    Single wall tower test FAILED: vertical sin wave pattern
    43
    2.2k
    • ReVeRbundefined
      ReVeRb
      the files
      resurrect.g
      homedelta.g
      config.g
      bed.g
      8/18/2021, 2:33:49 PM M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 882C
      8/18/2021, 2:33:13 PM M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet Ethernet 1.02 or later
      Board ID: 0JD0M-9P6B2-NJ4S8-6J1FJ-3SJ6L-T84LK
      Used output buffers: 3 of 24 (11 max)
      Static ram: 23460
      Dynamic ram: 68116 of which 0 recycled
      Never used RAM 20504, free system stack 200 words
      Tasks: NETWORK(ready,186) HEAT(blocked,308) MAIN(running,457) IDLE(ready,20)
      Owned mutexes:
      Last reset 00:00:37 ago, cause: power up
      Last software reset at 2021-08-18 14:21, reason: User, GCodes spinning, available RAM 20468, slot 2
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 33.2, current 36.3, max 36.6
      Supply voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 55012, standstill, SG min/max not available
      Driver 1: position 55012, standstill, SG min/max not available
      Driver 2: position 55012, standstill, SG min/max not available
      Driver 3: position 0, standstill, SG min/max not available
      Driver 4: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-08-18 14:33:12
      Cache data hit count 52825024
      Slowest loop: 10.77ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 4.9ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 9.94ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
        Can you also post your config-override.g file?
          Phaedrux Moderator @ReVeRb
          @carl said in Single wall tower test FAILED: vertical sin wave pattern:
          I notice that in the "resurrect.g" there is a file I started yesterday (my last print) that I did not finished. Normally, I pause and cancel a print, but I may have hit the "emergency stop" red button at top right corner by inadvertence.
          That file is created when a print is interrupted in case you wish to resume it later.
          ReVeRbundefined 1 Reply Last reply Reply Quote 0
            Your firmware is little out of date. To update, upload this zip file as is to the system tab in DWC.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
            That will get your firmware and DWC up to date.
              I think you may need to run a new G32 auto calibration after homing and then use M500 to save that again.
              Once I see your config-override.g file we can see how much your delta calibration command differs from what you have in config.g
              • ReVeRbundefined
                ReVeRb
                here the config override
                config-override.g
                • ReVeRbundefined
                  ReVeRb @Phaedrux
                  @phaedrux I did it plenty of time and it didn't resolve the new problem I facing now... Is it because it does not take into account the G32 or the M500 anymore for unknown reason ?
                    So others can easily see:
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:23 GMT-0400 (heure d’été de l’Est)
                    G90                                           ; send absolute coordinates...
                    M83                                           ; ...but relative extruder moves
                    M550 P"MiniKossel"                            ; set printer name
                    M665 R133.565 L288.065 B95 H292                    ; Set delta radius, diagonal rod length, printable radius and homed height
                    M666 X0 Y0 Z0 A0 B0                           ; X,Y,Z endstop adjustments and X,Y Bed tilt(% per 100mm), or let auto calibration find them
                    M540 PBE:EF:DE:AD:FE:ED                       ; set custom MAC address
                    M552 P0.0.0.0 S1                              ; enable network and acquire dynamic address via DHCP
                    M586 P0 S1                                    ; enable HTTP
                    M586 P1 S0                                    ; disable FTP
                    M586 P2 S0                                    ; disable Telnet
                    M569 P0 S0                                    ; physical drive 0 goes backwards
                    M569 P1 S0                                    ; physical drive 1 goes backwards
                    M569 P2 S0                                    ; physical drive 2 goes backwards
                    M569 P3 S0                                    ; physical drive 3 goes backwards
                    M584 X0 Y1 Z2 E3                              ; set drive mapping
                    M350 X16 Y16 Z16 E16 I1                       ; configure microstepping with interpolation
                    M92 X100.00 Y100.00 Z100.00 E358          ; set steps per mm E0386.02
                    M566 X1200.00 Y1200.00 Z1200.00 E1200.00      ; set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y18000.00 Z18000.00 E12000.00   ; set maximum speeds (mm/min)
                    M201 X2400.00 Y2400.00 Z2400.00 E2400.00      ; set accelerations (mm/s^2)
                    M906 X800 Y800 Z800 E500 I30                  ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                       ; Set idle timeout
                    M208 Z0 S1                                    ; set minimum Z
                    M574 X2 S1 P"xstop"                           ; configure active-high endstop for high end on X via pin xstop
                    M574 Y2 S1 P"ystop"                           ; configure active-high endstop for high end on Y via pin ystop
                    M574 Z2 S1 P"zstop"                           ; configure active-high endstop for high end on Z via pin zstop
                    M558 P8 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T2400                 ; disable Z probe but set dive height, probe speed and travel speed
                    G31 P100 X0 Y0 Z-0.1                          ; set Z probe trigger value, offset and trigger height
                    M557 R85 S20                                  ; define mesh grid
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                    M950 H0 C"bedheat" T0                         ; create bed heater output on bedheat and map it to sensor 0
                    M307 H0 B0 S1.00                              ; disable bang-bang mode for the bed heater and set PWM limit
                    M140 H0                                       ; map heated bed to heater 0
                    M143 H0 S120                                  ; set temperature limit for heater 0 to 120C
                    M308 S1 P"e0temp" Y"thermistor" T100000 B3950  ; configure sensor 1 as thermistor on pin e0temp
                    M950 H1 C"e0heat" T1                          ; create nozzle heater output on e0heat and map it to sensor 1
                    M307 H1 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
                    M143 H1 S280                                  ; set temperature limit for heater 1 to 280C
                    M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
                    M106 P0 S0.01 H-1                              ; set fan 0 value. Thermostatic control is turned off
                    M950 F1 C"fan1" Q500                          ; create fan 1 on pin fan1 and set its frequency
                    M106 P1 S0.5 H-1                                ; set fan 1 value. Thermostatic control is turned off
                    M563 P0 D0 H1 F0                              ; define tool 0
                    G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets
                    G10 P0 R0 S0                                  ; set initial tool 0 active and standby temperatures to 0C
                    M575 P1 S1 B57600                             ; enable support for PanelDue
                    M501
                    T0                                            ; select first tool
                    ; Scale Cartesian Axes
                    M579 X0.000 Y0.000 Z0.000
                    ;END_OF_CODE
                    ; homedelta.g
                    ; called to home all towers on a delta printer
                    G91                       ; relative positioning
                    ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
                    G1 H1 X309 Y309 Z309 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                    G1 H2 X-5 Y-5 Z-5 F1800   ; go down a few mm
                    ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
                    G1 H1 X10 Y10 Z10 F180    ; move all towers up once more (second pass)
                    G1 Z-5 F2400              ; move down a few mm so that the nozzle can be centred
                    G90                       ; absolute positioning
                    G1 X0 Y0 F2400            ; move X+Y to the centre
                    ; bed.g
                    ; called to perform automatic delta calibration via G32
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:21 GMT-0400 (heure d’été de l’Est)
                    ; Probe the bed at 6 peripheral and 3 halfway points, and perform 6-factor auto compensation
                    ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
                    G30 P0 X0 Y84.2 H0 Z-99999
                    G30 P1 X66.01 Y38.11 H0 Z-99999
                    G30 P2 X66.01 Y-38.11 H0 Z-99999
                    G30 P3 X0 Y-84.2 H0 Z-99999
                    G30 P4 X-73.61 Y-42.5 H0 Z-99999
                    G30 P5 X-73.61 Y42.5 H0 Z-99999
                    G30 P6 X0 Y41.05 H0 Z-99999
                    G30 P7 X29.84 Y-17.23 H0 Z-99999
                    G30 P8 X-36.81 Y-21.25 H0 Z-99999
                    G30 P9 X0 Y0 H0 Z-99999 S6
                    ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
                    ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
                    ; config-override.g file generated in response to M500 at 2021-08-18 13:21
                    ; Delta parameters
                    M665 L288.065:288.065:288.065 R127.891 H292.667 B85.0 X-0.006 Y0.463 Z0.000
                    M666 X0.319 Y0.127 Z-0.446 A0.00 B0.00
                    ; Heater model parameters
                    M307 H0 R0.256 C213.522:213.522 D3.59 S1.00 V12.1 B0
                    M307 H1 R3.286 C260.834:260.834 D9.98 S1.00 V12.1 B0
                    ; Workplace coordinates
                    G10 L2 P1 X0.00 Y0.00 Z0.00
                    G10 L2 P2 X0.00 Y0.00 Z0.00
                    G10 L2 P3 X0.00 Y0.00 Z0.00
                    G10 L2 P4 X0.00 Y0.00 Z0.00
                    G10 L2 P5 X0.00 Y0.00 Z0.00
                    G10 L2 P6 X0.00 Y0.00 Z0.00
                    G10 L2 P7 X0.00 Y0.00 Z0.00
                    G10 L2 P8 X0.00 Y0.00 Z0.00
                    G10 L2 P9 X0.00 Y0.00 Z0.00
                    M486 S-1
                    • ReVeRbundefined
                      ReVeRb @Phaedrux
                      @phaedrux Yes, that's what I though... So I deleted the file (where we upload our print) from the list because I believe it may be related to that. (instead of printing the new file, it try to resume an old one ?) Anyway, I deleted every upload I had, upload a new one and it behave the same.
                      I'm clueless for why it suddenly behave such way for no apparent reason.
                      I printed a lot of parts in the past without any issue. I mean, really no issue at all. I installed the duet effector 3 days ago and started to have all kind of issue (my nozzles heater stop to heat randomly, and now that).
                      I doubt they are linked, but maybe ?
                      • ReVeRbundefined
                        ReVeRb @Phaedrux
                        @phaedrux Ok, please explain me how you "published" the file in such way so everyone can see ?
                        I simply select "upload file" and it does not show like that. Which one I should select to have that ?
                          I think you should delete your current config-override.g
                          update your firmware to 3.3
                          Run G28, G32, M500
                          Then post the new config-override.g
                          You can copy and paste your heater tunings back into the new file so that you don't need to re-tune them,
                          By the way, to post code snippets on the forum you can click on the </> button on the post window. That will insert a little block with ``` above and below the word UNDEFINED. You can copy and replace the word undefined with your code.
                          • ReVeRbundefined
                            ReVeRb @Phaedrux
                            @phaedrux I followed the instruction you provided me.
                            I deleted the config-override and send G28, G32 and M500.
                            I generated a new config-override file.
                            but, I didn't had to copy/paste my Heater model parameters, they were already there in the new file with the proper parameters. is that normal ?
                            New config-override.h :
                            ; config-override.g file generated in response to M500 at 2021-08-18 16:20
                            ; Delta parameters
                            M665 L288.065:288.065:288.065 R127.923 H292.702 B85.0 X-0.103 Y0.529 Z0.000
                            M666 X0.321 Y0.093 Z-0.414 A0.00 B0.00
                            M307 H0 R0.256 C213.522:213.522 D3.59 S1.00 V12.1 B0 I0
                            M307 H1 R3.286 C260.834:260.834 D9.98 S1.00 V12.1 B0 I0
                            • ReVeRbundefined
                              ReVeRb
                              By the way, I still have all the same after HOMING. It behave the same:
                              1. move upward, activate the endstops, move downward a bit, raise again until endstops activation and stay there (endstop sactive). Tool coordinate is n/a.
                              • ReVeRbundefined
                                ReVeRb
                                M115
                                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
                                Bed.g
                                ; bed.g
                                config-eoverride.g
                                ; Delta parameters
                                config.g
                                M501
                                heightmap.csv
                                RepRapFirmware height map file v2 generated at 2021-08-17 21:08, min error -0.052, max error 0.043, mean -0.010, deviation 0.022
                                xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                                -80.00,80.10,-80.00,80.10,85.00,20.00,20.00,9,9
                                      0,      0,      0,  0.001, -0.032, -0.007,      0,      0,      0
                                      0, -0.002, -0.007, -0.031, -0.020, -0.032, -0.028,  0.012,      0
                                      0, -0.016, -0.013, -0.029, -0.037, -0.003,  0.011,  0.009,      0
                                  0.003,  0.008,  0.010, -0.024, -0.023, -0.032, -0.020, -0.020,  0.009
                                  0.002, -0.013, -0.032, -0.040, -0.023, -0.017, -0.012, -0.003,  0.043
                                  0.000, -0.018, -0.024, -0.023, -0.021, -0.021, -0.032, -0.041, -0.002
                                      0,  0.002,  0.020,  0.021,  0.011,  0.039,  0.032,  0.030,      0
                                      0,  0.013, -0.020, -0.049, -0.052, -0.029, -0.020,  0.040,      0
                                      0,      0,      0, -0.007, -0.031, -0.027,      0,      0,      0
                                homedelta.g
                                ; homedelta.g
                                pause.g
                                resume.g
                                ; resume.g
                                ; called before a print from SD card is resumed
                                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:24 GMT-0400 (heure d’été de l’Est)
                                G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
                                G1 R1 X0 Y0 ; go back to the last print move
                                M83 ; relative extruder moves
                                G1 E10 F3600 ; extrude 10mm of filament
                                ; pause.g
                                ; called when a print from SD card is paused
                                G1 E-10 F3600  ; retract 10mm of filament
                                G1 Z5 F360     ; lift Z by 5mm
                                G1 X0 Y0 F6000 ; go to X=0 Y=0
                                sleep.g
                                ; sleep.g
                                ; called when M1 (Sleep) is being processed
                                stop.g
                                ; stop.g
                                ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                                tfree0.g
                                ; tfree0.g
                                ; called when tool 0 is freed
                                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:25 GMT-0400 (heure d’été de l’Est)
                                tpost0.g
                                ; tpost0.g
                                ; called after tool 0 has been selected
                                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:26 GMT-0400 (heure d’été de l’Est)
                                ; Wait for set temperatures to be reached
                                M116 P0
                                tpre0.g
                                ; tpre0.g
                                ; called before tool 0 is selected
                                I have deleted resurrect.g file but still have it in my backup if I absolutely need to have it.
                                Here is everything I have. Anyone know why my printer has become crazy this morning ? Not enough sleep or too much sugar, maybe? lol
                                  Yes that would be expected if you had not rebooted after deleting the config-override.g. The values would have been loaded at startup and then when you did M500 they would have been saved to the new file.
                                  And what does G32 do after homing has completed?
                                  Can you test your endstops with M119? Check that they all report as you'd expect when not pressed and then again when pressed. Maybe sure they match the towers they are paired with.
                                  https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_and_endstops_individually
                                  Are you sure nothing else has changed recently?
                                    dc42 administrators @ReVeRb
                                    I suggest you remove that, or change the XYZ parameters to 1.0 each.
                                    ReVeRbundefined 1 Reply Last reply Reply Quote 2
                                    • ReVeRbundefined
                                      ReVeRb @Phaedrux
                                      @phaedrux Here, manually tested all endstops, homed, send M119 to show they are all actiavted, sent a G32, then M500.
                                      Start to read from bottom , sorry.
                                      8/18/2021, 5:27:17 PM M500
                                      8/18/2021, 5:27:11 PM G32
                                      Calibrated 6 factors using 10 points, (mean, deviation) before (-0.035, 0.020) after (-0.000, 0.016)
                                      8/18/2021, 5:26:26 PM M119
                                      Endstops - X: at max stop, Y: at max stop, Z: at max stop, Z probe: not stopped
                                      8/18/2021, 5:26:23 PM G28
                                      8/18/2021, 5:26:10 PM M119
                                      Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
                                      8/18/2021, 5:26:07 PM M119
                                      Endstops - X: not stopped, Y: at max stop, Z: not stopped, Z probe: not stopped
                                      8/18/2021, 5:26:04 PM M119
                                      Endstops - X: at max stop, Y: not stopped, Z: not stopped, Z probe: not stopped
                                      8/18/2021, 5:25:57 PM M119
                                      Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
                                      The problem persist...
                                      I updated the files:
                                      Duet2_Sdiap32_WiFiEth.bin
                                      Duet2CombinedFirmware.bin
                                      Duet2Firmware_SBC.bin
                                      DuetWebControl-SD.zip
                                      Do I should wipe out everything and start from scratch or... ?
                                      • ReVeRbundefined
                                        ReVeRb @dc42
                                        @dc42 done, I changed them to 1.0, and it solved the problem !
                                        How do I tag as "solved" ?
                                          To update you simply need to upload the entire zip file as is to the system tab. Don't extract it first.
                                            Click on the Topic Tools icon and select "ask as question". Then click on it again and select "mark as solved".
