    Rotating Magnetic Sensor - Keeps Pausing Printer
    Filament Monitor
    9
    151
    9.7k
      T3P3Tony administrators @A Former User
      @thedragonlord thanks, sorry to be a pain but can I also have your heightmap.csv file.
      basically looking for anything at impacts the print process.
      A Former User? 2 Replies Last reply Reply Quote 0
        A Former User @T3P3Tony
        @t3p3tony said in Rotating Magnetic Sensor - Keeps Pausing Printer:
        You don't need to apolgize, you are helping me so it's all ok!
        Here's the file:
        heightmap.csv
          have you discovered something? The sensor are almost completely unuseful because they keep om pausing even without the two settings...
          EDIT:
          I was thinking about a thing....could it be that this issue depends from the pressure advance? I'm using it with 0.4 value...
          T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
            @thedragonlord I managed to get some testing done this week and have passed the results on to @dc42. I have some more tests to do though. I made a cut down version of your print file, with as little movement as possible to see some of the effect and got 64% to 106% which for movement with no major retractions I find odd. So in summary its not forgotten, but not pinned down yet.
            CNCModellerundefined A Former User? 2 Replies Last reply Reply Quote 0
            • CNCModellerundefined
              CNCModeller @T3P3Tony
              I've also been seeing some unusual behaviour with my 600ppr encoder based filament sensor but didn't have time to investigate so I've disabled it for now.
              If there is any significant updates on this I'll reactivate my DIY sensor.
              Polar Duet3 Mini + 1HCL
              https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
              Wanhao D4S: Duet2
              https://forum.duet3d.com/post/296755
              K40 Laser, Duet2
              https://forum.duet3d.com/post/312082
              Wanhao D5S
              https://www.youtube.com/CNCModellerUK
                ok, thanks! I think the key is PA...Let me know
                  @thedragonlord I have been testing magnetic filament monitor reporting yesterday and today with a view to discovering why some users are experiencing this type of problem. As part of this I am putting together a set of test files. Here are the first three (more will follow). Please try them on your machine. In each case:
                  • Select a tool and preheat it to your normal extrusion temperature, or a little higher (to make sure the extruder doesn't skip steps)
                  • Ensure that the MFM is disabled (use M591 D0 S0 if you are testing extruder 0)
                  • Run the file. It will home the printer if it hasn't already been homed, then extrude 10mm above the bed between X0 Y0 and X0 Y50. So it should be OK to run on almost any printer.
                  • At the end it will use M591 to report the calibration data. Report the results here.
                  • For the third one, the results may depend on your pressure advance setting. I get good results with PA=0.2 (my usual setting) and also with PA=1 but your results may vary.
                  • The default extrusion speed is 1mm/sec. You can run the tests at a higher extrusion speed using the speed multiplier or the extrusion factor multiplier.
                  MFM test 3.gcode MFM test 2.gcode MFM test 1.gcode
                    A Former User @dc42
                    @dc42 said in Rotating Magnetic Sensor - Keeps Pausing Printer:
                    Thanks! I'll try the three files when I'll be back home this evening and I'll let tyou know
                      @thedragonlord here's test file 4. For this one you need to configure firmware retraction using M207.
                      MFM test 4.gcode
                      dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
                        dc42 administrators @dc42
                        @wouldstain please can you run these four test files too.
                        wouldstainundefined 1 Reply Last reply Reply Quote 0
                          A Former User @dc42
                          MFM test 4.gcode
                          I'll try this too. I've never used the M207, I suppose I have to configure it with the same params I set in the slicer for retraction, right? I usually set 3mm at 40mm/sec so I have to set:
                          M207 P0 S3 F2400
                          and set it in the config.g correct?
                            @thedragonlord yes thats right
                            • alankilianundefined
                              alankilian @T3P3Tony
                              Here are my results if they are helpful:
                              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2021-01-05
                              (I took out the var... part since my version of RRF doesn't support that)
                              Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 132 agc 114, measured sensitivity 26.00mm/rev, min 98% max 102% over 98.5mm
                              Finished printing file 0:/gcodes/1635171097795-mfm-test-1.gcode, print time was 0h 0m
                              Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 132 agc 114, measured sensitivity 26.40mm/rev, min 96% max 103% over 98.8mm
                              Finished printing file 0:/gcodes/1635171097802-mfm-test-2.gcode, print time was 0h 0m
                              Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 131 agc 114, measured sensitivity 26.76mm/rev, min 97% max 102% over 48.5mm
                              Finished printing file 0:/gcodes/1635171097805-mfm-test-3.gcode, print time was 0h 0m
                              (At this point, I entered M207 P0 S3 F2400 in the GCODE console)
                              Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 131 agc 114, measured sensitivity 26.80mm/rev, min 96% max 103% over 40.0mm
                              Finished printing file 0:/gcodes/1635173702760-mfm-test-4.gcode, print time was 0h 0m
                                PS all these files use relative extrusion. I will add M83 commands to the final versions, in the mean time feel free to ad M83 commands yourself if you do not have M83 in config.g.
                                  dc42 administrators @alankilian
                                  @alankilian thanks, so far they look good (I'm looking at the measured sensitivity min/max). More test files to follow.
                                    Here are some more test files, also the earlier ones with added M83 commands.
                                    MFM test 7.gcode MFM test 6.gcode MFM test 5.gcode MFM test 4.gcode MFM test 3.gcode MFM test 2.gcode MFM test 1.gcode
                                      A Former User @dc42
                                      Here are my results:
                                      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 24.78mm/rev, allow 0% to 160%, check every 3.0mm, version 3, mag 132 agc 68, measured sensitivity 25.36mm/rev, min 96% max 104% over 98.2mm
                                      Finished printing file 0:/gcodes/Test/1635178672419-mfm-test-1.gcode, print time was 0h 0m
                                      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 24.78mm/rev, allow 0% to 160%, check every 3.0mm, version 3, mag 129 agc 66, measured sensitivity 25.28mm/rev, min 97% max 104% over 98.2mm
                                      Finished printing file 0:/gcodes/Test/1635178672425-mfm-test-2.gcode, print time was 0h 0m
                                      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 24.78mm/rev, allow 0% to 160%, check every 3.0mm, version 3, mag 129 agc 66, measured sensitivity 25.18mm/rev, min 97% max 102% over 48.9mm
                                      Finished printing file 0:/gcodes/Test/1635178672427-mfm-test-3.gcode, print time was 0h 0m
                                      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 24.78mm/rev, allow 0% to 160%, check every 3.0mm, version 3, mag 129 agc 66, measured sensitivity 25.28mm/rev, min 98% max 102% over 40.0mm
                                      Finished printing file 0:/gcodes/Test/1635178672429-mfm-test-4.gcode, print time was 0h 0m
                                      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 24.78mm/rev, allow 0% to 160%, check every 3.0mm, version 3, mag 130 agc 66, measured sensitivity 25.22mm/rev, min 98% max 104% over 98.3mm
                                      Finished printing file 0:/gcodes/Test/1635178672431-mfm-test-5.gcode, print time was 0h 0m
                                      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 24.78mm/rev, allow 0% to 160%, check every 3.0mm, version 3, mag 130 agc 66, measured sensitivity 25.22mm/rev, min 97% max 104% over 98.3mm
                                      Finished printing file 0:/gcodes/Test/1635178672433-mfm-test-6.gcode, print time was 0h 0m
                                      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 24.78mm/rev, allow 0% to 160%, check every 3.0mm, version 3, mag 130 agc 66, measured sensitivity 25.07mm/rev, min 98% max 102% over 48.1mm
                                      Finished printing file 0:/gcodes/Test/1635178672436-mfm-test-7.gcode, print time was 0h 1m
                                        alankilian @A Former User
                                        This was without M207 P0 S3 F2400
                                        Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 132 agc 114, measured sensitivity 25.57mm/rev, min 99% max 102% over 48.3mm
                                        Finished printing file 0:/gcodes/1635178672436-mfm-test-7.gcode, print time was 0h 0m
                                        Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 131 agc 114, measured sensitivity 25.80mm/rev, min 97% max 102% over 97.9mm
                                        Finished printing file 0:/gcodes/1635178672433-mfm-test-6.gcode, print time was 0h 0m
                                        Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 132 agc 116, measured sensitivity 26.07mm/rev, min 96% max 104% over 98.4mm
                                        Finished printing file 0:/gcodes/1635178672431-mfm-test-5.gcode, print time was 0h 0m
                                        This was WITH M207 P0 S3 F2400
                                        With M207 P0 S3 F2400
                                        Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 132 agc 114, measured sensitivity 25.52mm/rev, min 99% max 102% over 48.1mm
                                        Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 132 agc 114, measured sensitivity 25.89mm/rev, min 97% max 103% over 97.8mm
                                        Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 132 agc 114, measured sensitivity 25.91mm/rev, min 98% max 102% over 98.5mm
                                        • wouldstainundefined
                                          wouldstain
                                          I can certainly run those files tomorrow.
                                          Additional datapoint:
                                          I ran an 8hr job yesterday with PETG (have had far fewer problems with PETG than PLA)
                                          with zero issues after running with the the sensor set wide open:
                                          M591 P3 C"e0_stop" S1 D0 L26.5 R1:200
                                          printing at 60mm/sec perimeter and 80mm/sec infill.
                                          If I slow down the print speed (only tried to slow to 40/60) I get stops again.
                                          Will run test files tomorrow and share results.
                                          A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                            A Former User @wouldstain
                                            @wouldstain said in Rotating Magnetic Sensor - Keeps Pausing Printer:
                                            So your problems seem to happen when you print slower? mmh, interesting...I always print at 60mm/s internal perimeters and infill and 40mm/s external perimeter....have you configured PA as well?
