    InputShaping-Plugin-0.1.0-rc7 released (repacked)
    Plugins for DWC and DSF
    12
    32
    2.2k
    • mfs12undefined
      mfs12 @Fred-Y
      @fred-y thanks for your feedback. basically all of your ideas are going to be implemented in future versions. so stay tuned 😉
      Visit me on github at https://github.com/mfs12/
      Fred-Yundefined 1 Reply Last reply Reply Quote 1
      • Fred-Yundefined
        Fred-Y @mfs12
        @mfs12 I'm looking forward to test the next releases!
        This might be a little off topic: is there a plan to implement a script similar to the one used by Klipper to determine the best frequency / type for IS?
        Using the graphs requires some knowledge and analysis, for example the spike at 102Hz on my graph is deceiving as it is not caused by a movement, it exists on a records done with no moves. I suspect it to come from the PSU fan on top of my Delta.
        • mfs12undefined
          mfs12
          @Fred-Y thanks for you help.
          Yes, we plan to automate as much as possible. Although i can't tell you yet what is going to be realized.
          this is a very good point you are hinting to. To understand such behavior we should records as well the current movement with the accelerations.
          Fred-Yundefined shmibbityundefined 2 Replies Last reply Reply Quote 0
          • Fred-Yundefined
            Fred-Y @mfs12
            @mfs12 Thanks for the response.
            Let me know if you need any kind of help to test experimental functions or alpha built, I would be happy to support.
            My printers are not used for any business purposes so they can be use for troubleshooting and even be put out of service for days.
            • shmibbityundefined
              shmibbity @mfs12
              @mfs12 I'm also interested in an autocalibration feature. Would the right way to go about it be to have the printer oscillate the print head in one dimension at a time with varying accelerations and distances and use the accelerometer data to find how much distance the frame moved as it shook? The largest displacement will indicate what the natural frequency is of the printer frame in the respective axis.
              That information could be used to dynamically adjust jerk and acceleration values of the printer before the next move takes place.
              NightLonk42undefined shmibbityundefined 2 Replies Last reply Reply Quote 0
              • NightLonk42undefined
                NightLonk42 @shmibbity
                This post is deleted!
                  NightLonk42
                  I've tried on the latest RRF beta and 3.3. It's replicated 100% every time.
                  Duet Mini 5+ Wifi
                  Toolboard V1.1
                  BL Touch (in case that matters somehow)~~
                  m122
                  RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus WiFi (standalone mode)
                  Board ID: GJRQ5-V396U-D65J0-40KM8-K013Z-7VUQA
                  Used output buffers: 3 of 40 (15 max)
                  Static ram: 102756
                  Dynamic ram: 107252 of which 28 recycled
                  Never used RAM 31676, free system stack 200 words
                  Tasks: NETWORK(ready,11.8%,253) HEAT(notifyWait,0.0%,372) Move(notifyWait,0.0%,338) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,346) TMC(notifyWait,0.7%,115) MAIN(running,85.4%,428) IDLE(ready,1.2%,29) AIN(delaying,0.8%,266), total 100.0%
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:00:19 ago, cause: software
                  Last software reset at 2021-09-13 22:57, reason: User, GCodes spinning, available RAM 31388, slot 0
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  MCU revision 3, ADC conversions started 19343, completed 19341, timed out 0, errs 0
                  Step timer max interval 750
                  MCU temperature: min 43.7, current 44.1, max 44.8
                  Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 70, reads 988, writes 12, timeouts 0, DMA errors 0
                  Driver 1: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 70, reads 988, writes 12, timeouts 0, DMA errors 0
                  Driver 2: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 70, reads 987, writes 12, timeouts 0, DMA errors 0
                  Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 70, reads 987, writes 12, timeouts 0, DMA errors 0
                  Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 70, reads 988, writes 12, timeouts 0, DMA errors 0
                  Driver 5: position 0, assumed not present
                  Driver 6: position 0, assumed not present
                  Date/time: 2021-09-13 22:58:05
                  Cache data hit count 36845245
                  Slowest loop: 3.99ms; fastest: 0.12ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 3.5ms, write time 0.0ms, max retries 0
                  DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  === AuxDDARing ===
                  Bed heaters = 0 -1, chamberHeaters = -1 -1
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty
                  === CAN ===
                  Messages queued 193, received 591, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 237, free buffers 17 (min 16), ts 97/96/0
                  Tx timeouts 0,0,0,0,0,0
                  === Network ===
                  Slowest loop: 15.35ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  - WiFi -
                  Network state is active
                  WiFi firmware version 1.26
                  WiFi MAC address f0:08:d1:02:e6:b1
                  WiFi Vcc 3.40, reset reason Power up
                  WiFi flash size 2097152, free heap 21408
                  WiFi IP address 192.168.1.29
                  WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                  Socket states: 0 4 0 0 0 0 0 0
                  How to replicate:
                  * -Install InputShaping Plugin (Currently using latest version as of 9/13/21)
                  * Start it
                  *No issues whatsoever with homing or G32 happen at this point. Everything is fine*
                  * Home Printer
                  * Run mesh compensation (G29)
                  *A Height Map is saved*
                  (The height map file is what's causing the bug for whatever reason)
                  * Reboot printer
                  *Paneldue will no longer connect and is now stuck at connecting*
                  * Try to Home Printer
                  *BL Touch will not deploy and the console throws error messages*
                  9/13/2021, 10:49:13 PM	Error: in file macro line 17: G30: Z probe 0 not found
                  Error: G0/G1: insufficient axes homed
                  9/13/2021, 10:49:11 PM	G28
                  * Delete heightmap.csv
                  * Reboot printer
                  *Everything now works as expected again*~~
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                  • gloomyandyundefined
                    gloomyandy @NightLonk42
                    @nightlonk42 Are you saying that if you do not install the input-shaper plugin (or disable it) that this problem does not happen?
                    NightLonk42undefined 1 Reply Last reply Reply Quote 0
                      shmibbity @shmibbity
                        NightLonk42 @gloomyandy
                        @gloomyandy said in InputShaping-Plugin-0.1.0-rc7 released (repacked):
                        That is correct
                        mfs12undefined 1 Reply Last reply Reply Quote 0
                        • jallen810undefined
                          jallen810
                          @fred-y @mfs12 I have to say, after using Klipper's system to "Autotune" this is bit archaic by comparison. I sure hope this will be continued to be improved upon as i think it has merit. WIthout having a huge understanding of the algorithms involved here let me take a stab at how i think your system could be improved to help the user make educated decisions on I.S. for their system.
                          1.) The Analysis graphing always defaults to displaying all 3 (X,Y,Z) axes simulataneously. This is overwhelming, the configuration dialog asks us to pick 1 axes to test, thus the accelerometer readings should only be recorded for this axis (or filtered after the fact) so as to not confuse the user.
                          2.) I have notice that my acclerometer testing file names are not being generate with the user selected (I.S. algo type, Frequency, Damping, axis desire, etc..) they simply get some random numbers & a date/time stamp... (Pic below)
                          Supposed to name:
                          Actual Name i get when CSV is saved:
                          So i have to go one-by-one, test, record, rename, update settings, repeat... very slow & frustrating simply to get my filenames correct so i can compare them....
                          3.) The analysis doesn't make any kind of recommendations for solving any of our variables.... The user must optimize 3-variables... not likely going to happen in any sort of quick situation. My recommendation would be for the system to take a standing still reading to account for environmental resonances (fans/etc...) and ignore these values when analyzing the accelerometer data. From there it should test increasing frequencies (Defined by user OR 0-150Hz F.E.) and then run that through solving for each I.S. type one-by-one to determine optimal frequency to cancel and maximum accel/decel & dampening at solved frequency...
                          This would, in effect, do exactly what Klipper I.S. does so well (and in mere minutes) but would give us a graphical representation of it simultaneously....
                          I truly hope you keep at it and make some improvements to the system, I don't want this to sound like negative because this is great work so far, it just simply isn't complete yet, if you mission is to provide the user with "turnkey" information to improve their prints. I will keep playing with this and upgrading as beta's come out.
                          Phaedruxundefined mfs12undefined 2 Replies Last reply Reply Quote 1
                            Phaedrux Moderator @jallen810
                            @jallen810 Work is still progressing.
                              A Former User @Phaedrux
                              @phaedrux said in InputShaping-Plugin-0.1.0-rc7 released (repacked):
                              Looking forward to have it!
                              • mfs12undefined
                                mfs12 @NightLonk42
                                Hey @nightlonk42,
                                thanks for your feedback. I have no clue how inputshaping plugin would interferes with the other plugins or other functionality of the printer.
                                But as this plugin is still in a very early stage, please stop using it for now. We will keep an eye on this issue.
                                • mfs12undefined
                                  mfs12 @jallen810
                                  Hey @jallen810,
                                  as @Phaedrux already stated the plugin is still in an early stage, but it will improve.
                                  From what i understand your most missing features are
                                  • displaying only the tested axis
                                  • show inputshaping configuration and test parameters for each record
                                  • get parameter recommendations
                                  • speed things up
                                  • do a completely automated calibration process
                                  • Heartleander81undefined
                                    Heartleander81
                                      Heartleander81
                                      Hi. I installed DWC 3.4b4 today.
                                      Now I want to install the plugin,
                                      but I get the message: Requirement DWC version 3.4.0-b420210927_221302.jpg 20210927_221252.jpg
                                      • mfs12undefined
                                        mfs12 @Heartleander81
                                        A new version of input plugin was released.
                                        Check https://forum.duet3d.com/topic/25306/inputshaping-plugin-0-2-0-pre3-released/1
