    D3 Mini + wont upgrade to Release 3.4.0 beta 4
    Firmware installation
    738
    • PCRundefined
      PCR @CNCModeller
      @cncmodeller can you downgrade to 3.3 and the. Upgrade
      CNCModellerundefined 1 Reply Last reply Reply Quote 0
      • CNCModellerundefined
        CNCModeller @PCR
        @pcr that's weird, downgrade to 3.3 then upgrade to 3.4b4 and it still shows b3...
        very odd
        Polar Duet3 Mini + 1HCL
        https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
        Wanhao D4S: Duet2
        https://forum.duet3d.com/post/296755
        K40 Laser, Duet2
        https://forum.duet3d.com/post/312082
        Wanhao D5S
        https://www.youtube.com/CNCModellerUK
          T3P3Tony administrators @CNCModeller
          @cncmodeller maybe you have got the 3.4b3 uf2 by mistake?
            CNCModeller @T3P3Tony
            @t3p3tony
            Ah OK, just tried again. When I uploaded the 3.3 firmware it didn't take either... that explains it.
            Is there any way to force a firmware update without using DWC? Or doesn't it make any difference?
            Nb: I'm also on Duet Web Control 3.4.0-b4
            Wanhao D4S: Duet2
            K40 Laser, Duet2
            Wanhao D5S
              @cncmodeller send M997 from the console.
                @t3p3tony
                Thanks Tony. I'd already tried that as a generic M997 no change. I'll try forcing the relevant filename next.
                Wanhao D4S: Duet2
                K40 Laser, Duet2
                Wanhao D5S
                  @cncmodeller if that does not work then you can connect over USB, double tap the reset button and a drive will be created that you can drag the UF2 into.
                    @t3p3tony
                    Still no dice, of note the SD came up as corrupted on my PC, so I repaired it with the windows tool.
                    I've pulled the SD and placed the firmware in the root from here: https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0beta4/Duet3Firmware_Mini5plus.uf2
                    I've then run M997 S0 P"0:/Duet3Firmware_Mini5plus.uf2"
                    Unfortunately M122 still shows "RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus WiFi (standalone mode)" as does the DWC "settings", "machine specific" page.
                    Is it worth reformatting and rebuilding the SD? Not sure where to go from here?
                    Wanhao D4S: Duet2
                    K40 Laser, Duet2
                    Wanhao D5S
                    • Dougal1957undefined
                      Dougal1957 @CNCModeller
                      @cncmodeller did you place the file in the /Firmware Folder or ROOT Root won't work with M997 but if you follow Tony's suggestion of connect by USB hit the reset twice should put it into Bootloader and pop up a Explorer window with 3 files in it then drop the firmware file into that drive and it should just upgrade
                        CNCModeller @Dougal1957
                        @dougal1957 Ah ok, I'll have to pull the board from its enclosure to connect to the usb port. Will look at that after work tonight.
                        Many thanks
                        Barry M
                        Wanhao D4S: Duet2
                        K40 Laser, Duet2
                        Wanhao D5S
                          @cncmodeller before trying to remove the board, can you confirm what @Dougal1957 asked about the uf2 file in /firmware as opposed to /
                            @t3p3tony
                            I've already tried running M997 with the firmware in the firmware folder, this time I used the specified location of the SD root i.e.
                            I assume O is the SD root based on the M997 docs?
                            I'm rooting for a right angle micro SD lead as I type so I don't have to pull the board.
                            Wanhao D4S: Duet2
                            K40 Laser, Duet2
                            Wanhao D5S
                              @cncmodeller i assume you mean micro usb lead?
                              CNCModellerundefined 2 Replies Last reply Reply Quote 0
                                @t3p3tony said in D3 Mini + wont upgrade to Release 3.4.0 beta 4:
                                Yup... having a bad day!
                                Wanhao D4S: Duet2
                                K40 Laser, Duet2
                                Wanhao D5S
                                  @t3p3tony, the USB + double tap procedure worked! Albeit I had some issues along the way, see below.
                                  Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.0beta4 (2021-09-27)
                                  So some useful feedback for future me...
                                  Make sure you have the correct USB drivers installed... device manager should say: "Duet 3 motion control electronics"
                                  https://github.com/Duet3D/RepRapFirmware/blob/dev/Driver/WindowsDriverFiles.zip
                                  Long USB cables don't work for doing the double tap procedure... a short cable + powered USB extender works like a charm!
                                  Thanks for everyone's help, and now back to the main event!
                                  Cheers
                                  Barry M
                                  Wanhao D4S: Duet2
                                  K40 Laser, Duet2
                                  Wanhao D5S
