    Mesh bed leveling Z Endstop switch
    duet 3 mainboard 6hc duet 3 expansion board 1xd endstop for z manual bed probing
    803
      jay_s_uk @SignPostMan
      @signpostman no, they are very different.
      for one, an endstop is fixed to the frame, can be at the maximum or minimum of travel.
      the z probe can be used to level the bed, look at how flat the bed is and can be configured with an offset to the nozzle in X, Y and Z.
      a Z endstop is only really useful at max travel for print recovery
      SignPostManundefined 1 Reply Last reply Reply Quote 0
      • SignPostManundefined
        SignPostMan @jay_s_uk
        @jay_s_uk OK, that is why the endstop cannot be used for bed leveling. I just assumed they were the same thing. I will try to install a Z-Probe again. Any suggestions for a Z-Probe that will work over a long cable? the BL Touch does not seam to like it.
        jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
          @signpostman you could just stick with the switch if it doesn't get in the way of the nozzle.
          on one of my printers I use a BFPtouch (poor mans bltouch) and on another I run an inductive probe.
          Or, you could look at running a toolboard on the print head allowing you to use a bltouch
          • fcwiltundefined
            fcwilt @SignPostMan
            @signpostman said in Mesh bed leveling Z Endstop switch:
            The clue should have been different commands, the M574 command for configuring an endstop and the M558/G31 commands for configuring a Z probe.
            Whatever Z probe you use it has to be attached (or attachable) to the XY gantry in such a way that the probe tip can touch the bed surface.
            Naturally you have to observe all instructions regarding the installation of whatever Z probe you chose.
              @jay_s_uk Tool board is a great idea, I bet it will eliminate the problem with the long cable. Will I also need a Tool Distribution Board?
                @signpostman not if you're using just one
                  @jay_s_uk If I want to use the CAN connection to eliminate the problem with the length of the wires, I may need the Tool Distribution Board.
                    @signpostman i mean you don't need (or shouldn't need) a distribution board if you're only using one toolboard.
                      @jay_s_uk OK, Thanks
                      Thanks for your help Jay_s_uk
                      • fcwiltundefined
                        fcwilt @SignPostMan
                        Get the TDB - it makes the connection of power and CAN much easier and foolproof.
