    Single wall tower test FAILED: vertical sin wave pattern
    43
    2.1k
    • giostarkundefined
      giostark @ReVeRb
      @carl
      those calibration are pretty good. Its true that the results on a small glass come better than on bigger ones BUT those are still really good.
      So 2 cent of deviation is not a number that can produce such distortion. I have the same deviation on 30cm of glass and no distortion , and my system is not that accurate , so the geometrical problem can be excluded. In the past I had similar distortion for geometrical issue , so now for your case I wanted not exclude such waste of time from the variable. What make me think about it is the expansion and contraction of the picture you posted. The heat problems I faced till now have just torsions.
      For the side of heat... this is what is explained for the vase option...
      https://all3dp.com/2/cura-vase-mode-all-you-need-to-know/
      Like is stated maybe 40mm/s with a not proper cooling could be problematic.
      You can try to print slower and with a stronger cooling.
      Apart understand the printer the other tricky variable is understand the material we are using. 😧
      Wall Line Width:
      The width of a single wall is preset in the slicer and corresponds to the nozzle size that you’re using. For a 0.4-mm nozzle, the width of a single line is 0.4 mm. A higher line width will create a much stronger print, and a larger nozzle will produce a higher line width. But swapping out the nozzle isn’t the only way: A 0.4-mm nozzle can also print a wall thickness of up to 0.6 mm if you get the following two settings right.
      Temperature:
      Vase mode or not, getting your temperature settings dialed in will go a long way. A larger nozzle size will be pushing out much more material, so a 0.6-mm nozzle will need a slightly higher temperature than your 0.4-mm nozzle. And it’s the same story when you’re printing with a higher line width. Try increasing the temperature in steps of five degrees at a time.
      Speed:
      Vase mode needs to be slow, so that the material has time to cool before the next pass of the printhead. Plus, if the line width is higher, you need to go slower still. A 25–30-mm/s wall printing speed is a good starting point.
      mrehorstdmdundefined 1 Reply Last reply Reply Quote 1
      • mrehorstdmdundefined
        mrehorstdmd @giostark
        I would chalk this problem up to a combo of the material used, the shape of the object, and the nature of FDM printing. A straight line single wall is very easy to deflect from its position- more so than a curved wall (that one reason why your car is full of curved sheet metal instead of flat panels). The longer the straight wall, the easier it is to deflect. So easy that a little shrinkage of the plastic as it cools will cause the wall to deflect away from the target position. That means the next line will be slightly off to one side of the wall. This will start happening vey quickly as each line of plastic starts shrinking as soon as it is laid down.
        The answer? print more than a single wall as others have mentioned, or maybe try a much bigger nozzle/wider line width. You might get better results with a material that shrinks less. Like poor overhang performance, this is one of the inherent limitations of FDM printing. Fortunately, we rarely need to print large, straight, single walls.
        • ReVeRbundefined
          ReVeRb
          Ok, thank you everyone. I'll have to make more test with different speed and temperature. But this morning, when I turned ON my printer, a new inexplicable problem appear from thin air.
          When 1 start up, in DWC, I see the tool position coordinate, as usual: X0 Y0 Z292
          As soon as I HOME the printer, all the coordinate turn n/a.
          When I HOME, the effector move up until the endstop are activated, then it lower a bit, raise again until endstops activate and it stay there... it does not go down a bit as usual.
          After the HOMING, I can't move the head all around.
          Also, If I auto-calibrate, it do it perfectly... then I send M500. Still the tool position are n/a.
          if I try to launch a print, it heat the bed and nozzle sequentially, but it does not home. Instead it goes to X0 Y0 Z0 and prime the nozzle and try to extrude...
          I never had that problem before... is it related to the new duet effector or the mesh grid I now can generate since I have the duet effector ?
          Which file I should check ?
            At this point please post your config.g, bed.g, homedelta.g, and the results of M122 and M98 P"config.g"
            • ReVeRbundefined
              ReVeRb
              Ok, I've wrote down how my printer behave now... I joined the files at the end. (I don't know how to show the content of the file directly like other do).
              1. I turn ON the printer and the tool coordinate are shown (Z0 Y0 Z292)
              2. If I HOME, the printer, all the coordinate turn n/a.
              3) If I turn ON the printer and directly load a print and launch it, the tool coordinate turn n/a, the sequence of heating is normal, but it HOME 1 stime, then it go down CRAZY fast to X0 Y0 Z0 and start extruding (extruder crackling)
              I paused and still can't move the effector around
              I canceled and still the same
              I can only HOME (or maybe launch a G32, but didn't tried it).
              I notice that in the "resurrect.g" there is a file I started yesterday (my last print) that I did not finished. Normally, I pause and cancel a print, but I may have hit the "emergency stop" red button at top right corner by inadvertence.
              [4_1629312457066_bed.g](Uploading 100%) [3_1629312457066_config.g](Uploading 100%) [2_1629312457066_homedelta.g](Uploading 100%) [1_1629312457066_M98_M122](Uploading 100%) [0_1629312457066_resurrect.g](Uploading 100%)
              • ReVeRbundefined
                ReVeRb
                the files
                resurrect.g
                homedelta.g
                config.g
                bed.g
                8/18/2021, 2:33:49 PM M98 P"config.g"
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 882C
                8/18/2021, 2:33:13 PM M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet Ethernet 1.02 or later
                Board ID: 0JD0M-9P6B2-NJ4S8-6J1FJ-3SJ6L-T84LK
                Used output buffers: 3 of 24 (11 max)
                Static ram: 23460
                Dynamic ram: 68116 of which 0 recycled
                Never used RAM 20504, free system stack 200 words
                Tasks: NETWORK(ready,186) HEAT(blocked,308) MAIN(running,457) IDLE(ready,20)
                Owned mutexes:
                Last reset 00:00:37 ago, cause: power up
                Last software reset at 2021-08-18 14:21, reason: User, GCodes spinning, available RAM 20468, slot 2
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU temperature: min 33.2, current 36.3, max 36.6
                Supply voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: position 55012, standstill, SG min/max not available
                Driver 1: position 55012, standstill, SG min/max not available
                Driver 2: position 55012, standstill, SG min/max not available
                Driver 3: position 0, standstill, SG min/max not available
                Driver 4: position 0, standstill, SG min/max not available
                Driver 5: position 0
                Driver 6: position 0
                Driver 7: position 0
                Driver 8: position 0
                Driver 9: position 0
                Driver 10: position 0
                Driver 11: position 0
                Date/time: 2021-08-18 14:33:12
                Cache data hit count 52825024
                Slowest loop: 10.77ms; fastest: 0.21ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 4.9ms, write time 0.0ms, max retries 0
                === MainDDARing ===
                === AuxDDARing ===
                Heater 1 is on, I-accum = 0.0
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 9.94ms; fastest: 0.02ms
                HTTP sessions: 1 of 8
                Interface state active, link 100Mbps full duplex
                  Can you also post your config-override.g file?
                    Phaedrux Moderator @ReVeRb
                    @carl said in Single wall tower test FAILED: vertical sin wave pattern:
                    That file is created when a print is interrupted in case you wish to resume it later.
                    ReVeRbundefined 1 Reply Last reply Reply Quote 0
                      Your firmware is little out of date. To update, upload this zip file as is to the system tab in DWC.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                      That will get your firmware and DWC up to date.
                        I think you may need to run a new G32 auto calibration after homing and then use M500 to save that again.
                        Once I see your config-override.g file we can see how much your delta calibration command differs from what you have in config.g
                        • ReVeRbundefined
                          ReVeRb
                          here the config override
                          config-override.g
                          • ReVeRbundefined
                            ReVeRb @Phaedrux
                            @phaedrux I did it plenty of time and it didn't resolve the new problem I facing now... Is it because it does not take into account the G32 or the M500 anymore for unknown reason ?
                              So others can easily see:
                              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:23 GMT-0400 (heure d’été de l’Est)
                              G90                                           ; send absolute coordinates...
                              M83                                           ; ...but relative extruder moves
                              M550 P"MiniKossel"                            ; set printer name
                              M665 R133.565 L288.065 B95 H292                    ; Set delta radius, diagonal rod length, printable radius and homed height
                              M666 X0 Y0 Z0 A0 B0                           ; X,Y,Z endstop adjustments and X,Y Bed tilt(% per 100mm), or let auto calibration find them
                              M540 PBE:EF:DE:AD:FE:ED                       ; set custom MAC address
                              M552 P0.0.0.0 S1                              ; enable network and acquire dynamic address via DHCP
                              M586 P0 S1                                    ; enable HTTP
                              M586 P1 S0                                    ; disable FTP
                              M586 P2 S0                                    ; disable Telnet
                              M569 P0 S0                                    ; physical drive 0 goes backwards
                              M569 P1 S0                                    ; physical drive 1 goes backwards
                              M569 P2 S0                                    ; physical drive 2 goes backwards
                              M569 P3 S0                                    ; physical drive 3 goes backwards
                              M584 X0 Y1 Z2 E3                              ; set drive mapping
                              M350 X16 Y16 Z16 E16 I1                       ; configure microstepping with interpolation
                              M92 X100.00 Y100.00 Z100.00 E358          ; set steps per mm E0386.02
                              M566 X1200.00 Y1200.00 Z1200.00 E1200.00      ; set maximum instantaneous speed changes (mm/min)
                              M203 X18000.00 Y18000.00 Z18000.00 E12000.00   ; set maximum speeds (mm/min)
                              M201 X2400.00 Y2400.00 Z2400.00 E2400.00      ; set accelerations (mm/s^2)
                              M906 X800 Y800 Z800 E500 I30                  ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30                                       ; Set idle timeout
                              M208 Z0 S1                                    ; set minimum Z
                              M574 X2 S1 P"xstop"                           ; configure active-high endstop for high end on X via pin xstop
                              M574 Y2 S1 P"ystop"                           ; configure active-high endstop for high end on Y via pin ystop
                              M574 Z2 S1 P"zstop"                           ; configure active-high endstop for high end on Z via pin zstop
                              M558 P8 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T2400                 ; disable Z probe but set dive height, probe speed and travel speed
                              G31 P100 X0 Y0 Z-0.1                          ; set Z probe trigger value, offset and trigger height
                              M557 R85 S20                                  ; define mesh grid
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                              M950 H0 C"bedheat" T0                         ; create bed heater output on bedheat and map it to sensor 0
                              M307 H0 B0 S1.00                              ; disable bang-bang mode for the bed heater and set PWM limit
                              M140 H0                                       ; map heated bed to heater 0
                              M143 H0 S120                                  ; set temperature limit for heater 0 to 120C
                              M308 S1 P"e0temp" Y"thermistor" T100000 B3950  ; configure sensor 1 as thermistor on pin e0temp
                              M950 H1 C"e0heat" T1                          ; create nozzle heater output on e0heat and map it to sensor 1
                              M307 H1 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
                              M143 H1 S280                                  ; set temperature limit for heater 1 to 280C
                              M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
                              M106 P0 S0.01 H-1                              ; set fan 0 value. Thermostatic control is turned off
                              M950 F1 C"fan1" Q500                          ; create fan 1 on pin fan1 and set its frequency
                              M106 P1 S0.5 H-1                                ; set fan 1 value. Thermostatic control is turned off
                              M563 P0 D0 H1 F0                              ; define tool 0
                              G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets
                              G10 P0 R0 S0                                  ; set initial tool 0 active and standby temperatures to 0C
                              M575 P1 S1 B57600                             ; enable support for PanelDue
                              M501
                              T0                                            ; select first tool
                              ; Scale Cartesian Axes
                              M579 X0.000 Y0.000 Z0.000
                              ;END_OF_CODE
                              ; homedelta.g
                              ; called to home all towers on a delta printer
                              G91                       ; relative positioning
                              ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
                              G1 H1 X309 Y309 Z309 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                              G1 H2 X-5 Y-5 Z-5 F1800   ; go down a few mm
                              ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
                              G1 H1 X10 Y10 Z10 F180    ; move all towers up once more (second pass)
                              G1 Z-5 F2400              ; move down a few mm so that the nozzle can be centred
                              G90                       ; absolute positioning
                              G1 X0 Y0 F2400            ; move X+Y to the centre
                              ; bed.g
                              ; called to perform automatic delta calibration via G32
                              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:21 GMT-0400 (heure d’été de l’Est)
                              ; Probe the bed at 6 peripheral and 3 halfway points, and perform 6-factor auto compensation
                              ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
                              G30 P0 X0 Y84.2 H0 Z-99999
                              G30 P1 X66.01 Y38.11 H0 Z-99999
                              G30 P2 X66.01 Y-38.11 H0 Z-99999
                              G30 P3 X0 Y-84.2 H0 Z-99999
                              G30 P4 X-73.61 Y-42.5 H0 Z-99999
                              G30 P5 X-73.61 Y42.5 H0 Z-99999
                              G30 P6 X0 Y41.05 H0 Z-99999
                              G30 P7 X29.84 Y-17.23 H0 Z-99999
                              G30 P8 X-36.81 Y-21.25 H0 Z-99999
                              G30 P9 X0 Y0 H0 Z-99999 S6
                              ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
                              ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
                              ; config-override.g file generated in response to M500 at 2021-08-18 13:21
                              ; Delta parameters
                              M665 L288.065:288.065:288.065 R127.891 H292.667 B85.0 X-0.006 Y0.463 Z0.000
                              M666 X0.319 Y0.127 Z-0.446 A0.00 B0.00
                              ; Heater model parameters
                              M307 H0 R0.256 C213.522:213.522 D3.59 S1.00 V12.1 B0
                              M307 H1 R3.286 C260.834:260.834 D9.98 S1.00 V12.1 B0
                              ; Workplace coordinates
                              G10 L2 P1 X0.00 Y0.00 Z0.00
                              G10 L2 P2 X0.00 Y0.00 Z0.00
                              G10 L2 P3 X0.00 Y0.00 Z0.00
                              G10 L2 P4 X0.00 Y0.00 Z0.00
                              G10 L2 P5 X0.00 Y0.00 Z0.00
                              G10 L2 P6 X0.00 Y0.00 Z0.00
                              G10 L2 P7 X0.00 Y0.00 Z0.00
                              G10 L2 P8 X0.00 Y0.00 Z0.00
                              G10 L2 P9 X0.00 Y0.00 Z0.00
                              M486 S-1
                              • ReVeRbundefined
                                ReVeRb @Phaedrux
                                @phaedrux Yes, that's what I though... So I deleted the file (where we upload our print) from the list because I believe it may be related to that. (instead of printing the new file, it try to resume an old one ?) Anyway, I deleted every upload I had, upload a new one and it behave the same.
                                I'm clueless for why it suddenly behave such way for no apparent reason.
                                I printed a lot of parts in the past without any issue. I mean, really no issue at all. I installed the duet effector 3 days ago and started to have all kind of issue (my nozzles heater stop to heat randomly, and now that).
                                I doubt they are linked, but maybe ?
                                • ReVeRbundefined
                                  ReVeRb @Phaedrux
                                  @phaedrux Ok, please explain me how you "published" the file in such way so everyone can see ?
                                  I simply select "upload file" and it does not show like that. Which one I should select to have that ?
                                    I think you should delete your current config-override.g
                                    update your firmware to 3.3
                                    Run G28, G32, M500
                                    Then post the new config-override.g
                                    You can copy and paste your heater tunings back into the new file so that you don't need to re-tune them,
                                    By the way, to post code snippets on the forum you can click on the </> button on the post window. That will insert a little block with ``` above and below the word UNDEFINED. You can copy and replace the word undefined with your code.
                                    • ReVeRbundefined
                                      ReVeRb @Phaedrux
                                      @phaedrux I followed the instruction you provided me.
                                      I deleted the config-override and send G28, G32 and M500.
                                      I generated a new config-override file.
                                      but, I didn't had to copy/paste my Heater model parameters, they were already there in the new file with the proper parameters. is that normal ?
                                      New config-override.h :
                                      ; config-override.g file generated in response to M500 at 2021-08-18 16:20
                                      ; Delta parameters
                                      M665 L288.065:288.065:288.065 R127.923 H292.702 B85.0 X-0.103 Y0.529 Z0.000
                                      M666 X0.321 Y0.093 Z-0.414 A0.00 B0.00
                                      M307 H0 R0.256 C213.522:213.522 D3.59 S1.00 V12.1 B0 I0
                                      M307 H1 R3.286 C260.834:260.834 D9.98 S1.00 V12.1 B0 I0
                                      • ReVeRbundefined
                                        ReVeRb
                                        By the way, I still have all the same after HOMING. It behave the same:
                                        1. move upward, activate the endstops, move downward a bit, raise again until endstops activation and stay there (endstop sactive). Tool coordinate is n/a.
                                        • ReVeRbundefined
                                          ReVeRb
                                          M115
                                          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
                                          Bed.g
                                          ; bed.g
                                          config-eoverride.g
                                          ; Delta parameters
                                          config.g
                                          M501
                                          heightmap.csv
                                          RepRapFirmware height map file v2 generated at 2021-08-17 21:08, min error -0.052, max error 0.043, mean -0.010, deviation 0.022
                                          xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                                          -80.00,80.10,-80.00,80.10,85.00,20.00,20.00,9,9
                                                0,      0,      0,  0.001, -0.032, -0.007,      0,      0,      0
                                                0, -0.002, -0.007, -0.031, -0.020, -0.032, -0.028,  0.012,      0
                                                0, -0.016, -0.013, -0.029, -0.037, -0.003,  0.011,  0.009,      0
                                            0.003,  0.008,  0.010, -0.024, -0.023, -0.032, -0.020, -0.020,  0.009
                                            0.002, -0.013, -0.032, -0.040, -0.023, -0.017, -0.012, -0.003,  0.043
                                            0.000, -0.018, -0.024, -0.023, -0.021, -0.021, -0.032, -0.041, -0.002
                                                0,  0.002,  0.020,  0.021,  0.011,  0.039,  0.032,  0.030,      0
                                                0,  0.013, -0.020, -0.049, -0.052, -0.029, -0.020,  0.040,      0
                                                0,      0,      0, -0.007, -0.031, -0.027,      0,      0,      0
                                          homedelta.g
                                          ; homedelta.g
                                          pause.g
                                          resume.g
                                          ; resume.g
                                          ; called before a print from SD card is resumed
                                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:24 GMT-0400 (heure d’été de l’Est)
                                          G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
                                          G1 R1 X0 Y0 ; go back to the last print move
                                          M83 ; relative extruder moves
                                          G1 E10 F3600 ; extrude 10mm of filament
                                          ; pause.g
                                          ; called when a print from SD card is paused
                                          G1 E-10 F3600  ; retract 10mm of filament
                                          G1 Z5 F360     ; lift Z by 5mm
                                          G1 X0 Y0 F6000 ; go to X=0 Y=0
                                          sleep.g
                                          ; sleep.g
                                          ; called when M1 (Sleep) is being processed
                                          stop.g
                                          ; stop.g
                                          ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                                          tfree0.g
                                          ; tfree0.g
                                          ; called when tool 0 is freed
                                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:25 GMT-0400 (heure d’été de l’Est)
                                          tpost0.g
                                          ; tpost0.g
                                          ; called after tool 0 has been selected
                                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 20:11:26 GMT-0400 (heure d’été de l’Est)
                                          ; Wait for set temperatures to be reached
                                          M116 P0
                                          tpre0.g
                                          ; tpre0.g
                                          ; called before tool 0 is selected
                                          I have deleted resurrect.g file but still have it in my backup if I absolutely need to have it.
                                          Here is everything I have. Anyone know why my printer has become crazy this morning ? Not enough sleep or too much sugar, maybe? lol
                                            Yes that would be expected if you had not rebooted after deleting the config-override.g. The values would have been loaded at startup and then when you did M500 they would have been saved to the new file.
                                            And what does G32 do after homing has completed?
                                            Can you test your endstops with M119? Check that they all report as you'd expect when not pressed and then again when pressed. Maybe sure they match the towers they are paired with.
                                            https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_and_endstops_individually
                                            Are you sure nothing else has changed recently?
