    Rotating Magnetic Sensor - Keeps Pausing Printer
    Filament Monitor
    9
    151
    9.7k
    • wouldstainundefined
      wouldstain @T3P3Tony
      @t3p3tony this one is interresting:
      Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 20% to 130%, check every 3.0mm, version 3, mag 132 agc 76, measured sensitivity 19.53mm/rev, min 100% max 100% over 12.0mm
      happening repeatedly on a smaller print.Drywall_Anchor.gcode
        @wouldstain @TheDragonLord please also provide your config.g files, to help us reproduce this.
        A Former User? wouldstainundefined 3 Replies Last reply Reply Quote 0
          A Former User @dc42
          @dc42 said in Rotating Magnetic Sensor - Keeps Pausing Printer:
          sure! here's mine!
          config.g
          Thanks
            wouldstain @dc42
            @dc42 attached as requested.
            config.g
              A Former User @dc42
              If it could help I've discovered that the Magnetic sensor "doesn't like" theese two Ideamaker settings (that's the slicer I use). Unchecking both of them the false errors reduces a lot but, of course, this can't be the solution because in this way you get bad prints....
              T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
                T3P3Tony administrators @A Former User
                @thedragonlord I have been working on replicating the very fast error print you sent through
                Please can you send through the two macros that are called by your start gcode:
                M98 P"Print_gcodes/print_petg_pressure_advance.g" ;pressure advance
                M98 P"Print_gcodes/print_start_gcode.g" ; start gcode operations
                I get not "great" results but not nothing like as wide a variation as you see
                measured sensitivity 24.45mm/rev, min 70% max 103% over 219.2mm
                measured sensitivity 24.53mm/rev, min 71% max 103% over 140.2mm
                measured sensitivity 24.64mm/rev, min 71% max 104% over 100.9mm
                measured sensitivity 24.89mm/rev, min 72% max 104% over 61.5mm
                as an aside, you may have already resolved this but this is an error in your config.g (its not related to this issue):
                M350 E16:E16 I0
                The second E should not be there
                  @thedragonlord said in Rotating Magnetic Sensor - Keeps Pausing Printer:
                  Yes, these settings probably cause a lot of short moves with retraction which may be related to the issue.
                    A Former User @T3P3Tony
                    @t3p3tony said in Rotating Magnetic Sensor - Keeps Pausing Printer:
                    M350 E16:E16 I0
                    Here are the g files and thanks for the M350!
                    print_petg_pressure_advance.g.txt
                    print_start_gcode.g.txt
                      @thedragonlord thanks, sorry to be a pain but can I also have your heightmap.csv file.
                      basically looking for anything at impacts the print process.
                      A Former User? 2 Replies Last reply Reply Quote 0
                        You don't need to apolgize, you are helping me so it's all ok!
                        Here's the file:
                        heightmap.csv
                          have you discovered something? The sensor are almost completely unuseful because they keep om pausing even without the two settings...
                          EDIT:
                          I was thinking about a thing....could it be that this issue depends from the pressure advance? I'm using it with 0.4 value...
                          T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            @thedragonlord I managed to get some testing done this week and have passed the results on to @dc42. I have some more tests to do though. I made a cut down version of your print file, with as little movement as possible to see some of the effect and got 64% to 106% which for movement with no major retractions I find odd. So in summary its not forgotten, but not pinned down yet.
                            CNCModellerundefined A Former User? 2 Replies Last reply Reply Quote 0
                            • CNCModellerundefined
                              CNCModeller @T3P3Tony
                              I've also been seeing some unusual behaviour with my 600ppr encoder based filament sensor but didn't have time to investigate so I've disabled it for now.
                              If there is any significant updates on this I'll reactivate my DIY sensor.
                              Polar Duet3 Mini + 1HCL
                              https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                              Wanhao D4S: Duet2
                              https://forum.duet3d.com/post/296755
                              K40 Laser, Duet2
                              https://forum.duet3d.com/post/312082
                              Wanhao D5S
                              https://www.youtube.com/CNCModellerUK
                                ok, thanks! I think the key is PA...Let me know
                                  @thedragonlord I have been testing magnetic filament monitor reporting yesterday and today with a view to discovering why some users are experiencing this type of problem. As part of this I am putting together a set of test files. Here are the first three (more will follow). Please try them on your machine. In each case:
                                  • Select a tool and preheat it to your normal extrusion temperature, or a little higher (to make sure the extruder doesn't skip steps)
                                  • Ensure that the MFM is disabled (use M591 D0 S0 if you are testing extruder 0)
                                  • Run the file. It will home the printer if it hasn't already been homed, then extrude 10mm above the bed between X0 Y0 and X0 Y50. So it should be OK to run on almost any printer.
                                  • At the end it will use M591 to report the calibration data. Report the results here.
                                  • For the third one, the results may depend on your pressure advance setting. I get good results with PA=0.2 (my usual setting) and also with PA=1 but your results may vary.
                                  • The default extrusion speed is 1mm/sec. You can run the tests at a higher extrusion speed using the speed multiplier or the extrusion factor multiplier.
                                  MFM test 3.gcode MFM test 2.gcode MFM test 1.gcode
                                    A Former User @dc42
                                    Thanks! I'll try the three files when I'll be back home this evening and I'll let tyou know
                                      @thedragonlord here's test file 4. For this one you need to configure firmware retraction using M207.
                                      MFM test 4.gcode
                                      dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
                                        dc42 administrators @dc42
                                        @wouldstain please can you run these four test files too.
                                        wouldstainundefined 1 Reply Last reply Reply Quote 0
                                          A Former User @dc42
                                          MFM test 4.gcode
                                          I'll try this too. I've never used the M207, I suppose I have to configure it with the same params I set in the slicer for retraction, right? I usually set 3mm at 40mm/sec so I have to set:
                                          M207 P0 S3 F2400
                                          and set it in the config.g correct?
                                            @thedragonlord yes thats right
