    Help for translation needed
    51
    2.5k
    • mfs12undefined
      mfs12
      @cosmowave @Aitor thanks for you help. I build a new version with your changed translations.
      If you like to test and provide feedback this would be appreciated.
      https://github.com/mfs12/PanelDueFirmware/releases/tag/3.4.0-pre1-translations
      Visit me on github at https://github.com/mfs12/
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @mfs12
        @mfs12 can i use this PanelDueFW with RRF 3.3?
        Or do i have to update to RRF 3.4?
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        • mfs12undefined
          mfs12
          @cosmowave it should be mostly compatible. No need to update.
          cosmowaveundefined 1 Reply Last reply Reply Quote 1
          • Aitorundefined
            Aitor @mfs12
            Good morning @mfs12,
            I'm testing the translated version and I've seen a few things
            On the one hand 5.0i and 7.0i are separated, is there a reason? what do they change?
            Also as I expected Heaters comb. in Spanish is too long, I think it will be better to leave it in English, on the other hand this same button did not work, they always remained combined.
            In the print section the text did not appear completely and this has space to appear.
            On the other hand, the button that serves to change cards is no longer displayed, unless you mount the card with M21 P1, before it served to mount the card if it was not mounted, when you removed this functionality?, it could be added again?
            Also you can see that while I was calibrating the printer the status of the due panel did not change to busy in DWC if it changed, I did not see it in the translations either.
            I will keep looking for more options to see if I can find something else.
            Best regards
            mfs12undefined 1 Reply Last reply Reply Quote 0
            • Fred-Yundefined
              Fred-Y @mfs12
              @mfs12 I thin I'm done, there is still a few sentence in English but getting a proper translation is not easy (ex. Heaters comb., feedrate...)
              I added some comments like "need context" to make sure I can provide a correct translation.
              Let me know when it's integrated to a build and I will load it into one on my printers.
                cosmowave @mfs12
                @mfs12 Please change in german in the setup page to "Heat's kombiniert" and "Heat's nicht komb."
                Sorry for the late reply!
                Edit: Sorry again, in the Status page to "Geschw.", Geschwindigkeit is to long.
                • mfs12undefined
                  mfs12
                  Hey @cosmowave,
                  already updated Heat entries. And set Tempo/Geschwindigkeit to "Speed".
                  As i also speak german 😉 I think speed is a ok-ish compromise. Geschw. is unclear, as is Tempo.
                  Thanks a lot for your help!
                  zaptaundefined 1 Reply Last reply Reply Quote 1
                  • mfs12undefined
                    mfs12
                    This is the pull request where I merge all your suggestions and correction together.
                    https://github.com/Duet3D/PanelDueFirmware/pull/139
                    mfs12 opened this pull request in Duet3D/PanelDueFirmware
                    closed Cleanup translations #139
                    • mfs12undefined
                      mfs12
                      So far we reviewed english (obviously), german, spanish and french.
                      A big thanks to all the helping hands!
                      Fred-Yundefined 1 Reply Last reply Reply Quote 1
                      • Fred-Yundefined
                        Fred-Y @mfs12
                        @mfs12 Did you included the new translations into PanelDue-3.4.0-pre2?
                        Thanks 🙂
                        • mfs12undefined
                          mfs12
                          Hey @Fred-Y, yes, translations where added. Although there was only one suggested change in french. Or did i miss something. I found just one comment.
                          And this entry got meanwhile obsolete for all languages.
                          Fred-Yundefined 1 Reply Last reply Reply Quote 0
                          • mfs12undefined
                            mfs12 @Aitor
                            @aitor
                            No, just the new build process. I thought it's nice to have explicit builds for every device. But it looks like there are going to be merged again into one image.
                            • Fred-Yundefined
                              Fred-Y @mfs12
                              @mfs12 I'm not familiar with GitHub, I added many corrections, I'm not quite sure why you didn't see them - they are all "Pending".
                              I have surely missed something 😕
                              Let me know how to fix this and I will do it asap.
                              • mfs12undefined
                                mfs12
                                @Fred-Y this is weird. never saw this "pending" status before.
                                Did you use this link?
                                https://github.com/mfs12/PanelDueFirmware/pull/2/files
                                can you share the link from where you took the screenshot?
                                mfs12 opened this pull request in mfs12/PanelDueFirmware
                                draft Review translations langs #2
                                Fred-Yundefined 2 Replies Last reply Reply Quote 0
                                • Fred-Yundefined
                                  Fred-Y @mfs12
                                  @mfs12 It's coming from the same link you posted above
                                  • Fred-Yundefined
                                    Fred-Y @mfs12
                                    @mfs12 I think I figured out!
                                    I had this button to submit my review 🙄
                                    Can you see my comments now? 🤞
                                    • mfs12undefined
                                      mfs12
                                      @Fred-Y yes, now everything appeared.
                                      It will get in with the next release.
                                      • Fred-Yundefined
                                        Fred-Y @mfs12
                                        @mfs12 Perfect!
                                        I will try to install it as soon as it is released and switch to French to make sure it looks good.
                                        • mfs12undefined
                                          mfs12
                                          @Fred-Y i commented some stuff.
                                          Status values must not be longer then 15 characters otherwise they are cut off.
                                          Please check
                                          • https://github.com/mfs12/PanelDueFirmware/pull/2
                                          And here are the actual changes i did so far.
                                          • https://github.com/Duet3D/PanelDueFirmware/pull/205/files
                                          closed Strings: updated french translation #205
                                          • RomanVinundefined
                                            RomanVin
                                            Translate.txt
                                            Translation into Russian.
