Just for fun why did I buy this?
My Duet controlled machine
1.2k
    fcwilt @bot
    @bot said in Just for fun why did I buy this?:
    @fcwilt the first word?
    Yes
    undefined 1 Reply Last reply 20 Oct 2021, 00:09 Reply Quote 0
      bot @fcwilt
      @fcwilt sounds like fun. I have been manually aligning my tools on the idex with a cheap USB microscope. so magnificent. You could use your little doo-dad to move the camera into the exact same position every time!
      Or, a CNC-style tool pre-setter to measure tool Z offsets.
      Or, a 3D-Taster style multi-axis touch probe to do Z and X/Y offsets.
      *not actually a robot
      undefined 1 Reply Last reply 20 Oct 2021, 00:11 Reply Quote 0
        fcwilt @bot
        Well your first word was "probing" unless I read it wrong.
        undefined 1 Reply Last reply 20 Oct 2021, 00:12 Reply Quote 0
          bot @fcwilt
          @fcwilt hmmmm. probing is a vague term. I hope you're not thinking of placing anything in any dark places.
          undefined 1 Reply Last reply 20 Oct 2021, 00:15 Reply Quote 0
            fcwilt @bot
            Nope - nothing like that - but was not your first word "probing"? The second item mentioned as tool alignment using a camera.
            Did I misunderstand your post?
              zapta @fcwilt
              @fcwilt said in Just for fun why did I buy this?:
              OK, it is used to move something out of the way so when printing no print area is lost but still allows the something to perform it's intended purpose.
              My answer below, encrypted with Google translate
              Brosse de nettoyage de buse
              undefined 1 Reply Last reply 20 Oct 2021, 00:36 Reply Quote 0
                jens55
                Pebble wiper setup
                  fcwilt @zapta
                  @zapta said in Just for fun why did I buy this?:
                  I like that I idea - I may just try that as well.
                    fcwilt @jens55
                    @jens55 said in Just for fun why did I buy this?:
                    Pebble wiper setup
                    What is a "pebble wiper"?
                    undefined 1 Reply Last reply 20 Oct 2021, 01:28 Reply Quote 0
                      jens55 @fcwilt
                      @fcwilt, a device for cleaning printing nozzles. The purged filament is formed into a pebble for easy separation from the nozzle (no curling around of loose filament), disconnected from the nozzle and then wiped away to ready for the next purge operation. In the context of a tool changing printer, the height of the wiper assembly is adjusted based on the tool being purged which is why you have a very short reach adjustable stage.
                      undefined 1 Reply Last reply 20 Oct 2021, 02:04 Reply Quote 0
                        fcwilt @jens55
                        Interesting.
                        How is the filament formed into a "pebble"?
                        undefined undefined 2 Replies Last reply 20 Oct 2021, 02:45 Reply Quote 0
                          jens55 @fcwilt
                          @fcwilt, it is extruded onto a flat surface just underneath the extruder
                          https://lukeslabonline.com/products/pebble-wiper?variant=41218627371193
                          undefined 1 Reply Last reply 20 Oct 2021, 02:48 Reply Quote 1
                            fcwilt @jens55
                            Well the link is interesting because it is also a clue to what I am experimenting with.
                              Yveske @fcwilt
                              @fcwilt A cheaper, mechanical way of doing things
                              https://www.bigbrain3d.com/product/retractable-purge-mechanism/
                              undefined 1 Reply Last reply 20 Oct 2021, 07:02 Reply Quote 0
                                fcwilt @Yveske
                                @yveske said in Just for fun why did I buy this?:
                                That is rather neat.
                                  fcwilt @fcwilt
                                  Well I finished the first experimental setup and it is working, although with a limitation I believe is related to the 12 volt power supplies I used on this printer.
                                  I will make a quick video Wednesday and post a link to it here.
                                  undefined 1 Reply Last reply 20 Oct 2021, 17:03 Reply Quote 0
                                    fcwilt @fcwilt
                                    @fcwilt
                                    Here is a link to a quick-and-dirty video showing the mini linear guide at work.
                                    Mini Linear Guide At Work
                                    It was hard to get a good view - sorry.
                                    16 out of 23
