Duet 2 wifi z axis takes off on board reset
446
    cbrunnem2 @engikeneer
    @engikeneer
    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jul 21 2021 18:08:02 GMT-0400 (Eastern Daylight Time)
    M550 P"My Printer" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M350 X256 Y256 Z256 E256 I0 ; configure microstepping without interpolation
    M92 X1280.00 Y1280.00 Z6400.00 E1563 ; set steps per mm
    M566 X600 Y600 Z300 E120 ; set maximum instantaneous speed changes (mm/min)
    M203 X12000.00 Y12000.00 Z3600 E4800.00 ; set maximum speeds (mm/min)
    M201 X400 Y400 Z100 E250 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
    M84 S50 ; Set idle timeout
    M208 X0 Y0 Z-2.0 S1 ; set axis minima
    M208 X350 Y400 Z400 S0 ; set axis maxima
    M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X0 Y0 Z1.94 ; set Z probe trigger value, offset and trigger height Z1.92 for .8mm nozzle 1.84 for .8mm nozzle
    M557 X50:350 Y0:400 S100 ; define mesh grid
    M140 H-1 ; disable heated bed (overrides default heater mapping)
    M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e0temp
    M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
    M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H0 S300 ; set temperature limit for heater 0 to 300C
    M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
    M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
    M563 P0 D0 H0 F0 ; define tool 0
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 0JD0M-9P6B2-NJ4S8-6J9F6-3SJ6L-1A4QK
    Used output buffers: 3 of 24 (13 max)
    Static ram: 27980
    Dynamic ram: 93632 of which 20 recycled
    Exception stack ram used: 600
    Never used ram: 8840
    Tasks: NETWORK(ready,268) HEAT(blocked,1224) MAIN(running,1732) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 06:19:07 ago, cause: software
    Last software reset at 2021-09-02 07:48, reason: User, spinning module GCodes, available RAM 8792 bytes (slot 0)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 32.6, current 35.9, max 39.5
    Supply voltage: min 23.7, current 24.1, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, SG min/max 0/257
    Driver 1: standstill, SG min/max 0/245
    Driver 2: standstill, SG min/max 0/613
    Driver 3: standstill, SG min/max 0/119
    Date/time: 2021-09-02 14:07:57
    Slowest loop: 203.84ms; fastest: 0.12ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 5.2ms, write time 53.0ms, max retries 0
    Hiccups: 17795(0), FreeDm: 169, MinFreeDm: 116, MaxWait: 148682ms
    === MainDDARing ===
    Scheduled moves: 255722, completed moves: 255722, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
    Heater 0 is on, I-accum = 0.4
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 111.82ms; fastest: 0.00ms
    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is active
    WiFi firmware version 1.23
    WiFi MAC address EDITED
    WiFi Vcc 3.38, reset reason Unknown
    WiFi flash size 4194304, free heap 22608
    WiFi IP address EDITED
    WiFi signal strength -52dBm, reconnections 0, sleep mode modem
      So the instant you power on the Z axis starts to move?
      @cbrunnem2 said in Duet 2 wifi z axis takes off on board reset:
      Hiccups: 17795(0)
      It's not recommended to use x256 microstepping for all axis as it can overwhelm the step generation and provides no real benefit. x16 with interpolation enabled is generally the way to go. I suggest switching to that and adjusting your steps per mm accordingly.
      Probably also a good idea to update your firmware to 3.3
      Upload this zip file to the system tab in DWC.
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
      With those changes in place, see if it still behaves the same.
      undefined 1 Reply Last reply 2 Sept 2021, 20:45 Reply Quote 0
        cbrunnem2 @Phaedrux
        @phaedrux
        1. I don't know if it moves on power up as it already is bottomed out so it can't move any further down. It moves down at a reset of any type.
        2. I will change the microstepping. Do you recommend on all axis or just z?
        3. I will update the firmware.
          Use x16 with interpolation for all axis. The only time using higher makes any sense is if you need extra resolution in an extruder that has a very low natural steps per mm like an ungeared direct drive extruder with a 1.8 motor.
          Are you able to manually move the Z axis up even when it's bottomed out?
          Does it sound like the motors are stalling?
          What kind of a Z axis is it? Does it have enough weight to fall on it's own? You say it's a cartesian, but is it a bed that moves in Y or does the bed move in Z?
          undefined 1 Reply Last reply 2 Sept 2021, 21:20 Reply Quote 0
            cbrunnem2 @Phaedrux
            @phaedrux x and y move on a trolley rail system. Z moves strictly up and down. It has a lead screw on two sides of the bed and uses two motors. One on each lead screw.
            As mentioned, the only time this happens is when the board is reset. Once it reboots I have to rehome and level the bed. I can then print as normal.
            Lastly, my extruder is a non geared with a 200 step per rev stepper so it sounds like it's a good idea to not use 16x? Recommendation?
            undefined 1 Reply Last reply 2 Sept 2021, 22:14 Reply Quote 0
              Phaedrux Moderator @cbrunnem2
              It sounds like the Z axis is heavy enough that it could be causing it to auto rotate and fall when the motors are de-energized.
              Photos?
              Adjust your microstepping so that your steps per mm are in the 400 range.
              undefined 1 Reply Last reply 2 Sept 2021, 22:22 Reply Quote 0
                cbrunnem2 @Phaedrux
                @phaedrux I'll send pictures later. It's definitely driving as the couplers attaching the screw to the motor stretch out when it bottoms out.
                Will make the adjustments and report back.
                  cbrunnem2
                  just installed the new firmware. as soon as it asked me if i wanted to install and i clicked yes, the bed took off downward.
                  after i reset the microsteps... issue gone.
                  i have had x256 working for over a month. why is this an issue now?
                  undefined 1 Reply Last reply 3 Sept 2021, 00:11 Reply Quote 0
                    cbrunnem2 @cbrunnem2
                    Soooo I just realized that I greased the z lead screws since the last reset. It's likely falling. Never thought it could fall this fast. Any way to prevent this?
                    Def need to find a way to tie the two z lead screws together. Can't find a belt that can span 20 inches. Might have to come up with a contraption to use 2 belts.
                    undefined 1 Reply Last reply 3 Sept 2021, 00:53 Reply Quote 1
                      Using a lead screw with a shallower pitch could help. Or perhaps adding spring loaded anti-backlash nuts to increase the friction.
                      If you have a spare driver you can use one for each Z motor and then use auto leveling to get them in sync and level with the bed.
                      https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                      undefined 1 Reply Last reply 3 Sept 2021, 01:46 Reply Quote 0
                        fcwilt @cbrunnem2
                        @cbrunnem2
                        Well as you may have observed in the past after a re-boot the steppers are off so your Z axis can fall due to your 8mm lead lead screws.
                        What you could try is putting a G91 G1 Z0.1 pair of commands in your config file, after the steppers are configured, to turn the Z steppers on.
                        Now normally doing a move in your config file is considered a bad idea but a tiny move would likely be ok.
                          cbrunnem2 @Phaedrux
                          @phaedrux hmm this could be the ticket here.
                          yall are awesome. just needed some good nudging to get to the right path. also fixed some things too that i didnt know needed fixed!
                          12 out of 14
