    Just for fun why did I buy this?
    My Duet controlled machine
    1.2k
    • fcwiltundefined
      fcwilt @bot
      @bot said in Just for fun why did I buy this?:
      Probing, tool alignment with a camera coming in and out, or purge bucket moving in and out of print area are my guesses.
      Well one of the words in your post is exactly what this experiment is about.
      • botundefined
        bot @fcwilt
        @fcwilt the first word?
        *not actually a robot
        • fcwiltundefined
          fcwilt @bot
          Yes
          • botundefined
            bot @fcwilt
            @fcwilt sounds like fun. I have been manually aligning my tools on the idex with a cheap USB microscope. so magnificent. You could use your little doo-dad to move the camera into the exact same position every time!
            Or, a CNC-style tool pre-setter to measure tool Z offsets.
            Or, a 3D-Taster style multi-axis touch probe to do Z and X/Y offsets.
            • fcwiltundefined
              fcwilt @bot
              Well your first word was "probing" unless I read it wrong.
              • botundefined
                bot @fcwilt
                @fcwilt hmmmm. probing is a vague term. I hope you're not thinking of placing anything in any dark places.
                • fcwiltundefined
                  fcwilt @bot
                  Nope - nothing like that - but was not your first word "probing"? The second item mentioned as tool alignment using a camera.
                  Did I misunderstand your post?
                  • zaptaundefined
                    zapta @fcwilt
                    @fcwilt said in Just for fun why did I buy this?:
                    OK, it is used to move something out of the way so when printing no print area is lost but still allows the something to perform it's intended purpose.
                    My answer below, encrypted with Google translate
                    Brosse de nettoyage de buse
                    • jens55undefined
                      jens55
                      Pebble wiper setup
                      • fcwiltundefined
                        fcwilt @zapta
                        @zapta said in Just for fun why did I buy this?:
                        I like that I idea - I may just try that as well.
                        • fcwiltundefined
                          fcwilt @jens55
                          @jens55 said in Just for fun why did I buy this?:
                          Pebble wiper setup
                          What is a "pebble wiper"?
                          • jens55undefined
                            jens55 @fcwilt
                            @fcwilt, a device for cleaning printing nozzles. The purged filament is formed into a pebble for easy separation from the nozzle (no curling around of loose filament), disconnected from the nozzle and then wiped away to ready for the next purge operation. In the context of a tool changing printer, the height of the wiper assembly is adjusted based on the tool being purged which is why you have a very short reach adjustable stage.
                            • fcwiltundefined
                              fcwilt @jens55
                              Interesting.
                              How is the filament formed into a "pebble"?
                              jens55undefined Yveskeundefined 2 Replies Last reply Reply Quote 0
                              • jens55undefined
                                jens55 @fcwilt
                                @fcwilt, it is extruded onto a flat surface just underneath the extruder
                                https://lukeslabonline.com/products/pebble-wiper?variant=41218627371193
                                • fcwiltundefined
                                  fcwilt @jens55
                                  Well the link is interesting because it is also a clue to what I am experimenting with.
                                  • Yveskeundefined
                                    Yveske @fcwilt
                                    @fcwilt A cheaper, mechanical way of doing things
                                    https://www.bigbrain3d.com/product/retractable-purge-mechanism/
                                    • fcwiltundefined
                                      fcwilt @Yveske
                                      @yveske said in Just for fun why did I buy this?:
                                      That is rather neat.
                                      • fcwiltundefined
                                        fcwilt @fcwilt
                                        Well I finished the first experimental setup and it is working, although with a limitation I believe is related to the 12 volt power supplies I used on this printer.
                                        I will make a quick video Wednesday and post a link to it here.
                                        • fcwiltundefined
                                          fcwilt @fcwilt
                                          @fcwilt
                                          Here is a link to a quick-and-dirty video showing the mini linear guide at work.
                                          Mini Linear Guide At Work
                                          It was hard to get a good view - sorry.
