    Help for translation needed
    51
    2.5k
    • mfs12undefined
      mfs12
      Hey @cosmowave,
      already updated Heat entries. And set Tempo/Geschwindigkeit to "Speed".
      As i also speak german 😉 I think speed is a ok-ish compromise. Geschw. is unclear, as is Tempo.
      Thanks a lot for your help!
      Visit me on github at https://github.com/mfs12/
      zaptaundefined 1 Reply Last reply Reply Quote 1
      • mfs12undefined
        mfs12
        This is the pull request where I merge all your suggestions and correction together.
        https://github.com/Duet3D/PanelDueFirmware/pull/139
        mfs12 opened this pull request in Duet3D/PanelDueFirmware
        closed Cleanup translations #139
        • mfs12undefined
          mfs12
          So far we reviewed english (obviously), german, spanish and french.
          A big thanks to all the helping hands!
          Fred-Yundefined 1 Reply Last reply Reply Quote 1
          • Fred-Yundefined
            Fred-Y @mfs12
            @mfs12 Did you included the new translations into PanelDue-3.4.0-pre2?
            Thanks 🙂
            • mfs12undefined
              mfs12
              Hey @Fred-Y, yes, translations where added. Although there was only one suggested change in french. Or did i miss something. I found just one comment.
              And this entry got meanwhile obsolete for all languages.
              Fred-Yundefined 1 Reply Last reply Reply Quote 0
              • mfs12undefined
                mfs12 @Aitor
                @aitor
                On the one hand 5.0i and 7.0i are separated, is there a reason? what do they change?
                No, just the new build process. I thought it's nice to have explicit builds for every device. But it looks like there are going to be merged again into one image.
                • Fred-Yundefined
                  Fred-Y @mfs12
                  @mfs12 I'm not familiar with GitHub, I added many corrections, I'm not quite sure why you didn't see them - they are all "Pending".
                  I have surely missed something 😕
                  Let me know how to fix this and I will do it asap.
                  • mfs12undefined
                    mfs12
                    @Fred-Y this is weird. never saw this "pending" status before.
                    Did you use this link?
                    https://github.com/mfs12/PanelDueFirmware/pull/2/files
                    can you share the link from where you took the screenshot?
                    mfs12 opened this pull request in mfs12/PanelDueFirmware
                    draft Review translations langs #2
                    Fred-Yundefined 2 Replies Last reply Reply Quote 0
                    • Fred-Yundefined
                      Fred-Y @mfs12
                      @mfs12 It's coming from the same link you posted above
                      • Fred-Yundefined
                        Fred-Y @mfs12
                        @mfs12 I think I figured out!
                        I had this button to submit my review 🙄
                        Can you see my comments now? 🤞
                        • mfs12undefined
                          mfs12
                          @Fred-Y yes, now everything appeared.
                          It will get in with the next release.
                          • Fred-Yundefined
                            Fred-Y @mfs12
                            @mfs12 Perfect!
                            I will try to install it as soon as it is released and switch to French to make sure it looks good.
                            • mfs12undefined
                              mfs12
                              @Fred-Y i commented some stuff.
                              Status values must not be longer then 15 characters otherwise they are cut off.
                              Please check
                              • https://github.com/mfs12/PanelDueFirmware/pull/2
                              And here are the actual changes i did so far.
                              • https://github.com/Duet3D/PanelDueFirmware/pull/205/files
                              closed Strings: updated french translation #205
                              • RomanVinundefined
                                RomanVin
                                Translate.txt
                                Translation into Russian.
                                mfs12undefined 1 Reply Last reply Reply Quote 0
                                • mfs12undefined
                                  mfs12 @RomanVin
                                  Hey @romanvin, it would be helpful to comment on the changes at github. Otherwise managing all the changes will be pretty hard.
                                  Please check
                                  https://github.com/mfs12/PanelDueFirmware/pull/2#issuecomment-909913840
                                  • Fred-Yundefined
                                    Fred-Y @mfs12
                                    @mfs12 I adjusted the status, they should all be 15 chr or less.
                                    Let me know if I missed something
                                    • mfs12undefined
                                      mfs12
                                      @RomanVin thanks for your help!
                                      I created a pull request with most of you changes. I two changes i didn't take because they were too long.
                                      If you want to have a last look on the changes feel free to comment in the pull request.
                                      https://github.com/Duet3D/PanelDueFirmware/pull/209/
                                      closed Strings: updated russian translation #209
                                      • zaptaundefined
                                        zapta @mfs12
                                        @mfs12, do you use an online service to manage the collaborative translation? They can be very handy. E.g https://crowdin.com/page/open-source-project-setup-request
                                        • mfs12undefined
                                          mfs12
                                          Hey @zapta, no, i didn't think of that when i started the task. But realized things like this exist. So far we are using github pull request to check translations. In the end i am updating the sources manually. Not ideal but so far only small portions need to be replaced.
                                          Recently i also stumbled over weblate which sounds also interesting.
                                          https://hosted.weblate.org/about/
                                          • Vladimir_Uundefined
                                            Vladimir_U
                                            Hi. I can also help with translation into Russian.
