    InputShaping-Plugin-0.1.0-rc6 released
    Plugins for DWC and DSF
    11
    35
    2.5k
    • SIamundefined
      SIam @mfs12
      @mfs12 first the good news, 😉 the support to show multiple profile graphs in one chart seems to work so far but setting of input shaping configuration here is the frequency always 0Hz
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      • Heartleander81undefined
        Heartleander81 @mfs12
        @mfs12
        Is there a guide on how to install plugins in DWC?
        Have never done that before
        SIamundefined 1 Reply Last reply Reply Quote 0
        • SIamundefined
          SIam @Heartleander81
          @heartleander81 it's the same way when you update the board click on the button upload system files and select the plugin archive.
          Then go to settings -> Machine Specific -> External Plugins and Activate the Plugin
          Heartleander81undefined 1 Reply Last reply Reply Quote 0
            Heartleander81 @SIam
            @siam ok thank you. I test it
            [Edit]
            Ok thank you again.
            Unfortunately, it is not. I have Beta 3.4.0 Beta2 when installing it tells me DWC 3.3.0 is the prerequisite. It is installed but there will be a change due to the beta
            • SIamundefined
              @heartleander81 You need the 3.4.b2 because this is the first version with Input shaping types
              • CaiJonasundefined
                CaiJonas @mfs12
                @mfs12
                thanks alot for your work.
                Unfortunatelly I'm getting this message:
                how can I solve this?
                Best Regards
                jay_s_ukundefined mfs12undefined 2 Replies Last reply Reply Quote 0
                  jay_s_uk @CaiJonas
                  @caijonas I get that too. I don't get than message if using the accelerometer plugin
                    @siam
                    I had done the SBC update but DWC 3.3.0 is still displayed. The board has firmware 3.4.0 Beta2 +. Wait until the next beta comes out. Thank you.
                    • SIamundefined
                      @heartleander81 have you installed DuetWebControl-SD.zip from the Release 3.4.0 beta 2 ?
                        jay_s_uk @SIam
                        @siam don't install that. it'll break DWC on an SBC build
                        • mfs12undefined
                          mfs12 @CaiJonas
                          @caijonas you get the error message "session does not match record's numer of samples" when you try to load different "records" with different numbers of samples.
                          Ususally you try to compare graphs from different recordings sessions where you were using different paramters. They are not comparable. At least so far.
                          Visit me on github at https://github.com/mfs12/
                            jay_s_uk @mfs12
                            @mfs12 i get that message when loading different graphs recorded using the same parameters
                            mfs12undefined 1 Reply Last reply Reply Quote 0
                            • mfs12undefined
                              mfs12 @jay_s_uk
                              @jay_s_uk did one graph have overflows?
                              jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                jay_s_uk @mfs12
                                @mfs12 how do I verify that?
                                  jay_s_uk @mfs12
                                  @mfs12 just looked at the files and all 3 have no overflows
                                  input-shaping-0-Z-none.csv
                                  input-shaping-0-Y-none.csv
                                  input-shaping-0-X-none.csv
                                  • mfs12undefined
                                    mfs12
                                    @jay_s_uk if there were overflows you usually get asked. At least if it's the first record to load.
                                    Or download the files and count the lines 😉 on Linux/MacOS you can use "wc -l" for that.
                                    $ cat RECORDED_FILE.csv | wc -l
                                    Here's the check that is failing...
                                    https://github.com/mfs12/DuetWebControl/blob/ef667f55bcc6043a48eb72e2769726a9a9d5a8d4/src/plugins/InputShaping/InputShapingSession.js#L185
                                    • mfs12undefined
                                      mfs12
                                      just checked. the line counts are ok.
                                      • mfs12undefined
                                        mfs12
                                        @jay_s_uk but they are not exactly the same. you should get an sample rate error and not a sample number error.
                                        The files use different sample rates.
                                        ==> 1629703252758-input-shaping-0-z-none.csv <==
                                        Rate 1286, overflows 0
                                        ==> 1629703255890-input-shaping-0-y-none.csv <==
                                        Rate 1284, overflows 0
                                        ==> 1629703258730-input-shaping-0-x-none.csv <==
                                          jay_s_uk @mfs12
                                          @mfs12 so how so I adjust that? they were all recorded using the input shaper plugin
                                          • mfs12undefined
                                            mfs12
                                            @jay_s_uk the easiest way would be to re-record them without tweaking any recording parameters.
