    Duet 2 wifi Error: Cannot initialise SD card 0: Card is unusable
    507
      droftarts administrators @tisdai
      @tisdai can’t really see from this angle, need a picture from behind the socket. It’s possible the top right (in your picture) SD card socket pin is not connected.
      tisdaiundefined 1 Reply Last reply Reply Quote 0
      • tisdaiundefined
        tisdai @droftarts
        @droftarts Sorry having a problem trying to get it to zoom in using my phone, duet wifi.jpg duet wifi 2.JPG
          T3P3Tony administrators @tisdai
          @tisdai what error are you getting with the card not recognised?
          • tisdaiundefined
            tisdai @T3P3Tony
            @t3p3tony With the M39 command I get " Error: No SD card mounted in slot 0 " I have tried 4 different sized cards from 2gig to 16gig and also tried the H2Testw test on the cards and they were ok and when I go to my browser and try to log in all I get is, " Your Duet rejected the HTTP request: page not found
            Check that the SD card is mounted and has the correct files in its /www folder " I have done the diagnostic and placed it here in the post nothing seems to work.
            • tisdaiundefined
              tisdai @tisdai
              @tisdai Is their anything else I can do to get the board working ok ?
              • tisdaiundefined
                tisdai @tisdai
                @tisdai That looks like a No then, thanks for your replies and trying to help appreciate it.
                  dc42 administrators @tisdai
                  @tisdai when you send M21 over USB or from PanelDue if you have one, what is the response?
                  Is the microcontroller getting hot?
                  • tisdaiundefined
                    tisdai @dc42
                    @dc42 ! No it is not getting hot and I get the same response from 4 different cards I tested them and placed the results here a little earlier in the post all were ok.
                    • tisdaiundefined
                      tisdai @tisdai
                      @tisdai Would jumping the erase pins and reinstalling the firmware help in any way, sorry but just trying anything I can think of that might help.
                        @tisdai if you have a genuine Duet less than one year old then please email warranty@duet3d.com including a link to this thread.
                        • tisdaiundefined
                          tisdai @dc42
                          @dc42 Yes I have a genuine Duet board I would never even consider buying anything else, I have done as you asked.
                          • tisdaiundefined
                            tisdai @tisdai
                            @tisdai Has been sorted by Warranty, Thank you to all who helped me out with this problem. Please mark as solved for me.
