Question: Best settings for maximum torque of stepper motor
I am running a clay printer with a Duet 2 Wifi and occasionally, my extruder motor would miss a few (micro-)steps because the extruder screw has to push high-viscosity material through the nozzle and work under high pressure.
What are your thoughts on getting the maximum torque out of my extruder motor?
Of course the torque curve (torque/speed) is what matters most, also the motor current. But are there any other settings I should be aware of?
I have also experimented with different micro-stepping settings, and it appears E16 would give me the best results so far.
Any thoughts will be appreciated. Thank you.
M92 X100.00 Y100.00 Z1600.00 E100:5000.00 ; set steps per mm M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M566 X500.00 Y500.00 Z20.00 E1000.00:500.00 ; set maximum instantaneous speed changes (mm/min) M203 X5000.00 Y5000.00 Z1000.00 E6000.00:400.00 ; set maximum speeds (mm/min) M201 X300.00 Y300.00 Z500.00 E250.00:500.00 ; set accelerations (mm/s^2) M906 X1200 Y1200 Z1000 E2750:2000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; set idle timeout -
@wieman01 Using the highes possible motor voltage helps. I'd also avoid stealthChop, (bad experience with earlier drivers on a different controller)
High Torque steppers usually have a higher inductance. Picking the right stepper can make a huge difference. -
@o_lampe said in Question: Best settings for maximum torque of stepper motor:
stealthChop
Thank you.
I did not mention I am using a Duet 2 with a TMC2660 driver, so Stealthchop is not supported anyway.
As for the stepper, yes, I will try another geared stepper, but was wondering if anything can be done here with a little tweaking.
@wieman01 have you looked at the EMF calculator? https://www.reprapfirmware.org/emf.html
@jay_s_uk said in Question: Best settings for maximum torque of stepper motor:
Yes, I have seen it, but I think the graph I have attached shows the same thing. The supplier provides it and I have taken the relevant range (up to 200 RPM) into account.
@wieman01 the graph you posted should be for a particular driver voltage. What voltage was quoted?
@dc42 said in Question: Best settings for maximum torque of stepper motor:
Yes, this is for 24v. I am using a 24v PSU in combination with a Duet 2. -
Oh, I see my error now I think. The Duet pins I am connecting this stepper to only supply 5v. You're right.
Would it work if I connected the phase to the 24v VIN instead? Hope this is making sense.
The graph is for 24v.
@wieman01 said in Question: Best settings for maximum torque of stepper motor:
The stepper motor outputs provide up to almost VIN voltage, so 24V if you are providing 24V VIN.
Thank you, yes, I see that now. Also it would not make much sense if they did not.
If nothing else works, I will try another (geared) stepper for that purpose.
@wieman01 what's the rated current of the stepper motor, and what motor current have you set?
I am currently running it at 2.5A. The rated current is 3.0A per phase.
@wieman01, can you improve the properties of the clay? E.g add water?
@zapta said in Question: Best settings for maximum torque of stepper motor:
Yes, you're right, in principle that is an option, however, in our case the viscosity of the material we are using cannot be changed for various reasons I won't bother you with.I have order a geared stepper, let's see if that works out for us.
