BL Touch Installation what is Servo Pin?
4.9k
    SignPostMan @Phaedrux
    I have tested by inputting G30 in the command line with the same result
    ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sat Aug 21 2021 12:25:45 GMT-0400 (Eastern Daylight Time)
    M550 P"Duet 3" ; set printer name
    M569 P40.0 S1 ; physical drive 40.0 goes forwards
    M569 P41.0 S1 ; physical drive 40.0 goes forwards
    M569 P42.0 S1 ; physical drive 42.0 goes forwards
    M569 P43.0 S1 ; physical drive 42.0 goes forwards
    ;M569 P125.0 S1 ; physical drive 125.0 goes forwards
    M584 X40.0:41.0 Y42.0 Z43.0 ;E125.0 ; set drive mapping
    M92 X160.00 Y200.00 Z200.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z900.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z2000.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z250.00 E250.00 ; set accelerations (mm/s^2)
    M906 X2500 Y1200 Z1200 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X2300 Y1300 Z304 S0 ; set axis maxima
    M574 X1 S1 P"!^40.io1.in" ; configure active-high endstop for low end on X via pin !^40.io1.in
    M574 Y1 S1 P"!^42.io1.in" ; configure active-high endstop for low end on Y via pin !^41.io1.in
    M574 Z1 S1 P"!^43.io1.in" ; configure active-high endstop for low end on Z via pin !^43.io1.in
    M950 S0 C"io5.out" ; create servo pin 0 for BLTouch
    M558 P9 C"io5.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
    M143 H1 S500 ; set temperature limit for heater 1 to 500C
    M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
    M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
    ; homeall.g
    ; called to home all axes
    ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sat Aug 21 2021 12:06:10 GMT-0400 (Eastern Daylight Time)
    G91 ; relative positioning
    G1 H2 Z30 F6000 ; lift Z relative to current position
    G1 H1 X-2305 Y-1305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-2305 Y-1305 F180 ; move slowly to X and Y axis endstops once more (second pass)
    G90 ; absolute positioning
    G1 X250 Y650 F3000 ;move probe to centre of bed
    G30 ; probe bed
    G1 Z20 F1800 ; lift Z relative to current position
    ; homez.g
    ; called to home the Z axis
    ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sat Aug 21 2021 12:06:11 GMT-0400 (Eastern Daylight Time)
    G1 H2 Z10 F6000 ; lift Z relative to current position
    G1 H1 Z-309 F2500 ; move Z down until the endstop is triggered
    G1 H2 Z5 F6000 ; go back a few mm
    G1 H1 Z-20Y F180 ; move slowly to Z axis endstops once more (second pass)
    ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
    G30 ; probe bed
    G1 Z20 F2500 ; lift Z relative to current position
      fcwilt @SignPostMan
      @signpostman said in BL Touch Installation what is Servo Pin?:
      @fcwilt I set the A to 1, the Max Taps was 1.
      The method your describing is what I have done, I must touch it multiple time (different number each time. I even change the S Parameter to 5 and tested it with the same result. I have since changed it back.
      That would seem to confirm my belief that the signal from the probe to the board is inconsistent.
      I have two printers with a BLTouch but the wire lengths are perhaps 1 meter.
      One difference I have from your setup is the M558 command prefixes the pin name with the ^ character.
      What sort of wire is used to extended the black/white pair back to the board?
      undefined 1 Reply Last reply 26 Aug 2021, 18:38 Reply Quote 0
        SignPostMan @fcwilt
        @fcwilt I have tried CAT 5 cable and now I have 18 gauge 4 conductor that is not twisted pair
        undefined undefined 2 Replies Last reply 26 Aug 2021, 18:41 Reply Quote 0
          SignPostMan @SignPostMan
          Should it look like this?
          undefined undefined undefined 3 Replies Last reply 26 Aug 2021, 18:44 Reply Quote 0
            fcwilt @SignPostMan
            I would remove one twisted pair from the CAT cable and use that. And I would make sure to route it away from any source of noise, like stepper wiring.
            undefined 1 Reply Last reply 26 Aug 2021, 18:59 Reply Quote 1
              fcwilt @SignPostMan
              Yes
                Adding ^ didn't seem to help
                undefined 1 Reply Last reply 26 Aug 2021, 18:46 Reply Quote 0
                  fcwilt @SignPostMan
                  And you re-booted after making the change?
                  It was worth a try.
                    Phaedrux Moderator @SignPostMan
                    On the Duet3 the pullup should not be enabled.
                    undefined 1 Reply Last reply 26 Aug 2021, 18:57 Reply Quote 0
                      fcwilt @Phaedrux
                      @phaedrux said in BL Touch Installation what is Servo Pin?:
                      True but at this point any change might help point to the problem.
                      undefined 1 Reply Last reply 26 Aug 2021, 19:18 Reply Quote 1
                        Phaedrux Moderator @fcwilt
                        @fcwilt said in BL Touch Installation what is Servo Pin?:
                        This might be your best bet. Short of a toolboard.
                        As a sanity check can you test the bltouch with a much shorter length of wire with the probe not mounted on the print head? Keep it vertical and trigger it by hand to see if it will stop the Z axis.
                        undefined 1 Reply Last reply 26 Aug 2021, 19:57 Reply Quote 1
                          SignPostMan @fcwilt
                          @fcwilt Agree
                            @phaedrux What other probe do you suggest that would work with a long cable?
                            undefined 1 Reply Last reply 26 Aug 2021, 20:16 Reply Quote 0
                              Maybe a good quality Normally Closed microswitch that you could manually mount before probing with some good quality shielded wire? Or a conductive touch plate that could be moved under the nozzle?
                              With a printer that size options may be limited?
                              With better wire the BLTouch may be viable as well.
                              undefined 1 Reply Last reply 26 Aug 2021, 20:49 Reply Quote 0
                                fcwilt @SignPostMan
                                What sort of bed do you have? What is it made of. What sort of surface do you print on?
                                undefined 1 Reply Last reply 26 Aug 2021, 20:39 Reply Quote 0
                                  SignPostMan @fcwilt
                                  @fcwilt Right now I have a piece of corrugated plastic, so the probe does not get destroyed. I am going to have a aluminum with steel overlay when complete.
                                  undefined 1 Reply Last reply 26 Aug 2021, 20:45 Reply Quote 0
                                    fcwilt @SignPostMan
                                    Will there be any magnets involved like you find in the Buildtak system?
                                      @phaedrux I just shortened the cables and put new fittings on the end
                                      undefined 1 Reply Last reply 26 Aug 2021, 20:50 Reply Quote 0
                                        Still have exactly same issue.
                                        undefined undefined 2 Replies Last reply 26 Aug 2021, 20:52 Reply Quote 0
                                          fcwilt @SignPostMan
                                          Do you have all 5 wires from the BLTouch connected to the board?
                                          59 out of 80
