    Creality CR-10 upgrade
    252
    53.7k
    • Agniusmundefined
      Agniusm
      Sending M997 S1 returns:
      >>>M997 S1
      SENDING:M997 S1
      Invalid module number '1'
      Sending M997 S0 returns:
      >>>M997 S0
      SENDING:M997 S0
      Error: Firmware binary "DuetEthernetFirmware.bin" not found
      [ERROR] Error: Firmware binary "DuetEthernetFirmware.bin" not found
      Maybe i am skipping some crucial steps? Working on win10 64bit.
      I have not installed any drivers for the duetWifi
        Somehow you have installed DuetEthernetFirmware on your Duet WiFi. Is it definitely the Duet WiFi that you have - the board that has the WiFi module soldered on near on corner, with the antenna part overhanging the edge of the board? Or is it a Duet Ethernet, with a daughter board that carries the Ethernet socket?
        • Agniusmundefined
          Agniusm
          Its deff wifi, i had it connected to my network 😄
          I have not installed it yet, i just got the board today and read that it is advisable to upgrade to the newest firmware so i tried 🙂
          Got the files from here: https://github.com/dc42/RepRapFirmware/releases
          and i did dowload this file: DuetWiFiServer-1.19.bin
          • Agniusmundefined
            Agniusm
            How about if I rename duet WiFi to duet Ethernet and flash it then flash wifi module?
              If you run M115 i think you will find that it reports itself as a Duet Ethernet, because somehow it is running DuetEthernetFirmware.
              What you need to do now is download DuetWiFiFirmware-1.19.bin to /sys on the SD card. But then rename it to DuetEthernetFirmware.bin. Then you will be able to run M997 S0 to install it. When it has finished installing and rebooted after about a minute, you should be able to run M997 S1 to install the new WiFi firmware.
              Edit: your post crossed with mine.
              • Agniusmundefined
                Agniusm
                This error comes up:
                SENDING:M997 S0
                [ERROR] Can't read from printer (disconnected?) (SerialException): call to ClearCommError failed
                • Agniusmundefined
                  Agniusm
                  Erased all then used SAM-BA to load wifi firmware and then M997 S0:1 worked. All upgraded.
                  P.S. I was wandering if there is Ad-hoc functionality? Or is there a way to avoid using router and connecting strait to duetwifi from tablet?
                    @Agniusm:
                    SENDING:M997 S0
                    That's normal. The USB port is closed while the firmware is updated. You can reconnect about a minute later when the firmware update has completed.
                    Access point mode isn't working on the WiFi module with the current firmware.
                    • Agniusmundefined
                      Agniusm
                      I have made PanelDue 5" enclosure. Its fully enclosed to be mounted on 2020 extrusion with quick release(sort off). USB is inaccessible but easy altered: https://www.thingiverse.com/thing:2495311
                      • Agniusmundefined
                        Agniusm
                        Doing this extruder assembly and was wandering what is recommended distance from extruder to avoid heat damage?
                        • number40fanundefined
                          number40fan
                          My IR probe is about 5mm from the heat block, but I do have Kapton tape wrapped around the hotend as well as the back side of the probe. No issues.
                          • Agniusmundefined
                            Agniusm
                            thanks. mine probably be with e3d sock.
                              5mm is plenty, but put 2 layers of Kapton tape on the back as recommended in the fitting instructions, in case the heater block rotates, to prevent the back of the sensor board shorting against it.
                                number40fan
                                I was scared and put 5 layers!
                                • Agniusmundefined
                                  Agniusm
                                  Thanks. I turned the probe around so all the components are on the cool side. I'll put some caption on it, good advice.
                                  • Agniusmundefined
                                    Agniusm
                                    I just started wiring. I got some stranded 24awg utp cable. Would that be suficient for the motors? It is very convenient with 8 conductors inside:)
                                      24awg should be OK for up to 2A motor current, but not much more.
                                      • Agniusmundefined
                                        Agniusm
                                        Ok thanks. Here is some uodate on the setup. Sketched up duet wifi enclosure. Its simple but functional. Changed panel due mout to the side and angle from 60 degrees to 36ish. Done most of the cabling, here are the photos:
                                        • Agniusmundefined
                                          Agniusm
                                          Have a question on the bed. As i will use IR bed probe and have dual Z, should i mount my heat bed rigid or should i leave springs, old setup? It is a large bed (410x410) and four mounting points don't add to bed flatness. I am thinking of drilling two holes in the middle (same as Prusa i3 mk2) and mounting it on rigid standoffs. I will not use glass then and glue PEI sheet strait to aluminium heat bed. I will probably win some heating time.
                                          Thank you
                                            Dual leadscrews only provide for levelling the bed in one direction, so you still need levelling screws to adjust it in the other direction.
