    sensor ir
    3.8k
      A Former User
      thank you for answering me.
      when i type g30 s-1 the bed doesn't stop
        A Former User
        is normal
        • oliofundefined
          oliof @A Former User
          @sgk if you have the gantry high enough do that you can trigger the probe by putting your finger under it, can you see that the z probe value on DWC goes up?
          Also, what kind of bed material do you use?
            A Former User @oliof
              A Former User @A Former User
              @sgk this bed
              • oliofundefined
                @sgk pei sheet is semi transparent and I've had mixed success with the IR board on it. I take it you also tested it with the paper underneath?
                  @oliof yes yes but the bed does not stop
                  jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                  • jumpedwithbothfeetundefined
                    jumpedwithbothfeet @A Former User
                    @sgk @oliof, I maybe off base but would it be worth trying the probe in mode 8? this is the way my IR sensor is configured, then use the paper with the bed well out of the way to trigger a response?
                    6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                      A Former User
                      I will try
                        A Former User
                        M558 P1 C"!zprobe.in" H5 F120 T6000
                        to
                        M558 P8 C"!zprobe.in" H5 F120 T6000
                          A Former User
                            A Former User
                            in fact the probe does not trigger because when I raise the bed I put the finger and the bed does not stop it continues to rise
                              @sgk are you getting any lights on the ir board when the printer turns on, Red light when you trigger it?
                                A Former User @jumpedwithbothfeet
                                @jumpedwithbothfeet yes 4x
                                  @sgk have you read through this?
                                  https://miscsolutions.wordpress.com/mini-height-sensor-board/
                                    SIamundefined 1 Reply Last reply Reply Quote 0
                                    • SIamundefined
                                      SIam @A Former User
                                      @sgk
                                      what happens if you replace this line
                                      M558 P1 C"^zprobe.in" H5 F200 T9000 I0 R0.5		        ; Set Z probe type mini ir sensor
                                      with this
                                      M558 P1 C"zprobe.in" H5 F120 T6000             ; set Z probe type to unmodulated and the dive height + speeds
                                      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                                      Duet WiFi 1.02 or later + DueX5
                                      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                                      Duet WiFi Server: 1.26
                                      Duet Web Control 3.4.0beta4 (2021-09-27)
                                        A Former User @SIam
                                        @siam thank you for helping me
                                          A Former User
                                            A Former User
                                            likewise the bed does not stop
