Unsolved firmware 3.0 and more
@phaedrux
thanks. will try everything you suggested. -
@ooly
Phaedrux,
I have uploaded all updates as suggested. however, when trying to reconfigure my delta I am running on all kinds of problems.-
homing all does not work because "failed to enable endstops". this in spite the fact I have "G1 H1 x....", in homedelta.g, which to my understanding activates the end switches.
in the RRF config tool, the endstops section is confusing to me and the problem, among others, revolves around the definition of X,Y,Z for delta printers. they can refer to the horizontal x and y together with height z; or they can be the height of the three towers. clearly these two interpretations are used in the configuration tools and in the settings. I had struggled with this problem two years ago when I built my delta, finally some how got it to work. now I forgot what I did and I am lost.
@ooly
here is the homedelta.g:G91 ; relative positioning
G1 H1 X235 Y235 Z235 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centre -
Post your config.g as well please. I think something in your config.g isn't quite right.
Also the results of M122 and M98 P"config.g" sent in the gcode console.
You may also find these helpful.
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer -
@phaedrux
thanks for bearing with me.I keep getting "failed to enable endstops" which means I cannot home anything and therefore I am locked out. is anything wrong with the homedelta.g above? how do I enable the endstops?
will post config.g later
@ooly
here is my config.g; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.1 on Sun Aug 29 2021 18:00:06 GMT+0300 (Eastern European Summer Time); General preferences
M550 P"oolys" ; set printer name
M665 R94.5 L215 B73 H216 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
; paneldue
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X800 Y800 Z800 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"null" ; configure active-high endstop for high end on Z via pin null; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z0.8 ; set Z probe trigger value, offset and trigger height
M557 R73 S20 ; define mesh grid; Heaters
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CM575 P1 B57600
M501
T0
; Custom settings are not defined -
@ooly said in firmware 3.0 and more:
Where is the Z endstop plugged in? Most likely, change the above to
M574 Z2 S1 P"zstop"
@droftarts
Ian, thanks.
I changed 574 as you suggested but I am still not there.in a delta there are no endstops for the horizontal "x" and "y", only
z probe for the bottom, and of course three XYZ endstops for the three towers, all on the top side.
on the other end, in the delta config tool, there is a clear difference between x, y, to that of Z.
kindly explain. thanks. -
@ooly What is "still not there"?
You need an endstop on each of the three delta axes, X, Y and Z. These are not referring to 3-dimensional space (as they might in a Cartesian machine), it's referring to the three delta towers. X, Y and Z are just axis labels. So you need to have a 3 endstops defined with M574. Check endstops are assigned to the correct axis and working correctly by sending M119 while depressing each switch in turn.The homedelta.g just homes these three axes at the maximum end. The M665 'H' parameter in config.g (or config_override.g) sets the homed height. The actual 'Z-probe' is used for the Delta auto calibration. See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Setting_up_your_initial_delta_parameters
@droftarts
I know and the three end switches are in place, but m119 brings back all at "max stop" when they are all midway.
my setting is m574 X2 S1 P"xstop" etc. tried x1 instead of x2 and it says x at "min stop" -
@ooly What does it say when you press the endstop and send M119? Most probably "not stopped". If so, it means you need to invert the logic of the endstop, as you have yours wired Normally Open, rather than Normally Closed.
Either change M574 to (note exclamation mark in pin definition):
M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin !ystop M574 Z2 S1 P"!zstop" ; configure active-high endstop for high end on Z via pin !zstop
Or rewire your endstops to Normally Closed, which is preferred as they are less susceptible to interference. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
Probably in your old RRF 2 config.g they were defined as
M574 X2 Y2 Z2 S0
, where S0 means they are inverted.Ian
ok, the ! did it. thanks
another problem: the status display is totally different from my old one in the 2.1 version. in the old one I could change the values of z. in this one I cannot so z is stuck at the top home value so I can't move it. is there a way to change z value in the status window? or alternatively return to the old window? -
@ooly
another problem: while commanding movements in the dashboard, speed is not constrained by the "max speed" setting in config.g.
how do I limit these movements? thanks -
@ooly
how do I limit these movements? thanksWith firmware 3.3 the M203 settings control the max speed of those movements.
If you mean change the jog amounts, right click on the number you want to change. See https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_Adjusting_movement_amounts
how do I limit these movements? thanksI very much doubt that. You have your M203 set as:
18000 mm/min = 300mm/s. Are you saying it goes faster than that?!Ian
Ah, just worked out what you mean. In DWC v1 you could click on the X, Y or Z position and enter a new value for the axis to move to. I think this was removed as it was too easy to upset a print by accidentally clicking on it. You need to use the jog buttons, or send the gcode (ie G1 Z50) to move the nozzle to a specific location.
If you've upgraded to RRF 3.3, I don't think DWC 1 will work any more as the communication protocols have changed.
@ooly
how do I limit these movements? thanksIf you're talking about the displayed max speed while homing being higher than you'd expect that's a display anomaly due to the way delta kinematics speed is calculated.
