    Z homing issu whit endstop please help
    1.8k
      jay_s_uk @bartekp
      @bartekp where is your endstop situated? your config says at minimum (i.e. 0) but your homing file for z sends the axis to the maximum.
      I don;t have z endstops on any of my machines and just use a probe to home the z axis
      bartekpundefined 1 Reply Last reply Reply Quote 0
      • bartekpundefined
        bartekp @jay_s_uk
        @jay_s_uk THe Z endstop is at the top and to homing Z the table is liftet to top
          jay_s_uk @bartekp
          @bartekp then your homing file needs changing
          e.g.
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni)
          G91 ; relative positioning
          G1 H1 Z-605 F1800 ; move Z up until the endstop is triggered
          G92 Z0 ; set Z position to axis maximum (you may want to adjust this)
          ;G91 ; relative positioning
          ;G1 Z5 F200 ; lift Z relative to current position
          ;G90 ; absolute positioning
          bartekpundefined 2 Replies Last reply Reply Quote 0
          • bartekpundefined
            bartekp @jay_s_uk
            @jay_s_uk In exosted with this config , can you tell me wah to do start printing I try to understatnd but this manual iw writen by enginer who maded this and I mnot so smart like he . And I fight with this almost 3 weeks .If you can please tel me what to change
            Bart
            • bartekpundefined
              bartekp @bartekp
              @bartekp I try to change Z1 to Z2 or S1 to 0 or 2 and the sama results
              • bartekpundefined
                bartekp @jay_s_uk
                @jay_s_uk I changed the home z and nothing changed
                  jay_s_uk @bartekp
                  @bartekp it should change the direction it homes in when using just G28 Z or Home z on the DWC screen.
                  Otherwise ditch the endstop and move the head to the middle of the bed and probe using G30
                  • bartekpundefined
                    bartekp @jay_s_uk
                    @jay_s_uk G28 table go up but whit G28 Z table goes down and when I pusch Z endstops the table stops
                    • bartekpundefined
                      bartekp @jay_s_uk
                      @jay_s_uk im not sure if my Z probe is good code in config g
                        jay_s_uk @bartekp
                        @bartekp sounds like your z motor need inverting then. As Z0 should be when the bed is in its highest position. Change the S value on the M569 line in your config to either S1 or S0.
                        Then reboot and home x, y and z independently and see if it's in the right position. DWC should show 0 for z once homed
                        • bartekpundefined
                          bartekp @jay_s_uk
                          @jay_s_uk OK I inverted the Z motors works bether!
                          What I meand that when I pusch X home or Y home table move down and home this axis and back to position , and after this i must homing Z what work also perfect
                          but If i Puch home all axis table go down and down and down and I must restatr the maschine
                            jay_s_uk @bartekp
                            @bartekp edit the home z portion of homeall to match the same as in homez.
                            If you're not sure, post your homeall here and I'll edit it for you
                            • bartekpundefined
                              bartekp @jay_s_uk
                              @jay_s_uk ; homeall.g
                              ; called to home all axes
                              G1 H2 Z5 F12000 ; lift Z relative to current position
                              G1 H1 X-505 Y-505 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                              G1 H1 X-505 ; home X axis
                              G1 H1 Y-505 ; home Y axis
                              G1 X5 Y5 F12000 ; go back a few mm
                              G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
                              G1 H1 Y-505 ; then move slowly to Y axis endstop
                              G1 H1 Z605 F360 ; move Z up stopping at the endstop
                              G92 Z600 ; set Z position to axis maximum (you may want to adjust this)
                              • bartekpundefined
                                bartekp @bartekp
                                @bartekp ; homeall.g
                                  jay_s_uk @bartekp
                                  ; homeall.g
                                  G1 H1 Z-605 F360 ; move Z up stopping at the endstop
                                  ;G92 Z600 ; set Z position to axis maximum (you may want to adjust this)
                                  There you go
                                  • bartekpundefined
                                    bartekp @jay_s_uk
                                    @jay_s_uk HI You mean G92 adjust for z 100 like this ??
                                    bartekpundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                    • bartekpundefined
                                      bartekp @bartekp
                                      @bartekp said in Z homing issu whit endstop please help:
                                      Can you look at Z probe if is good generated ?
                                      M558 P5 C"^zprobe.in" H5 F120 T12000 ; set Z probe type to switch and the dive height + speeds
                                      M557 X70:500 Y70:500 S20 ; define mesh grid
                                        jay_s_uk @bartekp
                                        i'm not sure what you mean here
                                        what type of probe is it?
                                        you can check the status of the probe on this window
                                        If its red, its triggered, if its not red, its not
                                        • bartekpundefined
                                          bartekp @jay_s_uk
                                          @jay_s_uk Bltouch sorry for that
                                            jay_s_uk @bartekp
                                            @bartekp no as you appear to be missing the servo configuration https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
                                            What board are you using and where is the bltouch connected?
                                            You should also have deployprobe.g and retractprobe.g in your sys folder
