 5215, writes 173 timeouts 0, SG min/max 0/1023
      Driver 4: position 0, standstill, reads 5369, writes 22 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 5218, writes 173 timeouts 0, SG min/max 0/1023
      Date/time: 2021-08-16 11:20:14
      Slowest loop: 174.44ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 12375997ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 460228, completed moves 460228, hiccups 0, stepErrors 0, LaErrors 0, Underruns [1, 0, 75], CDDA state -1
      === AuxDDARing ===
      Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.0
      Heater 2 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 4576948, received 2249460, lost 0, longest wait 3ms for reply type 6029, peak Tx sync delay 31273, free buffers 49 (min 38), ts 934087/934073/0
      Tx timeouts 0,0,13,0,0,0 last cancelled message type 30 dest 127
      === SBC interface ===
      State: 4, failed transfers: 0, checksum errors: 0
      Last transfer: 3ms ago
      RX/TX seq numbers: 6237/3836
      SPI underruns 0, overruns 0
      Disconnects: 1, timeouts: 1, IAP RAM available 0x2c83c
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.3.0
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz
      Full transfers per second: 41.43, max wait times: 86.5ms/0.0ms
      Codes per second: 17.18
      Maximum length of RX/TX data transfers: 4200/1368
        jay_s_uk @oozeBot
        @oozebot you need to get the logs from syslog as well on the pi
        oozeBotundefined 1 Reply Last reply Reply Quote 1
        • oozeBotundefined
          oozeBot @jay_s_uk
          @jay_s_uk grabbing them now
          • oozeBotundefined
            oozeBot
            Here is the relevant section. SD Card failure?
            Aug 16 11:18:25 oozeBot kernel: [188744.509778] mmc1: Timeout waiting for hardware interrupt.
            Aug 16 11:18:25 oozeBot kernel: [188744.509850] brcmfmac: mmc_submit_one: CMD53 sg block write failed -110
            Aug 16 11:18:25 oozeBot kernel: [188744.509869] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
            Aug 16 11:18:25 oozeBot kernel: [188744.510081] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
            Aug 16 11:18:25 oozeBot kernel: [188744.511323] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
            Aug 16 11:18:25 oozeBot kernel: [188744.511338] brcmfmac: brcmf_sdio_rxfail: terminate frame
            Aug 16 11:18:25 oozeBot kernel: [188744.512497] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
            Aug 16 11:18:25 oozeBot kernel: [188744.512512] brcmfmac: brcmf_sdio_rxfail: terminate frame
            Aug 16 11:18:25 oozeBot kernel: [188744.512686] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
            Aug 16 11:18:25 oozeBot kernel: [188744.512714] brcmfmac: brcmf_sdio_rxfail: terminate frame
            Aug 16 11:18:25 oozeBot kernel: [188744.512891] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
            Aug 16 11:18:25 oozeBot kernel: [188744.512905] brcmfmac: brcmf_sdio_rxfail: terminate frame
            Aug 16 11:18:27 oozeBot DuetControlServer[1043]: [info] System time has been changed
            Aug 16 11:18:27 oozeBot kernel: [188747.069866] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
            Aug 16 11:18:27 oozeBot kernel: [188747.070224] brcmfmac: brcmf_sdio_readshared: invalid sdpcm_shared address 0x00000000
            Aug 16 11:18:27 oozeBot kernel: [188747.070241] brcmfmac: brcmf_sdio_readshared: unable to obtain sdpcm_shared info: rv=-22 (addr=0x0)
            Aug 16 11:18:27 oozeBot kernel: [188747.070268] ieee80211 phy0: brcmf_cfg80211_get_station: GET STA INFO failed, -110
            Aug 16 11:18:27 oozeBot DuetControlServer[1043]: [warn] Controller has been reset
            Aug 16 11:18:27 oozeBot DuetControlServer[1043]: [info] Aborted job file
            Aug 16 11:18:27 oozeBot DuetControlServer[1043]: [warn] Trigger: Out-of-order reply: ''
            Aug 16 11:18:31 oozeBot kernel: [188750.655249] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
            Aug 16 11:18:31 oozeBot kernel: [188750.655268] brcmfmac: brcmf_sdio_rxfail: terminate frame
            Aug 16 11:18:34 oozeBot kernel: [188753.630009] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
            Aug 16 11:18:34 oozeBot kernel: [188753.630360] brcmfmac: brcmf_sdio_readshared: invalid sdpcm_shared address 0xFFB70048
            Aug 16 11:18:34 oozeBot kernel: [188753.630377] brcmfmac: brcmf_sdio_readshared: unable to obtain sdpcm_shared info: rv=-22 (addr=0xffb70048)
            Aug 16 11:18:36 oozeBot DuetControlServer[1043]: [info] System time has been changed
            Aug 16 11:18:36 oozeBot kernel: [188756.190060] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
            Aug 16 11:18:36 oozeBot kernel: [188756.190424] brcmfmac: brcmf_sdio_readshared: invalid sdpcm_shared address 0xFFB70048
            Aug 16 11:18:36 oozeBot kernel: [188756.190441] brcmfmac: brcmf_sdio_readshared: unable to obtain sdpcm_shared info: rv=-22 (addr=0xffb70048)
            Aug 16 11:18:36 oozeBot kernel: [188756.190468] ieee80211 phy0: brcmf_cfg80211_get_station: GET STA INFO failed, -110
            Aug 16 11:18:41 oozeBot kernel: [188760.659861] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
            Aug 16 11:18:41 oozeBot kernel: [188760.659879] brcmfmac: brcmf_sdio_rxfail: terminate frame
            Aug 16 11:18:43 oozeBot kernel: [188762.760085] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
            Aug 16 11:18:43 oozeBot kernel: [188762.766964] brcmfmac: brcmf_sdiod_ramrw: membytes transfer failed
            Aug 16 11:18:43 oozeBot kernel: [188762.766974] brcmfmac: brcmf_sdio_readshared: unable to obtain sdpcm_shared info: rv=-84 (addr=0x20000010)
            Aug 16 11:18:43 oozeBot kernel: [188762.767421] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
            Aug 16 11:18:43 oozeBot kernel: [188762.767428] brcmfmac: brcmf_sdio_rxfail: terminate frame
            Aug 16 11:18:43 oozeBot kernel: [188762.775888] ieee80211 phy0: brcmf_cfg80211_get_station: GET STA INFO failed, -52
            Aug 16 11:18:43 oozeBot dhcpcd[628]: wlan0: carrier lost
            • oliofundefined
              oliof
              It's a bit confusing since brcmfmac is a wifi driver.
              oozeBotundefined 1 Reply Last reply Reply Quote 0
              • oozeBotundefined
                oozeBot @oliof
                @oliof agreed. The RPi did not reboot, we just lost connection to it through DWC for ~30 seconds. Once the connection was restored, the print was canceled. I wonder if the change in System time (line 13) had anything to do with it? That's the first thing reported by DuetControlServer.
                • oliofundefined
                  oliof
                  CMD53 is some kind of configuration command for a wifi chip; which is where some error was triggered. This seems to have blocked some subsystem for about 2 seconds, long enough for a realtime system to decide it is in an irrevocable state of de-sync.
                  Sleuthing a bit, it could be related to an unfixed issue with the wifi chip and/or driver on the Raspberry Pi which has been around since 2018 ...
                  I'd suggest moving to Ethernet if possible.
                  dc42undefined 1 Reply Last reply Reply Quote 3
                    dc42 administrators @oliof
                    @oliof I think CMD53 actually related to the SD card interface. It looks to me that there was a timeout waiting for an interrupt from the SD card subsystem.
                    • oozeBotundefined
                      oozeBot
                      @oozebot said in Assistance reading diagnostics after failure- 3.3:
                      Thank you both. Based on what we are finding, we are starting to think we overtaxed the wifi module with several webcam streams going at once.
                      • oliofundefined
                        oliof @dc42
                        @dc42 I'm confused why the wifi driver does SD card interface management, but that may be the vagaries of integrated electronics. It still seems to be resulting in a failure of the wifi interface twice (Aug 16 11:18:27 oozeBot kernel: [188747.070268] ieee80211 phy0: brcmf_cfg80211_get_station: GET STA INFO failed, -110 and again at 11:18:43).
                        • alankilianundefined
                          alankilian @oliof
                          @oliof
                          If you look at the driver, it can support WiFi hardware on PCIe or SDIO interfaces.
                          I guess this Raspberry PI has the WiFi hardware attached to an SDIO interface (which is pretty common in the embedded-world)
                          Maybe this BCM43428.
                          • oliofundefined
                            oliof
                            on the RPi 3B it seems to be BCM43438 (on RPi4 a BCM4345/6) -- and you're right, they are connected via SDIO interface. I am less confused now.
