    Support for ADXL345 for measuring Resonances
    Firmware wishlist
    8
    9
    2.0k
    • PCRundefined
      PCR
      Dont know if its more hardware or software, but i like the concept of this:
      https://www.klipper3d.org/Measuring_Resonances.html
      Would be a nice addition to a toolboard or for the smart effector. See the link;)
      Best
      1 Reply Last reply Reply Quote 4
      • PCRundefined
        PCR
        More Info
        https://youtu.be/Q4OGfAHRnhY
        • Vetiundefined
          Veti
          first we need support for independent daa x and y adjustment and second harmonics filtering.
            dc42 administrators @Veti
            @Veti said in Support for ADXL345 for measuring Resonances:
            The existing algorithm already handles the second harmonic.
            Independent DAA adjustment would be possible for travel moves (as long as you are not fussy about the exact path taken during the travel move) but not in general for printing moves. However, I am looking to implement more general input shaping in RRF in Q1 next year.
            • arhiundefined
              arhi
              nice video about vibration and belt tension using this klipper feature
              https://youtu.be/M8I7W6fVTQg
              • slazundefined
                slaz
                Anything moving about this? Would really like something like this. Thanks and much appreciated
                sebkritikelundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                • sebkritikelundefined
                  sebkritikel @slaz
                  @slaz said in Support for ADXL345 for measuring Resonances:
                  Doesn’t use the ADXL345 but instead a LIS3DH. May be newer threads regarding the input shaping implementation but…
                  https://forum.duet3d.com/topic/24116/rrf-3-4-input-shaping-preview-available
                  Large(ish?) IDEX - 6HC, 1HCL
                  Stratasys Dimension 1200es to 6HC Conversion
                    droftarts administrators @slaz
                    @slaz See https://duet3d.dozuki.com/Wiki/Accelerometers
                    • DatEarlundefined
                      DatEarl
                      I would also appreciate support for the ADXL345.
