    Layer times
    Duet Web Control
    layer time
    520
    • IMSotherundefined
      IMSother
      Im relatively new to the duet firmware, and after a couple of months printing with an Ender 3 with duet wifi motherboard, the layer time is no longer working properly. Although it shows the current layer correctly on the progress bar, the last layer time doesn't update, neither does de layer time graph.screenshot.png
      For clarification, I'm using cura as slicer, with the reprap gcode flavor and one example gcode is attached (not exactly the gcode from the screenshot because its too big to upload here, but I can upload to my drive if that helps). Also, this is my home routine and config.g files, as I think that maybe this has to do with the BLTouch configuration.
      Any help will be apprecieted.
      Thanks
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 25 2021 17:30:43 GMT-0300 (Horário Padrão de Brasília)
      G1 H2 Z5 F6000          ; lift Z relative to current position
      G1 H1 X-250 Y-245 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000       ; go back a few mm
      G1 H1 X-250 Y-245 F120  ; move slowly to X and Y axis endstops once more (second pass)
      G90                     ; absolute positioning
      G1 X122 Y117 F6000        ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      ;G91                    ; relative positioning
      ;G1 Z1 F100             ;E lift Z relative to current position
      ;G90                    ; absolute positioning
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Ender 3"                                    ; set printer name
      M552 S1                                            ; enable network
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S0                                         ; physical drive 1 goes backwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S0                                         ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E97.03                   ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z600.00 E6000.00          ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
      M906 X600 Y600 Z600 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M208 X0 Y-6 Z0 S1                                  ; set axis minima
      M208 X245 Y234 Z260 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-55 Y-13 Z1.490		   			   ; set Z probe trigger value, offset and trigger height
      M557 X5:203.5 Y30:200 S24.81                       ; define mesh grid
      M376 H10										   ; set compensation taper to 10mm
      M308 S0 P"bedtemp" Y"thermistor" T98801 B4185      ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M307 H0 R0.258 C465.8 D0.45 S1.00 V23.8			   ; set PID values for bed heater
      M140 H0                                            ; map heated bed to heater 0
      M143 H0 S130                                       ; set temperature limit for heater 0 to 130C
      M308 S1 P"e0temp" Y"thermistor" T98801 B4185       ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M307 H1 R2.779 C155.7 D5.90 S1.00 V24.1			   ; set PID values for extruder heater
      M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
      M308 S2 P"e1temp" Y"thermistor" T98801 B4185  ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2                           ; create chamber heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00                               ; disable bang-bang mode for the chamber heater and set PWM limit
      M141 H2                                        ; map chamber to heater 2
      M143 H2 S100                                   ; set temperature limit for heater 2 to 100C
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P1 S1 H1 T100                               ; set fan 2 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H2 T50                               ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                   ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      M206 Y-9 ; Y axis offset
      M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      T0                                                 ; select first tool
      CE3_Porca_cubo_traseiro.gcode
        What firmware version?
        As of 3.3:
        RepRapFirmware no longer tries to work out what layer number is printing, and no longer provides an estimate of print completion time based on layer progress. The mechanism to work out the layer number failed in many cases, for example when the slicer used variable layer heights or printed multiple objects one at a time. The removal of these 200 lines of hard-to-maintain code has made more space available for other features on the older Duets that are tight on memory space. A consequence of this change is that DWC will no longer produce a layer chart if the GCode file being printed does not include layer number comments. For slicers that do not normally generate these comments (e.g. PrusaSlicer) it is usually possible to add a layer change script to generate them.
        https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-33
        o_lampeundefined IMSotherundefined 2 Replies Last reply Reply Quote 0
        • o_lampeundefined
          o_lampe @Phaedrux
          @phaedrux
          [OffTopic]
          In future releases (with multiple gcode streams and simultaneous printing) it will come handy to pre-calculate layer time of each tool and synchronize them by slowing down the tool with the shorter print path / smaller print area.
          But that will probably be done in DWC or SBC.
          The simulator tool of DWC will play a bigger role then. Writing a combined gcode file from two input streams and detect/avoid tool-collisions a.s.o.
          IMHO it's the best way for older controllers like Duet2 to implement these features . Fingers crossed it will come that way...
          • CadetCundefined
            CadetC
            @imsother
            @Phaedrux
            I had a similar problem, but I use PrusaSlicer . Everything came back to normal after adding ;LAYER:[layer_num] to the custom gcode tab under the "before layer change g-code" section in printer setting in PrusaSlicer
            IMSotherundefined 1 Reply Last reply Reply Quote 1
            • IMSotherundefined
              IMSother @Phaedrux
              @phaedrux I'm using RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11) and Duet Web Control 3.3.0
              • IMSotherundefined
                IMSother @CadetC
                @cadetc My G-Code already has that line, you can see that the board knows which layer it is, just is not counting the layer time.
                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                • DIY-O-Sphereundefined
                  DIY-O-Sphere @IMSother
                  @imsother
                  Maybe the problem is that the versions of RRF and DWC are different.
                  The calculation of firmware was changed in RRF3.3. Maybe DWC is not backwards compatible in that case.....
                  (UTC+1)
                    Phaedrux Moderator @IMSother
                    @imsother said in Layer times:
                    Update your firmware to match the DWC version. They must be in sync for proper function.
                    I suggest you upload this complete zip file package to the system tab in DWC to get everything up to date.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                    IMSotherundefined 1 Reply Last reply Reply Quote 0
                    • IMSotherundefined
                      IMSother @Phaedrux
                      @phaedrux said in Layer times:
                      Just did that, and worked perfectly! Thanks for all the help guys!
