Solved Difference between G28 and M98"homeall.g"?
@o_lampe said in Difference between G28 and M98"homeall.g"?:
Q: Is there a difference in sending G28 from the console or starting the homeall.g macro directly?
One significant difference is that G28 marks the axis/axes as un-homed before executing the code associated with the given axis/axes.
This can cause code that works with M98 to fail with G28 if the code is trying to move an un-homed axis.
@gloomyandy said in Difference between G28 and M98"homeall.g"?:
I'm not sure that what you are doing to clear an endstop is correct. It looks like:
M574 U0Which sets the endstop for that axis to none, may be the correct way to do this.
I think you are right, I'll test it first thing. I thought I had to free the formerly used pin.
PS: do you know if someone published a mounting case (for 2020 extrusion) for the F407ZG? I couldn't find a drawing which shows the mounting hole pattern...
@o_lampe
PSS: Where can I find more info on the "Z3" endstop, how to attach three switches and such? -
@o_lampe Sorry no idea about a case (i just have mine on my test bench!), @jay_s_uk may have some suggestions.
Freeing things in RRF is a bit messy. This example in the gcode listing:
M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input
seems to show that both the type 0 and nil pin are required, but looking at the code I'm not sure that is the case. I'd try just setting it to type 0 and see if that does what you want (I need to check again but I seem to remember that a P parameter may take it down a different code path!).
@o_lampe I didn't know there was a Z3 option, are you sure that is correct, there is the option to specify multiple endstops to match multiple Z motors via separate pins with something like:
M574 Z1 S1 P"io2.in+io3.in" ; Z axis with two motors, individual min endstops, active high
That is covered a little in the RRF GCode docs.
@gloomyandy Hmm, there's Zmin, Zmax and Z3, maybe I have to use them all in the way you described.
@o_lampe Where have you seen a reference to Z3? I don't see one in the gcode guide and the source code does not seem to have any idea of it, it only has...
noEndStop = 0, lowEndStop = 1, highEndStop = 2,
That's weird,
- I saw it mentioned on mellow fly aliexpress page
- there's a Z3 socket onboard
- teamgloomys github page mentions it on the pin names page
Supports dual Z-axis printers and three Z-axis printers (the motherboard has a dedicated Z3 limit switch interface).
...back to subject. I found out what caused the error message when calling G28 alone:
G28 automatically tries to home X,Y and Z even when homeZ is not mentioned in homeall.g.
I currently have no Z axis, so there's no endstop defined for Z...
I could probably delete or move homez.g or add M574 Z0 in config.g to supress the error message -
deleting an endstop only works with e.g. M574 X0.
Adding P"nil" is wrong
removing/renaming homeZ only led to another error: can't find homeZ.g
So I wrote homeZ with these lines:M574 Z0 G92 Z0
and no error popped up
Thanks all who tried to help
This post is deleted!
