    sensor ir
    3.9k
      A Former User
      Capture d’écran 2021-10-25 171053.png Capture d’écran 2021-10-25 163600.png hello everyone, i have problems configuring my mini ir sensor can you help pleaseundefined
      SIamundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam @A Former User
        @sgk if you post your config.g file, the chance for help is extremely higher 😉
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
          A Former User @SIam
          @siam ok thanks config.g
            A Former User
            ; ====================== Network ===========================
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M669 K1 ; select CoreXY mode
                            ; ======================= Endstops =========================
            M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
            M575 P1 S1 B57600 ; Set things up for the PanelDue
                                        ; Filament sensor
            ;M591 D0 P1 C"e0stop" S1 ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0
                        ; ======================= Drives ===========================
            M569 P0 S0 ; Drive 0 goes backwards blv: its was S1
            M569 P1 S0 ; Drive 1 goes backwards blv: its was S1
            M569 P2 S0 ; Drive 2 goes forwards
            M569 P3 S1 ; Drive 3 goes backwards WAS 0
            M569 P4 S0 ; Drive 4 goes forwards
            M584 X0 Y1 Z2:4 E3 ; set drive mapping
                         ; ===================== Drive Settings =====================
            M92 X200,120 Y200,541 Z800 E714.36 ; Set steps per mm for orbiter
            M566 X600 Y600 Z800 E600 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
            M203 X20000 Y20000 Z600 E7200 ; Set maximum speeds (mm/min)
            M201 X1000 Y1000 Z100 E700 ; Set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1000 E1200 I10 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
                                      ; ===================== Axis Limits ========================
            M208 X-23 Y0 Z0 S1 ; Set axis minima
            M208 X320 Y320 Z350 S0 ; Set axis maxima
                                      ; ======================== Z-Probe =========================
            M558 P1 C"^zprobe.in" H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor
            G31 P500 X-2.24 Y-20.81 Z1.044 ; Set Z probe trigger value, offset and trigger height
            M557 X20:270 Y20:270 S240 ; Define mesh grid
                                     ; ======================== Heaters =========================
            M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
            M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
            M307 H0 R0.345 C165.9 D7.58 S1.00 V23.6 ; Heatbed PID
            M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; define E0 temperature sensor
            M950 H1 C"e0heat" T1 ; heater 1 uses the e0heat pin and sensor 1
            M307 H1 R2.697 C168.9:154.1 D9.06 S1.00 V23.6 ; Hotend PID .4mm
            M143 H1 S260 ; set temperature limit for heater 0 to 260C
            M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor
                                       ; ======================== Tools ===========================
            M563 P0 S"T0" D0 H1 F1 ; Define tool 0
                                      ; ========================= Fans ===========================
            M106 P1 C"HE Fan" S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on 100% at 45deg
            ;Tool Fan/ Layer Fan
            M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
            ;MB cooling fan layer
            M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
            M106 P2 C"MB Fan" S1 H2 T35:55 ; set fan 2 value. Thermostatic control is turned on Temp Range of 35 - 55 deg
                                        ; ===================== Custom settings ====================
            M572 D0 S0.275 ; Set bowden extruder elasticity compensation for E0
            ;M207 S4.0 F2400 Z2.275 ; Set firmware retraction parameters
            M207 S4.0 F2400 Z0.075 ; Set firmware retraction parameters
            M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
                                                     ; Scanner support (debug)
            ;M750
                                               ; Set up DHT sensor on channels 101-102
            ;M305 P101 X405 S"DHT temperature" T11
            ;M305 P102 X455 S"DHT humidity [%]" T11
                                                        ; Automatic power saving
            M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                                       ; ====================== Miscellaneous =====================
            M500 ; save
            T0 ; select first tool
            ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
            • SIamundefined
              SIam @A Former User
              @sgk
              M350 X16 Y16 Z16 E16 I1                            ; Configure microstepping with interpolation
              Replace the comas with a dot after that go to the console and enter g98 P"config.g" and post the result.
              When you now enter M119 in the console look if the Z probe is triggered if it so change the following line
              to
              M558 P1 C"!^zprobe.in" H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor
              an retest with M119
                A Former User
                @siam i have M119
                Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
                  A Former User
                  • SIamundefined
                    SIam @A Former User
                    @sgk have you made the changes which I have provided in my last post? And can you post the result of M98 P"config.g"
                      A Former User
                        A Former User
                          A Former User
                            A Former User
                            when I do Calibrate the Z probe trigger height the bed crashed into the nozzle when I hit g30 s-1
                            • oliofundefined
                              oliof @A Former User
                              @sgk trigger height needs to be a positive value for the IR probe in RepRapFirmware.
                                A Former User
                                thank you for answering me.
                                when i type g30 s-1 the bed doesn't stop
                                  A Former User
                                  is normal
                                  • oliofundefined
                                    @sgk if you have the gantry high enough do that you can trigger the probe by putting your finger under it, can you see that the z probe value on DWC goes up?
                                    Also, what kind of bed material do you use?
                                      A Former User @oliof
                                        A Former User @A Former User
                                        @sgk this bed
                                        • oliofundefined
                                          @sgk pei sheet is semi transparent and I've had mixed success with the IR board on it. I take it you also tested it with the paper underneath?
                                            @oliof yes yes but the bed does not stop
                                            jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
