Z homing issu whit endstop please help
@bartekp it should change the direction it homes in when using just G28 Z or Home z on the DWC screen.
Otherwise ditch the endstop and move the head to the middle of the bed and probe using G30 -
@jay_s_uk G28 table go up but whit G28 Z table goes down and when I pusch Z endstops the table stops
@jay_s_uk im not sure if my Z probe is good code in config g
@bartekp sounds like your z motor need inverting then. As Z0 should be when the bed is in its highest position. Change the S value on the M569 line in your config to either S1 or S0.
Then reboot and home x, y and z independently and see if it's in the right position. DWC should show 0 for z once homed -
@jay_s_uk OK I inverted the Z motors works bether!
What I meand that when I pusch X home or Y home table move down and home this axis and back to position , and after this i must homing Z what work also perfect
but If i Puch home all axis table go down and down and down and I must restatr the maschine -
@bartekp edit the home z portion of homeall to match the same as in homez.
If you're not sure, post your homeall here and I'll edit it for you -
@jay_s_uk ; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni)
G91 ; relative positioning
G1 H2 Z5 F12000 ; lift Z relative to current position
G1 H1 X-505 Y-505 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-505 ; home X axis
G1 H1 Y-505 ; home Y axis
G1 X5 Y5 F12000 ; go back a few mm
G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-505 ; then move slowly to Y axis endstop
G1 H1 Z605 F360 ; move Z up stopping at the endstop
G90 ; absolute positioning
G92 Z600 ; set Z position to axis maximum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F200 ; lift Z relative to current position
;G90 ; absolute positioning -
@bartekp ; homeall.g
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni) G91 ; relative positioning G1 H2 Z5 F12000 ; lift Z relative to current position G1 H1 X-505 Y-505 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-505 ; home X axis G1 H1 Y-505 ; home Y axis G1 X5 Y5 F12000 ; go back a few mm G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-505 ; then move slowly to Y axis endstop G1 H1 Z-605 F360 ; move Z up stopping at the endstop G90 ; absolute positioning ;G92 Z600 ; set Z position to axis maximum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F200 ; lift Z relative to current position ;G90 ; absolute positioning There you go
@jay_s_uk HI You mean G92 adjust for z 100 like this ??
@bartekp said in Z homing issu whit endstop please help:
Can you look at Z probe if is good generated ?
M558 P5 C"^zprobe.in" H5 F120 T12000 ; set Z probe type to switch and the dive height + speeds
M557 X70:500 Y70:500 S20 ; define mesh grid -
i'm not sure what you mean here
M557 X70:500 Y70:500 S20 ; define mesh gridwhat type of probe is it?
you can check the status of the probe on this window
If its red, its triggered, if its not red, its not -
@jay_s_uk Bltouch sorry for that
@bartekp no as you appear to be missing the servo configuration https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
What board are you using and where is the bltouch connected?
You should also have deployprobe.g and retractprobe.g in your sys folder -
@bartekp deployprobe.g and retractprobe.g duet 2 wifi
@bartekp then you should have this line in your config
M950 S0 C"exp.heater3"
if you add that, does the probe react to M401 and M402?
What's the contents of those deploy and retract files? -
@jay_s_uk sory i forgot i dont have this files I working on reach them please wait
@bartekp
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F1200 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X30 Y60 Z8 ; set Z probe trigger value, offset and trigger height
M557 X15:315 Y15:315 S20 ; define mesh grid; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.3.4 on Wed Oct 20 2021 14:25:18 GMT+0200 (czas środkowoeuropejski letni)
M280 P3 S10 I1 ; deploy BLTouch; retractprobe.g
; called to retract a physical Z probe
M280 P3 S90 I1 ; retract BLTouch -
Thats the wrong syntax.
You needM558 P9 C"^zprobe.in" H5 F100 T2000 M950 S0 C"exp.heater3" G31 P500 X30 Y60 Z8 ; set Z probe trigger value, offset and trigger height M557 X15:315 Y15:315 S20 ; define mesh grid you also don't need the M307
