    Mesh bed leveling Z Endstop switch
    duet 3 mainboard 6hc duet 3 expansion board 1xd endstop for z manual bed probing
    803
      The question is, do you have a z probe on the print head at all, or just a z endstop fixed on the frame?
      SignPostManundefined 1 Reply Last reply Reply Quote 1
      • SignPostManundefined
        SignPostMan @Phaedrux
        @phaedrux I have a Endstop attached as the Z Probe. I couldn't get the BL Touch to work. My printer is really large 2600x1300x300 and the cables I think were to long
          jay_s_uk @SignPostMan
          @signpostman where is it attached to?
          SignPostManundefined 1 Reply Last reply Reply Quote 0
            SignPostMan @jay_s_uk
            @jay_s_uk Right Now I am in testing and I just have it attached to the lin rail in Z.
            To be honest I really don't understand that there is a Z Probe separate from the Z Endstop. is it not the same thing?
              @signpostman no, they are very different.
              for one, an endstop is fixed to the frame, can be at the maximum or minimum of travel.
              the z probe can be used to level the bed, look at how flat the bed is and can be configured with an offset to the nozzle in X, Y and Z.
              a Z endstop is only really useful at max travel for print recovery
                @jay_s_uk OK, that is why the endstop cannot be used for bed leveling. I just assumed they were the same thing. I will try to install a Z-Probe again. Any suggestions for a Z-Probe that will work over a long cable? the BL Touch does not seam to like it.
                jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                  @signpostman you could just stick with the switch if it doesn't get in the way of the nozzle.
                  on one of my printers I use a BFPtouch (poor mans bltouch) and on another I run an inductive probe.
                  Or, you could look at running a toolboard on the print head allowing you to use a bltouch
                  • fcwiltundefined
                    fcwilt @SignPostMan
                    @signpostman said in Mesh bed leveling Z Endstop switch:
                    The clue should have been different commands, the M574 command for configuring an endstop and the M558/G31 commands for configuring a Z probe.
                    Whatever Z probe you use it has to be attached (or attachable) to the XY gantry in such a way that the probe tip can touch the bed surface.
                    Naturally you have to observe all instructions regarding the installation of whatever Z probe you chose.
                      @jay_s_uk Tool board is a great idea, I bet it will eliminate the problem with the long cable. Will I also need a Tool Distribution Board?
                        @signpostman not if you're using just one
                          @jay_s_uk If I want to use the CAN connection to eliminate the problem with the length of the wires, I may need the Tool Distribution Board.
                            @signpostman i mean you don't need (or shouldn't need) a distribution board if you're only using one toolboard.
                              @jay_s_uk OK, Thanks
                              Thanks for your help Jay_s_uk
                              • fcwiltundefined
                                fcwilt @SignPostMan
                                Get the TDB - it makes the connection of power and CAN much easier and foolproof.
