Strange hight map
Regards being all red:
Before creating/loading a height map you have to set the Z=0 Datum using a single G30 at some fixed XY location.
Some folks use a specific point on the "height map" grid, other folks (like me) use the center of the bed.
Your height map image suggests you did not set the Z=0 Datum or it did not work correctly.
Regards the shape:
It's a bit hard to tell without being able to view the height map from different angles.
If you post the file here we can download and view it.
Until then I'm guessing your bed is not level.
@fcwilt Thanks a lot for your reply
I dont get how the "G31 P500 X0 Y0 Z1.95" in the z-probe section in config.g, is related to the Z=0 Datum? -
@hsverre said in Strange hight map:
I dont get how the "G31 P500 X0 Y0 Z1.95" in the z-probe section in config.g, is related to the Z=0 Datum?Let's assume you decide to use the center of the bed as the Z=0 reference point.
Assume:
- the bed is 300 x 300
- the X axis is 0 to 300
- the Y axis is 0 to 300
- probe X offset is 5
- probe Y offset is 10
Thus the center of the bed is at X=150, Y=150.
To position the probe at the center of the bed you need to account for the probe X and Y offsets.
So the command G1 X145 Y140 would move the probe to X=150, Y=150.
So to set the Z=0 Datum:
G29 S2 ; cancel mesh bed compensation M290 R0 S0 ; cancel baby stepping G1 X145 Y140 ; move probe to bed center G30 ; do single probe - sets Z to probe trigger height - if trigger height is wrong Z position will be wrong Having set the Z=0 Datum you can now use G29 to create the height map
@fcwilt Is it still the same procedure when i have four independent z-axis leadscrews?
Setting the Z=0 Datum?
Yes it is.
The independent Z steppers are involved in auto-bed leveling which also requires setting the Z=0 datum after the leveling is done.
But auto-leveling is not related to mesh bed compensation.
@fcwilt Where can i see what z=datum level is set? How do i figure out if it is set or not?
You cannot. You just have to perform the Z=0 Datum setting at certain times:
- after homing Z using endstops (if it will not be done later by one of the items below)
- after auto-leveling the bed (if you printer has the ability)
- before creating the height map
- before loading the height map
The G30 command just sets the current logical Z position (what the firmware "thinks" the Z position is) to match the Z Trigger Height parameter in your G31 command.
Assume the probe triggers at exactly 5mm above the bed and the G31 Z Trigger Height parameter is set to that value, 5.
You probe the bed with a G30, the probe triggers, therefore the current physical Z position is Z=5 and the logical Z position is set to Z=5.
Now the logical Z position matches the physical Z position and everything is in sync.
@fcwilt I cant make this fit with whats said at the Duet Wiki https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation section "Establish a Z=0 datum using the Z probe". ...
To establish a Z=0 datum by one of the following methods: "Alternatively, if the printer has multiple independent Z leadscrews and you have set up leadscrew bed levelling, run leadscrew bed levelling (G32)"Im running G32, why do all the other stuff?
The other stuff is only required when the bed is not planar.
You don't necessarily need that with a high quality print bed. -
Well I use the center of the bed as my reference point for setting the Z=0 Datum.
Auto-leveling the bed can change the Z position of the center of the bed so I follow the bed leveling procedure with the Z=0 Datum procedure.
I don't worry about setting the Z=0 Datum more often then necessary. I simply make sure that it is done when it must be done.
I dont get how the "G31 P500 X0 Y0 Z1.95" in the z-probe section in config.g, is related to the Z=0 Datum?This says that the probe has a zero X/Y offset from the nozzle, is considered 'triggered' when the analogue input reaches 500, and when it is triggered the nozzle is 1.95mm above the bed (I.e. it knows that z=0 is 1.95mm below where it triggered).
As @fcwilt says, you need to do a single G30 probe at a known location (typically the centre of the bed) after a G32 levelling, and before creating or loading a heightmap.
@engikeneer The G32, doesnt it do the G30, why do it again? Whats the difference between the G30 done in the beg.g and the G30 you are talking about?
Im sorry for the lack of knowledge, trying to learn
The beg.g file:
; bed.g
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 30 2021 22:46:27 GMT+0200 (sentraleuropeisk sommertid)
;M561 ; clear any bed transform
;G29 ; probe the bed and enable compensation
G28 ; home
;M401 ; deploy Z probe (omit if using bltouch)
G30 P0 X700 Y400 Z-99999 ; probe near a leadscrew
G30 P1 X700 Y5 Z-99999 ; probe near a leadscrew
G30 P2 X5 Y5 Z-99999 ; probe near a leadscrew
G30 P3 X5 Y400 Z-99999 S4 ; probe near a leadscrew and calibrate 4 motors
;M402 ; retract probe (omit if using bltouch) -
The beg.g file:
; bed.g
G28 ; home
;M402 ; retract probe (omit if using bltouch)Yes G32 does 2,3 or 4 G30 commands but it doesn't do one at the center of the bed which I use as my Z=0 reference point.
You can use one of the G32 points as your Z=0 reference point but I simply prefer the center of the bed.
Regardless of the points I probe with G32 or G29 the center of the bed is always in the same XY location.
So I have one file with just the commands needed to perform the Z=0 Datum setting procedure. I call that file from other files as needed.
Please tell us what firmware version you're using. Show us your config.g, homeall.g, homez.g, bed.g, and slicer start gcode. We need to know what's going on before the heightmap is created.
@phaedrux
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2021-06-15 21:45:03CONFIG.G:
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 30 2021 22:46:27 GMT+0200 (sentraleuropeisk sommertid); General preferences
M550 P"Voron24" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; z drive 1
M569 P2 S1 ; z drive 2
M569 P3 S0 ; z drive 3
M569 P4 S1 ; z drive 4
M569 P5 S1 ; a drive 5
M569 P6 S1 ; b drive 6
M569 P7 S0 ; ex drive 7
M584 X5 Y6 Z1:2:3:4 E7
M671 X815:815:-125:-125 Y500:-130:-130:500 S20 ; leadscrews at rear left, front middle and rear right
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M208 X700 Y400 Z500 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P1 C"zprobe.in" H20 F2000 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P1000 X0 Y0 Z1.995 ; set Z probe trigger value, offset and trigger height
M557 X15:700 Y15:400 S80 ; define mesh grid; Heaters
HOMEALL.G:
Voron24
m115
Status
Idle
Mode: FFF
Tool Position
X
655.0
Y
335.0
Z
22.00
Extruder Drives
Drive 0
0.0
Speeds
Requested Speed
0 mm/s
Top Speed
0 mm/s
Sensors
Vin
12.4 V
MCU Temperature
26.3 °C
Z-Probe
0
Tools
Extra
Control Heaters
Tool Heater Current Active Standby
Tool 0
T0 - PLA Heater 1
off 19.0 °C
0
0
Bed Heater 0
off -273.1 °C
0
0
Temperature Chart
System Directory
0:/sys/homeall.g
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-705 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-705 ; home X axis
G1 H1 Y-405 ; home Y axis
G1 H1 X-705 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-405 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioningHOMEZ.G:
; homez.g
; called to home the Z axis
G1 X15 Y15 F6000 ; go to first probe point
;G90 ; absolute positioningBED.G:; bed.g
G28 ; home
;M402 ; retract probe (omit if using bltouch)Some lines from a gcode file im trying to print. I dont have any startcode defined in particular:
;FLAVOR:RepRap
;TIME:2808
;Filament used: 4.52013m
;Layer height: 0.3
;MINX:25.485
;MINY:43.136
;MINZ:0.3
;MAXX:65.436
;MAXY:83.089
;MAXZ:30.2
;Generated with Cura_SteamEngine 4.11.0
T0
M104 S200
M109 S200
M82 ;absolute extrusion mode
print_start
M83 ;relative extrusion mode
G1 F4800 E-6.5
;LAYER_COUNT:100
;LAYER:0
M107
G1 F600 Z0.5
G0 F7200 X33.265 Y44.154 Z0.5
;TYPE:SKIRT
G1 F600 Z0.3
G1 F1920 E6.5
G1 F1200 X33.795 Y43.806 E0.03559
G1 X34.364 Y43.528 E0.03554
G1 X34.964 Y43.323 E0.03559
G1 X35.584 Y43.195 E0.03553
G1 X36.106 Y43.149 E0.02941 -
If you put your mouse cursor over that errant point in the grid it will give you the xy coordinate. Is there anything strange or unique about that point? Is the probe triggering early there for some reason?
What type of probe is it?
@phaedrux The coordinates for the errant point is X15 Y95 Z5,76 the next point is X15 Y15 Z0.575. And its not a difference like nearly half a cm. The build plate looks perfectly flat, its a milled 8mm cast aluminium plate.
The probe is a "PL-08N2 8mm sensing DC NPN NC Cube shell inductive Screen shield type proximity switch LP08 proximity sensor 171735"
When i try to print the printer starts to print about 10 mm above the build plate when I have Mesh Compensation on. When Mesh Comp is off the nozzle scraps the plate.
Whene i use the G32 True Bed Leveling it corrects axis 1 and 3 consistently. As if the Leveling prosess itself un-corrects the leveling.
Test the trigger height of the probe at that point. It looks like it's triggering too early.
