    Help for translation needed
    51
    2.5k
    • mfs12undefined
      mfs12
      So far we reviewed english (obviously), german, spanish and french.
      A big thanks to all the helping hands!
      Visit me on github at https://github.com/mfs12/
      Fred-Yundefined 1 Reply Last reply Reply Quote 1
      • Fred-Yundefined
        Fred-Y @mfs12
        @mfs12 Did you included the new translations into PanelDue-3.4.0-pre2?
        Thanks 🙂
        • mfs12undefined
          mfs12
          Hey @Fred-Y, yes, translations where added. Although there was only one suggested change in french. Or did i miss something. I found just one comment.
          And this entry got meanwhile obsolete for all languages.
          Fred-Yundefined 1 Reply Last reply Reply Quote 0
          • mfs12undefined
            mfs12 @Aitor
            @aitor
            On the one hand 5.0i and 7.0i are separated, is there a reason? what do they change?
            No, just the new build process. I thought it's nice to have explicit builds for every device. But it looks like there are going to be merged again into one image.
            • Fred-Yundefined
              Fred-Y @mfs12
              @mfs12 I'm not familiar with GitHub, I added many corrections, I'm not quite sure why you didn't see them - they are all "Pending".
              I have surely missed something 😕
              Let me know how to fix this and I will do it asap.
              • mfs12undefined
                mfs12
                @Fred-Y this is weird. never saw this "pending" status before.
                Did you use this link?
                https://github.com/mfs12/PanelDueFirmware/pull/2/files
                can you share the link from where you took the screenshot?
                mfs12 opened this pull request in mfs12/PanelDueFirmware
                draft Review translations langs #2
                Fred-Yundefined 2 Replies Last reply Reply Quote 0
                • Fred-Yundefined
                  Fred-Y @mfs12
                  @mfs12 It's coming from the same link you posted above
                  • Fred-Yundefined
                    Fred-Y @mfs12
                    @mfs12 I think I figured out!
                    I had this button to submit my review 🙄
                    Can you see my comments now? 🤞
                    • mfs12undefined
                      mfs12
                      @Fred-Y yes, now everything appeared.
                      It will get in with the next release.
                      • Fred-Yundefined
                        Fred-Y @mfs12
                        @mfs12 Perfect!
                        I will try to install it as soon as it is released and switch to French to make sure it looks good.
                        • mfs12undefined
                          mfs12
                          @Fred-Y i commented some stuff.
                          Status values must not be longer then 15 characters otherwise they are cut off.
                          Please check
                          • https://github.com/mfs12/PanelDueFirmware/pull/2
                          And here are the actual changes i did so far.
                          • https://github.com/Duet3D/PanelDueFirmware/pull/205/files
                          mfs12 opened this pull request in Duet3D/PanelDueFirmware
                          closed Strings: updated french translation #205
                          • RomanVinundefined
                            RomanVin
                            Translate.txt
                            Translation into Russian.
                            mfs12undefined 1 Reply Last reply Reply Quote 0
                            • mfs12undefined
                              mfs12 @RomanVin
                              Hey @romanvin, it would be helpful to comment on the changes at github. Otherwise managing all the changes will be pretty hard.
                              Please check
                              https://github.com/mfs12/PanelDueFirmware/pull/2#issuecomment-909913840
                              • Fred-Yundefined
                                Fred-Y @mfs12
                                @mfs12 I adjusted the status, they should all be 15 chr or less.
                                Let me know if I missed something
                                • mfs12undefined
                                  mfs12
                                  @RomanVin thanks for your help!
                                  I created a pull request with most of you changes. I two changes i didn't take because they were too long.
                                  If you want to have a last look on the changes feel free to comment in the pull request.
                                  https://github.com/Duet3D/PanelDueFirmware/pull/209/
                                  closed Strings: updated russian translation #209
                                  • zaptaundefined
                                    zapta @mfs12
                                    @mfs12, do you use an online service to manage the collaborative translation? They can be very handy. E.g https://crowdin.com/page/open-source-project-setup-request
                                    • mfs12undefined
                                      mfs12
                                      Hey @zapta, no, i didn't think of that when i started the task. But realized things like this exist. So far we are using github pull request to check translations. In the end i am updating the sources manually. Not ideal but so far only small portions need to be replaced.
                                      Recently i also stumbled over weblate which sounds also interesting.
                                      https://hosted.weblate.org/about/
                                      • Vladimir_Uundefined
                                        Vladimir_U
                                        Hi. I can also help with translation into Russian.
                                        • mfs12undefined
                                          mfs12 @Vladimir_U
                                          @vladimir_u said in Help for translation needed:
                                          Thank you, but Russian is already done. But testing the next release would be helpful as well.
                                          • Fred-Yundefined
                                            Fred-Y
                                            @mfs12 I just installed the 3.4.0-pre3 to check the French translation, how/where do you want the adjustment to be submitted?
                                            I've seen a few details I would like to correct if possible.
