    PLEASE HELP trying to make duet work
    help doble motor duet
    517
    • josegerdesundefined
      josegerdes
      I am trying to work with dobble motors in z ( 2 motors ), bltouch and sensorless... but nothing its working.. please some one help me
      The thing is when i make a movment it work but homing not work
      DUET 3 MINI all last versions
      CONFIG
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.4 on Fri Oct 15 2021 18:08:53 GMT-0300 (Horário Padrão de Brasília)
      M550 P"My Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.2 S0 ; physical drive 0.2 goes forwards
      M584 X0.0 Y0.1 Z2:4 E0.3 ; set drive mapping
      M92 X160.00 Y160.00 Z3200.00 E830.00 ; set steps per mm
      M84 S30 ; Set idle timeout
      M208 X215 Y210 Z200 S0 ; set axis maxima
      M574 X1 S3 ; configure sensorless endstop for low end on X
      M574 Y1 S3 ; configure sensorless endstop for low end on Y
      ; Stallguard Sensitivy
      M915 X S2 F0 H100 R0 ; Set X axis Sensitivity
      M915 Y S1 F0 H100 R0 ; Set Y axis Sensitivity
      M950 S0 C"io3.out" ; create servo pin 0 for BLTouch
      M558 P9 C"^io3.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
      M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
      HOMEALL
      ; homeall by executing individual axes homing macros
      M98 homex.g
      M98 homey.g
      M98 homez.g
      HOMEX
      M400 ; wait til stuff stops
      M574 X1 Y1 S3 ; use stall guard for endstops
      M913 X30 Y30 ; drop motor currents to 30%
      M201 X1000 Y1000 ; reduce acceleration on X/Y to stop false triggers
      M915 P0:1 S3 R0 F0 H400; both motors because corexy; Sensitivity 4, don’t take action, don’t filter, 400steps/sec
      G91 ; set relative
      G1 Z5 F1200 S2
      G1 S1 X-250 F4000 ; move left 250mm, stopping at the endstop
      G1 X10 F1200; move away from end
      G1 Z-5 F1200 S2
      G90 ; back to absolute positioning
      M400 ; wait again
      M913 X100 Y100 ; motor currents back to 100%
      M201 X3000 Y3000 ; accel back to original
      M574 X1 Y1 Z0 S0 ; set endstops back
      HOMEY
      G91 ; set relative
      G1 Z5 F1200 S2
      G1 S1 Y-250 F4000 ; move forward 250mm, stopping at the endstop
      G1 Y10 F1200; move away from end
      G1 Z-5 F1200 S2
      M400 ; wait again
      HOMEZ
      M400
      ; slow down for probing
      M566 Z10 ; max instantaneous speed change (mm/min) (jerk)
      M203 Z400 ; max speed (mm/min)
      M201 Z100 ; max acceleration (mm/s^2)
      ; probe
      M558 A1 F400 ; set single probe at faster feed rate
      G30 ; probe
      M558 A10 F100 ; set single probe at slower feed rate (more accurate)
      G30 ; probe to get a more accurate postion
      M400
      ; set normal speeds
      M566 Z60 ; max instantaneous speed change (mm/min) (jerk)
      M203 Z900 ; max speed (mm/min)
      M201 Z20
      T3P3Tonyundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
        T3P3Tony administrators @josegerdes
        @josegerdes what part of homing does not work. I see that you are using stall homing, have you tuned your settings for stall detection?
        https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
        josegerdesundefined 1 Reply Last reply Reply Quote 0
          josegerdes @T3P3Tony
          @t3p3tony no I didn’t because i dont know how to start i thing my config its all wrong…. Can you send me the correct config, i tune here…
          The X and Y homing is not working. It just dont stop… and the Z when i home the dobble motor not work, it forget about dobble motor
          fcwiltundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @josegerdes
            @josegerdes
            The syntax for M98 is:
            M98 P"homex.g"
            Notice the P and the " " around the name of the file.
            • JoergS5undefined
              JoergS5 @josegerdes
              @josegerdes said in PLEASE HELP trying to make duet work:
              The M569 definition for 4 is missing.
                That's why you need to follow the tuning documentation.
                Also a couple of other issues have been highlighted in your configuration that should be fixed.
                  @t3p3tony i did… i lk try to fix all that to se if works.. realy i soent all day hahaah
                    josegerdes
                    @fcwilt said in PLEASE HELP trying to make duet work:
                    M98 P"homex.g"
                    now Z its working but sensorless not sensing the end...
                    M913 X60 Y60 ; drop motor currents to 30%
                    M201 X800 Y800 ; reduce acceleration on X/Y to stop false triggers
                    M915 P0 S1 R0 F0; Sensitivity 4, don’t take action, don’t filter
                    G91 ; set relative
                    G1 Z5 F1200 S2
                    G1 Z-5 F1200 S2
                    M400 ; wait again
                    And z its in a strange loop i need to check... why
                    • fcwiltundefined
                      fcwilt @josegerdes
                      M98 P"homex.g"
                      G91 ; set relative
                      G1 Z5 F1200 S2
                      G1 Z-5 F1200 S2
                      M400 ; wait again
                      I cannot help you with sensorless homing as it is not something I have every attempted to do and do not know the procedures to follow.
                        josegerdes
                        maybie its this bug https://forum.duet3d.com/topic/21108/stall-detection-on-duet-3-mini/7
                          josegerdes
                          now worket without the
                          M915 X S60 F0 R0 ; Set X axis Sensitivity
                          M915 Y S60 F0 R0 ; Set X axis Sensitivity
                          probably the defalt confg? addded D30 V40 to drivers
