    Smart Effector V3 an plastic nut
    Smart effector for delta printers
    1.5k
    • Fred-Yundefined
      Fred-Y @Velvia
      @velvia I'm actually working on something.
      https://www.thingiverse.com/thing:4948025
      I have a Smart Effector v2, I'm not sure if it will fit on a v3.
      I am also added a proper inside groove to clip the PTFE tube.
      Initially I wanted to use a threaded connector but it is not possible, it would not be strong enough (wall too tin).
      This the adapter in printed of PA-CF at .1mm later (I tried ABS+ but it just broke when I tightened the nut) and the nuts with eSun ABS+.
      Velviaundefined 2 Replies Last reply Reply Quote 1
      • Velviaundefined
        Velvia @Fred-Y
        @fred-y This looks promising! Will try in CF-ABS or CF-PC. I also have a V2 for some reason. I thought V3 was latest, just got mine today from E3D.
        edit: by the way, is that an accelerometer you have behind the bowden tube? What type is it? Would like to try to use one now that RRF is implementing input shaping.
        Homegrown, grass fed and organically built 350mm delta
        Fred-Yundefined 1 Reply Last reply Reply Quote 0
        • Fred-Yundefined
          Fred-Y @Velvia
          @velvia I haven't found the time to search details about the v3, I'm not even sure if it has been released to be honest.
          I hope Duet3D will make a Smart Effector similar to the Tool Board v1.2 with integrated accelerometer - I designed a mount for it, you can see it on the picture, I will publish it shortly on Thingiverse as well.
          A CANBus would be really nice but it won't be retro-compatible with the Duet 2.
          Anyway, let me know if it requires a few adjustments, the inside groove for the collet has been a little challenging to make, I can easily increase or decrease it.
          • Velviaundefined
            Velvia @Fred-Y
            @fred-y I printed on in CF-ABS and it looks to work well. I'm waiting for some M2.5 bolts to mount it to the Dragon. I have a suggestion however: add an "arm" with a hole, so that it can be rigid mounted to the smart effector. One is enough. The it would fit nicely with my 40mm fan shroud as well. Or would you be willing to share .step files?
            • Fred-Yundefined
              Fred-Y @Velvia
              @velvia I was actually thinking to do it after having mounted everything, the hotend turns as I try to tight the nozzle - the advantage for me to install it was actually to don't have to use another tool.
              Check this one https://www.thingiverse.com/thing:4947898/files it has 3 arms.
              I found it after I published mine, I think that's what you are looking for, I'm not sure this the 2 heatsinks (TriangleLab vs Phaetus) have the same bolt pattern.
              I might load it in fusion to check, hopefully it works and I can still use the accelerator mount I made 🤞
              Velviaundefined 2 Replies Last reply Reply Quote 0
              • Velviaundefined
                Velvia @Fred-Y
                @fred-y I tried that one, but it's designed for a PC4 M6 bowden coupler. Yours worked great.
                Fred-Yundefined 2 Replies Last reply Reply Quote 0
                • Fred-Yundefined
                  Fred-Y @Velvia
                  @velvia I'm working on it, I'm going to make a 2 and 3 arms version.
                  I'm pretty sire it can work with my accelerometer mount with no issue.
                  I will publish when I printed it, I need to check the tolerances for the nuts and make sure it's solid enough.
                  I hope it won't impact the sensibility of the effector.
                  • Fred-Yundefined
                    Fred-Y @Velvia
                    @velvia I added the new version here: https://www.thingiverse.com/thing:4948025
                    I printed it but I haven't installed it so far, I will do it tomorrow it need to disassemble by Delta.
                    Support are not required not the nuts.
                    PCRundefined 1 Reply Last reply Reply Quote 0
                    • PCRundefined
                      PCR @Fred-Y
                      @fred-y couls you share the .step ? 😉
                      • Velviaundefined
                        Velvia @Fred-Y
                        @fred-y I remixed that one to have one arm. Step file included: https://www.thingiverse.com/thing:4957839
                        It still uses M6 PC4 bowden connector though. Ordered one from aliexpress.
                        The reason I made it with only one arm is because of the 40mm fan shroud I made, which requires the other 2 holes. The model of it is a mess, but it prints without supports and seems to work.
                        • Fred-Yundefined
                          Fred-Y @PCR
                          @pcr STEP file has been added.
                          • garyd9undefined
                            garyd9 @GuruSMI
                            @gurusmi said in Smart Effector V3 an plastic nut:
                            the adapter i talked about ist that Thing. There i printed only the adapter named Dragon_Adapter_v3.stl, It is made for the full dragon hontend and also for the BMO. You will have to take off the BMO's groove adapter. One don't need the Groove Adapter any longer with this design.
                            I realize that this is an older post I'm replying to. However, this is the first I'm seeing it. As the author of that thing, I'm kind of amused that you are asking any questions about nuts. When I designed the adapter, I realized that there are two different threads being used for smart effectors, and to avoid any issues, I included a .STL file of a nut that works fine. I even mention it in the instructions:
                            After attaching the adapter to the hotend, simply put the M12 threads of the adapter through the 12mm hole in the smart effector, and attach the printed nut.
                            I'd suggest scaling the nut to 100.1% if printing at the original size doesn't work. The nut should be a tight fit (to prevent it loosening) but not impossible to thread on the adapter.
                            I actually prefer using the plastic printed nut to using a metal one for weight savings. I also feel that I can tweak the scaling of the nut in order to make a very tight fit on the threads (which avoids any issue of the nut loosening over time.)
                            I am happy to see remixes of the thing that add "arms" to prevent rotation of the hotend.
                            • Fred-Yundefined
                              Fred-Y @garyd9
                              @garyd9 Thanks for making the original design and sharing the STEP file 👍
