    Duet3D 1HCL - Closed Loop Controller Beta test
    Hardware dev
    20
    209
    20.4k
    • supertb1undefined
      supertb1 @lirwin17
      @lirwin17 said in Duet3D 1HCL - Closed Loop Controller Beta test:
      M98 P"config.g"
      before change to P50.0
      9/21/2021, 7:10:36 AM Error: Response timeout: CAN addr 51, req type 6045, RID=27
      Pulse-type filament monitor on pin io5.in, enabled, sensitivity 7.000mm/pulse, allowed movement 55% to 150%, check every 22.0mm, no data received
      Error: bad model parameters
      9/21/2021, 7:10:35 AM Error: Response timeout: CAN addr 51, req type 6043, RID=25
      9/21/2021, 7:10:34 AM Error: Response timeout: CAN addr 51, req type 6042, RID=23
      9/21/2021, 7:10:33 AM Error: Response timeout: CAN addr 51, req type 6042, RID=21
      9/21/2021, 7:10:32 AM Error: Response timeout: CAN addr 51, req type 6042, RID=19
      9/21/2021, 7:10:31 AM Error: Response timeout: CAN addr 51, req type 6018, RID=17
      9/21/2021, 7:10:30 AM Error: Response timeout: CAN addr 51, req type 6041, RID=15
      Error: No encoder specified for closed loop drive mode
      9/21/2021, 7:10:29 AM Error: Error threshold value must be greater than zero.
      supertb1undefined 1 Reply Last reply Reply Quote 0
      • supertb1undefined
        supertb1 @supertb1
        @supertb1 I have P51.0 disconnected at the moment as advised
        • MaxGyverundefined
          MaxGyver @lirwin17
          Short update:
          I am on my third print with the closed loop drivers and so far they are working quite well. The axes are sticking to their position very well. I really have to apply a lot of force to push them off course, and they will snap right back. 👏
          I am printing with up to 300mm/s and was able to increase my acceleration and jerk significantly. On the downside I had to limit my max. speeds to 20000mm/min or 300mm/s.
          @lirwin17 I have two motors on my Y axis. They are both wired to one 1HCL board, but only one has an encoder. It calibrates fine, and I did not spot a significant problem during printing. Only the recorded graphs were of no use on this axis (at least for me). Maybe something to keep in mind for future development.(especially for autotuning. 😉 )
          Furthermore, I have the impression that the drivers run in full step without any microstepping as soon as I switch to closed loop. It sounds very much like my very first printer. 😁 The prints also show a strong stepping pattern.
          Cheers Max
          lirwin17undefined supertb1undefined 2 Replies Last reply Reply Quote 0
          • supertb1undefined
            supertb1 @lirwin17
            @lirwin17
            After change to P50.0
            9/21/2021, 7:14:52 AM Error: Response timeout: CAN addr 51, req type 6043, RID=25
            9/21/2021, 7:14:51 AM Error: Response timeout: CAN addr 51, req type 6042, RID=23
            9/21/2021, 7:14:50 AM Error: Response timeout: CAN addr 51, req type 6042, RID=21
            9/21/2021, 7:14:49 AM Error: Response timeout: CAN addr 51, req type 6042, RID=19
            9/21/2021, 7:14:48 AM Error: Response timeout: CAN addr 51, req type 6018, RID=17
            9/21/2021, 7:14:47 AM Error: Response timeout: CAN addr 51, req type 6041, RID=15
            9/21/2021, 7:14:43 AM M98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Again channel 51 is disconnected
            • supertb1undefined
              supertb1 @T3P3Tony
              @t3p3tony
              G4 S3 ;wait for expansion boards to start
              M569.1 P50.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 50 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
              M569.M51 P51.0 S1 T2 C20 E20 R100 I0 D0 ; Configure the 1HCL board at CAN address 51 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
              M569 P50.0 D4 S1 ; Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) X axis
              M569 P51.0 D2 S1 ; Configure the motor on the 1HCL at can address 51 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) Y axis
              M569 P0.0 S1 ; physical drive 0.0 goes forwards Z 1-2 axis
                T3P3Tony administrators @supertb1
                @supertb1 sorry I should have been clearer. After start up send the following from the console:
                M569 P50.0 D4 S1
                M569.6 P50.0 V31
                • supertb1undefined
                  supertb1 @lirwin17
                  @lirwin17
                  since the change on the M569.1 line to P50.0 T2 C5 E5:10
                  I am now getting closed loop enabled : yes
                  on P50 V8 it is saying that the drive has an incorrect polarity
                  V32 made the drive run off to the end of it's travel
                  M569.6 P50.0 V64
                  Warning: No new tuning errors have been found, but some existing tuning errors exist. The drive has not been zeroed. The drive has not had it's polarity checked. The drive has not had it's control checked. The encoder has not had it's count per revolution and V128 is the same result
                  • supertb1undefined
                    supertb1 @T3P3Tony
                    @t3p3tony said in Duet3D 1HCL - Closed Loop Controller Beta test:
                    M569.6 P50.0 V31
                    M569.6 P50.0 V31
                    Warning: M569.6: One or more tuning errors occurred. The drive has been found to have an incorrect polarity.
                    • supertb1undefined
                      supertb1 @T3P3Tony
                      @t3p3tony does this mean that I need to switch the positive and negative wires?
                        @supertb1 try the following:
                        M569 P50.0 D4 S0
                        Sorry that was wrong. I forgot you have the motor moving the correct way in open loop mode.
                        @lirwin17 is the polarity error an encoder polarity? in which case switching A and B phases of the encoder would be right?
                        • lirwin17undefined
                          lirwin17
                          @supertb1
                          Sorry, this error message is a bit misleading - I'll change that. The polarity should be detected automatically, so a better error message may be "encoder polarity failed to be detected"
                          Please could you follow the same instructions I gave to maxgyver above (here), although on the 'movement' checkboxes down the right hand side, please could you check 'polarity detection'
                          We should then be able to take a look at the graph and see what's going on 🙂
                          supertb1undefined 4 Replies Last reply Reply Quote 0
                          • supertb1undefined
                            supertb1 @lirwin17
                            @lirwin17 50_2021-09-21_15.04.43.csv
                            lirwin17undefined 1 Reply Last reply Reply Quote 0
                            • supertb1undefined
                              supertb1 @lirwin17
                              @lirwin17 is there another report with different variables I need to run for more information?
                              • supertb1undefined
                                supertb1 @lirwin17
                                @lirwin17 50_2021-09-21_15.57.09.csv
                                • supertb1undefined
                                  supertb1 @lirwin17
                                  @lirwin17 I'm not sure how to read these... it looks like coil A is out of step phase and coil B doesn't appear to be doing anything... target motor steps says there are 4 errors
                                  • lirwin17undefined
                                    lirwin17 @supertb1
                                    @supertb1
                                    No, this is great 👍
                                    There's docs coming soon, but for now I'll talk you through it
                                    The first thing to say is that the raw encoder reading is 0 on both recordings - this means it doesn't seem to register the encoder as moving at all.
                                    This is strange because I thought that you did M122 twice after manually turning a full rotation and the encoder's reading changed... Please could you confirm this is still the case
                                    (See this post for more detailed information)
                                    supertb1undefined 3 Replies Last reply Reply Quote 0
                                    • lirwin17undefined
                                      lirwin17 @MaxGyver
                                      @maxgyver thank you for the update! Don't worry, I've not forgotten about increasing the max speed - it's actually next on my list!
                                      Excellent that's what we like to hear 🎉
                                      Hmm okay 🤔 do you mean that both motors are wired into the single driver output on the 1HCL? What exactly were the issues you were having with the recorded graph?
                                      This is an interesting one haha - so with closed loop, we kinda lose all sense of microstepping, since the motors no longer move in discrete steps, but move as close to continuously as possible. This means that in theory, the microstepping is infinite... but the keyword here is 'continuously as possible', in reality the motor has to move some discrete distance per PID iteration, and this is a function of the frequency of the PID loop (constant) and the speed of the move (variable). If you do a very slow move, I'd expect you to be getting very small discrete moves per PID cycle (the equivalent of very high mocrostepping), whereas if we're pushing the boundary on how fast we can move, you'll get very large discrete moves per PID cycle (up to a full step).
                                      You can actually measure the size of these discrete steps by taking a recording (with speed set to 'as fast as possible') and looking at the step phase variable, and the vertical distance between datapoints. A distance of 90 degrees means 1 step, you could work out an 'effective microstepping' from this, since you know the increments in which the motor moves.
                                      The good news is though, as we increase the maximum speed, the 'effective microstepping' will also increase as well, so hopefully you'll see less of the stepping pattern as we do so 🙂
                                      • supertb1undefined
                                        supertb1 @lirwin17
                                        @lirwin17 M122 B50
                                        Diagnostics for board 50:
                                        Duet EXP1HCL firmware version 3.4.0beta3+1 (2021-09-14 15:07:31)
                                        Bootloader ID: SAME5x bootloader version 2.4beta (2021-07-23)
                                        Never used RAM 51472, free system stack 2592 words
                                        Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,95) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,81) CanClock(notifyWait,0.0%,72) TMC(notifyWait,38.1%,344) CLSend(notifyWait,0.0%,148) CLData(notifyWait,0.0%,142) MAIN(running,59.9%,408) IDLE(ready,0.0%,39) AIN(notifyWait,2.0%,265), total 100.0%
                                        Last reset 00:01:25 ago, cause: power up
                                        Last software reset time unknown, reason: HardFault bfarValid precise, available RAM 51580, slot 2
                                        Software reset code 0x0060 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00430803 BFAR 0x20030008 SP 0x2001eba8 Task MAIN Freestk 531 ok
                                        Stack: 00000000 00000000 00000002 20030000 00030f39 0001b8f9 0001ea4c 41000000 bf800000 00000000 533c0605 04001200 a8888700 06420000 c2010829 19a21029 50708239 5d000040 2a60041c 54540122 04801201 41200000 41c27924 4142a3fe 20000010 0002699b 00000002
                                        Closed loop enabled: yes, live status: 0x4, encoder type rotaryQuadrature, pre-error threshold: 5.000000, error threshold: 10.000000, reverse polarity: no, tuning: 0, tuning error: 0x1f, position 0, raw count = 0, collecting data: no, ultimateGain=0.000000, oscillationPeriod=0.000000, Control loop runtime (ms): min=0.000000, max=0.066667, avg=0.008000, Control loop frequency (Hz): min=7075.472168, max=18292.683594, avg=15625.000977
                                        Driver 0: pos 0, 106.5 steps/mm, standstill, reads 8610, writesMoves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                        Peak sync jitter -4/3, peak Rx sync delay 179, resyncs 0/0, no step interrupt scheduled
                                        VIN: 24.3V, V12: 12.2V
                                        MCU temperature: min 23.1C, current 25.4C, max 25.4C
                                        Ticks since heat task active 157, ADC conversions started 84048, completed 84047, timed out 0, errs 0
                                        Last sensors broadcast 0x00000000 found 0 162 ticks ago, loop time 0
                                        CAN messages queued 728, send timeouts 0, received 744, lost 0, free buffers 37, min 37, error reg 0
                                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                        Disconnected the motor coils and turn the motor by hand one full revolution by hand:
                                        M122 B50
                                        Never used RAM 51472, free system stack 2580 words
                                        Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,95) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,81) CanClock(notifyWait,0.0%,72) TMC(notifyWait,38.4%,344) CLSend(notifyWait,0.0%,148) CLData(notifyWait,0.0%,142) MAIN(running,59.6%,380) IDLE(ready,0.0%,39) AIN(notifyWait,2.0%,265), total 100.0%
                                        Last reset 00:05:31 ago, cause: power up
                                        Closed loop enabled: yes, live status: 0x4, encoder type rotaryQuadrature, pre-error threshold: 5.000000, error threshold: 10.000000, reverse polarity: no, tuning: 0, tuning error: 0x1f, position 4055, raw count = 4055, collecting data: no, ultimateGain=0.000000, oscillationPeriod=0.000000, Control loop runtime (ms): min=0.006667, max=0.086667, avg=0.008000, Control loop frequency (Hz): min=6756.756836, max=16304.347656, avg=15625.000977
                                        Driver 0: pos 0, 106.5 steps/mm, standstill, reads 0, wriMoves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                        Peak sync jitter -3/4, peak Rx sync delay 183, resyncs 0/0, no step interrupt scheduled
                                        MCU temperature: min 23.1C, current 26.3C, max 26.5C
                                        Ticks since heat task active 205, ADC conversions started 324949, completed 324948, timed out 0, errs 0
                                        Last sensors broadcast 0x00000000 found 0 210 ticks ago, loop time 0
                                        CAN messages queued 2005, send timeouts 0, received 2218, lost 0, free buffers 37, min 37, error reg 0
                                        • supertb1undefined
                                          supertb1 @lirwin17
                                          @lirwin17 it is reading the encoder... raw count 4055 from zero.. .and it is a 4000 count encoder
                                          • supertb1undefined
                                            supertb1 @lirwin17
                                            @lirwin17 what would be the next step to trouble shoot
