    Heater Fault
    2.6k
    • SIamundefined
      SIam @Dave Parry
      @dave-parry as far I can remember I had the same problem, my solution was to upload an actual version from Duet2CombinedIAP.bin I was sure I had the newest version, but it wasn't so...
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      • jazbaatbadalgayeundefined
        jazbaatbadalgaye
        Idk if it will work but make a copy of the contents of your SD card, then flash a stable binary using Bossa, perferably 3.3. Then generate the config files according to the printer and place those folders in the sd card. Then replace the bin in firmware folder with the version you want to flash. Go to YAT and run M997.
        Also are you pressing the reset button before you try to flash the firmware? I have noticed that even if your all files are in correct directories, YAT gives .bin file not found unless you reset the board
        Dave Parryundefined 2 Replies Last reply Reply Quote 0
        • Dave Parryundefined
          Dave Parry @jazbaatbadalgaye
          @jazbaatbadalgaye No did'nt press reset. Will try that next.
            @jazbaatbadalgaye trying to flash using bossa, but although the Com3 is listed (and Device manager/port is listed as duet) says cant connect to device. Am I missing something?
            jazbaatbadalgayeundefined 1 Reply Last reply Reply Quote 0
              jazbaatbadalgaye @Dave Parry
              @dave-parry Did you put the jumper on the erase pins? As the name suggests, it is going to erase the board so proceed with caution.
              Dave Parryundefined 1 Reply Last reply Reply Quote 0
                @jazbaatbadalgaye no I didn't and its buried underneath the heated bed...
                  Dave Parry @Dave Parry
                  @dave-parry Ok Got it done. Installed 3.3 using bossa. Then tried to install 3.4.0beta 5 and just got the same problem. So I erased again with bossa and used YAT to install 3.4.0 Beta 5 and it worked. However I would like to know why it won't work through DWC as normal. If I have to do it with Bossa it means I have to take the heated bed off do the update, re-install and then recalibrate. IfI have to do that each time I want to update I will have to extend the erase pins so they are acessible.
                  Dave Parryundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    @dave-parry After all that it hasn't cured the original fault. Still getting hot end heater errors as soon as I start a print. Do a heater reset, reset temp, wait for it to get back to set temp, restart and it prints fine. Don't think its the problem but tomorrow I will change the sensor and heater cartridge and see if it helps.
                    • Gixxerfastundefined
                      Gixxerfast
                      Maybe a redundant question, but you say that you store the pid calibration with M500.
                      Then it's saved to the config-override.g.
                      Do you load that in the end of the config.g with M501?
                      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                      Ender 3 Pro with BTT SKR-2 + RRF
                        Dave Parry @Gixxerfast
                        @gixxerfast yes it's in the file.
                          @dave-parry It seems it was a problem with the V6 hotend.
                          Took it apart, cleaned and re-installed and its so far been OK.
                          I think the block may have loosened from the heatbreak a little bit.
                          But would still like to get to the bottom of the update problem.
                            T3P3Tony administrators @Dave Parry
                            @dave-parry ok, thanks for the update about the heater fault. Will be interesting to see if it is now fixed over repeated uses.
                            We can test the upgrade again when the next beta comes out.
                              Dave Parry @T3P3Tony
                              @t3p3tony Thanks Tony.
                                @dave-parry Have got the heater error problem back again.
                                It seems that the voltage drops when the stepper motors run, but the power supply is a 24v 25w meanwell power supply, so should be more than enough power. I am going to check connections but just thought I have the hot end fan connected to a always on output, as that is how it was on my duet 0.8.5 board. Should it be on a thermostatically controlled fan output?
                                jay_s_ukundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                  jay_s_uk @Dave Parry
                                  @dave-parry are you sure you mean its only a 25w 24v PSU?
                                    Dave Parry @jay_s_uk
                                    @jay_s_uk Sorry 25A
                                      @dave-parry said in Heater Fault:
                                      this can be either, and its 99% not the cause of the power supply voltage dipping.
                                      Does M122 report voltage drops?
                                        @t3p3tony Will check tomorrow Tony been out tonight and only just got in.
                                          @t3p3tony results of M122 and error message
                                          M122
                                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta5 (2021-10-12 13:54:53) running on Duet Ethernet 1.02 or later
                                          Board ID: 0JD0M-9P6M2-NWNS4-7J1DA-3SJ6M-TA2ZK
                                          Used output buffers: 1 of 24 (22 max)
                                          Static ram: 23868
                                          Dynamic ram: 70336 of which 0 recycled
                                          Never used RAM 17804, free system stack 134 words
                                          Tasks: NETWORK(ready,27.3%,245) HEAT(notifyWait,0.0%,209) Move(notifyWait,0.0%,312) MAIN(running,72.7%,442) IDLE(ready,0.0%,30), total 100.0%
                                          Owned mutexes:
                                          Last reset 00:02:08 ago, cause: software
                                          Last software reset at 2021-10-19 10:55, reason: User, GCodes spinning, available RAM 17804, slot 1
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          Step timer max interval 0
                                          MCU temperature: min 42.8, current 43.6, max 43.7
                                          Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                          Driver 0: pos 17561,standstill, SG min/max 0/152
                                          Driver 1: pos 17561,standstill, SG min/max 0/160
                                          Driver 2: pos 17561,standstill, SG min/max 0/145
                                          Driver 3: pos 0,standstill, SG min/max n/a
                                          Driver 4: pos 0,standstill, SG min/max n/a
                                          Driver 5: pos 0
                                          Driver 6: pos 0
                                          Driver 7: pos 0
                                          Driver 8: pos 0
                                          Driver 9: pos 0
                                          Driver 10: pos 0
                                          Driver 11: pos 0
                                          Date/time: 2021-10-19 10:57:50
                                          Slowest loop: 5.92ms; fastest: 0.17ms
                                          === Storage ===
                                          Free file entries: 10
                                          SD card longest read time 3.5ms, write time 0.0ms, max retries 0
                                          DMs created 83, segments created 3, maxWait 110993ms, bed compensation in use: none, comp offset 0.000
                                          === MainDDARing ===
                                          Scheduled moves 4, completed 4, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                                          === AuxDDARing ===
                                          Segments left: 0
                                          Movement lock held by null
                                          HTTP is idle in state(s) 0
                                          Telnet is idle in state(s) 0
                                          File is idle in state(s) 0
                                          USB is idle in state(s) 0
                                          Aux is idle in state(s) 0
                                          Trigger is idle in state(s) 0
                                          Queue is idle in state(s) 0
                                          LCD is idle in state(s) 0
                                          Daemon is idle in state(s) 0
                                          Code queue is empty
                                          === Network ===
                                          Slowest loop: 8.40ms; fastest: 0.04ms
                                          HTTP sessions: 1 of 8
                                          Interface state active, link 100Mbps full duplex
                                          19/10/2021, 10:57:47 Error: Heater 1 fault: temperature excursion exceeded 15.0°C (target 210.0°C, actual 180.8°C)
                                          Dave Parryundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                            @dave-parry Its giving this error everytime I drive the axis motors.
                                            The motor currents are all set at 1000 mA.
