Error Short to Ground reported by driver(s)
57
3.7k
    davidewen
    After many hours of prints, I was presented with "Error Short to Ground reported by driver(s)3"
    Drive3 is my extruder.
    Extruder is a Bondtech DDX3
    I checked wiring
    I also used a different stepper with the same result
    I moved the connection to Drive4, problem solved.
    This leads me to believe Drive3 is faulty.
    undefined 1 Reply Last reply 25 Sept 2021, 14:13 Reply Quote 0
      droftarts administrators
      @davidewen Please post your config.g and the response to M122. Please also post a good, in focus picture of the Duet board around the area of the stepper drivers (to see if there's any obvious IC failures). For a warranty replacement, we need to know when and where you purchase the Duet. For warranty terms, see https://www.duet3d.com/warranty
        davidewen
        @droftarts
        config.g
        After running M122, I'm attempting to download log files from console, but nothing happens.
        So here is a copy/paste
        9/24/2021, 8:53:59 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:55 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:50 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:46 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:41 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:37 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:32 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:28 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:23 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:19 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:14 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:10 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:05 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:53:01 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:56 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:52 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:47 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:43 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:38 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:34 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:29 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:25 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:20 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:16 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:11 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:07 AM Error: short-to-ground reported by driver(s) 3
        9/24/2021, 8:52:04 AM M122
        RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: F4835-L296U-D65J0-40KML-JK03Z-HP6R5
        Used output buffers: 3 of 40 (13 max)
        Static ram: 102724
        Dynamic ram: 110268 of which 40 recycled
        Never used RAM 27816, free system stack 120 words
        Tasks: NETWORK(ready,47.0%,240) HEAT(notifyWait,0.1%,366) Move(notifyWait,0.2%,284) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,357) CanClock(delaying,0.0%,340) TMC(notifyWait,2.1%,114) MAIN(running,47.8%,408) IDLE(ready,0.0%,29) AIN(delaying,2.7%,273), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 02:21:07 ago, cause: software
        Last software reset at 2021-09-24 06:30, reason: User, GCodes spinning, available RAM 30672, slot 1
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        MCU revision 3, ADC conversions started 8467337, completed 8467337, timed out 0, errs 0
        Step timer max interval 1488
        MCU temperature: min 43.9, current 47.4, max 52.9
        Supply voltage: min 23.1, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/32/32, gc cycles 0
        Driver 0: position 0, standstill, SG min/max 0/110, read errors 0, write errors 1, ifcnt 25, reads 52386, writes 14, timeouts 0, DMA errors 0
        Driver 1: position 0, standstill, SG min/max 0/86, read errors 0, write errors 1, ifcnt 24, reads 52386, writes 14, timeouts 0, DMA errors 0
        Driver 2: position 2071, standstill, SG min/max 0/56, read errors 0, write errors 1, ifcnt 24, reads 52385, writes 14, timeouts 0, DMA errors 0
        Driver 3: position 0, short-to-ground, standstill, SG min/max 0/224, read errors 0, write errors 1, ifcnt 29, reads 52383, writes 16, timeouts 0, DMA errors 0
        Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 52391, writes 9, timeouts 0, DMA errors 0
        Driver 5: position 0, assumed not present
        Driver 6: position 0, assumed not present
        Date/time: 2021-09-24 08:52:04
        Slowest loop: 78.83ms; fastest: 0.07ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 4.3ms, write time 2.5ms, max retries 0
        DMs created 83, maxWait 3310924ms, bed compensation in use: mesh, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 415, completed moves 415, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 9], CDDA state -1
        === AuxDDARing ===
        Bed heaters = 0 -1, chamberHeaters = -1 -1
        Heater 0 is on, I-accum = 0.3
        Heater 1 is on, I-accum = 0.3
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === CAN ===
        Messages queued 76439, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 42337/0/0
        Tx timeouts 0,233,42336,0,0,33867 last cancelled message type 30 dest 127
        === Network ===
        Slowest loop: 85.33ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.26
          WiFi MAC address f0:08:d1:02:e8:4f
          WiFi Vcc 3.31, reset reason Power up
          WiFi flash size 2097152, free heap 24312
          WiFi IP address 192.168.16.220
          WiFi signal strength -50dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          9/24/2021, 8:52:03 AM Error: short-to-ground reported by driver(s) 3
          9/24/2021, 8:51:58 AM Error: short-to-ground reported by driver(s) 3
          9/24/2021, 8:51:54 AM Error: short-to-ground reported by driver(s) 3
          9/24/2021, 8:51:49 AM Error: short-to-ground reported by driver(s) 3
          9/24/2021, 8:51:45 AM Error: short-to-ground reported by driver(s) 3
          9/24/2021, 8:51:40 AM Error: short-to-ground reported by driver(s) 3
          9/24/2021, 8:51:36 AM Error: short-to-ground reported by driver(s) 3
          9/24/2021, 8:51:31 AM Error: short-to-ground reported by driver(s) 3
          dc42 administrators @davidewen
          @davidewen with power off please unplug the motor from driver 3, then power up, command driver 3 to move and see if you get the same error message.
          Also check that there is nothing conductive under the board that it could be shorting against.
          undefined 2 Replies Last reply 26 Sept 2021, 13:24 Reply Quote 0
            davidewen @dc42
            I have a couple large / long print jobs that need to be completed. Customers are waiting for product, so I will not be able to do this until sometime late next week.
            There is nothing conductive under the board. It is elevated off the Ender 6 mounts by a 3D printed PETG spacer.
              davidewen @dc42
              @dc42 said in Error Short to Ground reported by driver(s):
              I would to make a note for us to refer back to should it be needed.
              After the 1st failure of D3, I moved the Extruder to D4 with no problems since.
              When @droftarts sent the 1st request for info on 9/17, I reconnected the Extruder to D3 and revised my config.g to match.
              I was able to run for about 20-30 minutes before the error "short to ground" was reported.
              I suspect this will be the same when I move the extruder back to D3 again.
              I don't think it will do any good if D3 is not reporting the error, so I'm suspecting that you will want me to run it until the error shows up, then run the test you requested?
              Please confirm.
              David
              undefined 1 Reply Last reply 27 Sept 2021, 17:59 Reply Quote 0
                @davidewen if RRF reports an intermittent "short to ground" message, then normally either there is a genuine intermittent short in the wiring, or the message is caused by running the driver in stealthChop mode and you are trying to move the motor too fast (this is a behaviour documented by Trinamic). Are you running that driver in stealthChop mode at high speeds?
                If the message is caused by a driver failure, then normally the error occurs immediately you try to move the motor.
                undefined 3 Replies Last reply 28 Sept 2021, 16:31 Reply Quote 0
                  davidewen @dc42
                  As far as I know, I am not running in stealth/chop mode.
                  Is there some way I can test / confirm that?
                  As far as a short in the wiring.
                  Why would I get the error only for D3 and not on D4?
                  David
                    davidewen @dc42
                    Any update to this case yet?
                    Thanks,
                    David
                      davidewen @dc42
                      Have you had the opportunity to look over my last post from Sept 28?
                      Are there any other questions or tests you want me to run or can I get a RMA for a replacement board?
                      @davidewen said in Error Short to Ground reported by driver(s):
                      David
                      undefined 1 Reply Last reply 1 Oct 2021, 13:45 Reply Quote 0
                        @davidewen we will replace the Duet. Please email warranty@duet3d.com and include a link to this thread.
                        undefined 2 Replies Last reply 1 Oct 2021, 22:19 Reply Quote 0
                          davidewen @dc42
                          Thank you.
                          I have sent an email as requested.
                          David
                            davidewen @dc42
                            I received the replacement board.
                            Swapped old board with new board.
                            Put SD card from old board into new board.
                            Could not connect via Wi-Fi.
                            Took new board out.
                            Put SD card that came with new board back in.
                            Connected USB to Mac. (macOS 11.6.1 with M1 chip)
                            Could not detect board
                            Followed "Fallback 1 & Fallback 2" instructions @ https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                            Neither worked.
                            Still can not connect to board via USB
                            Board does not show up in System Information, or in Terminal via ls /dev/tty.*.
                            Any suggestions?
                            Thanks,
                            David
                            T3P3Tonyundefined 1 Reply Last reply 9 Nov 2021, 08:32 Reply Quote 0
                              T3P3Tony administrators @davidewen
                              @davidewen with nothing other than the power plugged inot the board, what LEDS are lit? also please send a picture of the board.
                              undefined 1 Reply Last reply 9 Nov 2021, 16:24 Reply Quote 0
                                davidewen @T3P3Tony
                                @t3p3tony
                                R40 = off
                                R49 = flashing red (slow flash)
                                R28 = off
                                R27 = off
                                R29 = Red
                                P30 = Green
                                ESP = off
                                undefined T3P3Tonyundefined 2 Replies Last reply 10 Nov 2021, 21:27 Reply Quote 0
                                  elmoret @davidewen
                                  @T3P3Tony Could you assist David, please?
                                    @davidewen with it setup as you have it in the image above, please double click the reset button and see if a Duetboot drive becomes available on the PC over USB. If it does then you can drop the 3.3 firmware for mini 5+ into that drive, it will.opy across then install. After that it should be available over YAT.
                                    Firmware is here:
                                    Duet3Firmware_Mini5plus.uf2
                                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet3Firmware_Mini5plus.uf2
                                    undefined 1 Reply Last reply 11 Nov 2021, 14:23 Reply Quote 0
                                      davidewen @T3P3Tony
                                      @t3p3tony
                                      Tony, as mentioned in a previous post.
                                      I have followed all instructions for Fallback 1 & 2 per the guide.
                                      Neither work. Board is not found on computer under System Information, via Terminal or Disk Utility.
                                      Neither worked.
                                      Results from Terminal
                                      @Macmini-M1 ~ % ls /dev/tty..
                                      zsh: no matches found: /dev/tty.
                                      Results from System Information.
                                      This is what shows up when board is plugged in.
                                      Results from Disk Utility
                                      I do get a "DuetBOOT" after double clicking the reset button, and copying the firmware to the drive does cause a restart, but then I'm back to square 1.
                                      No Duet in System Info or Terminal.
                                      Even with a good copy of sys folder files, no Duet on my WiFi.
                                      T3P3Tonyundefined 1 Reply Last reply 13 Nov 2021, 12:00 Reply Quote 0
                                        @davidewen if DuetBoot shows up and the file is transferred successfully then at least part of the USB system is working as expected. I don't have a Mac to test this on - there might be some interaction between the USB driver in that particular version of MacOS/Mac hardware and the Duet. Or it might be a (partially) faulty USB hardware on the Duet.
                                        Would it be possible to try connecting on a PC/laptop running windows?
                                          davidewen
                                          @t3p3tony
                                          I don't have a Windows computer. I do run Windows in Parallels and/or Bootcamp, but still on a Mac computer.
                                          I've tested the connection on the new M1 macMini and an older Intel based MacBookPro_2017. Same issue on both.
                                          I attempted to connect via Parallels.
                                          Did not work.
                                          Could not update the device drivers.
                                          T3P3Tonyundefined 1 Reply Last reply 14 Nov 2021, 12:25 Reply Quote 0
