    Large Format Dowell to Duet conversion
    362
    35.4k
      T3P3Tony administrators @Charles Fraser
      @charles-fraser lets deal with the incompatible firmware bit and then come back to the heaters.
      Please send M115 and M115 B1. copy the results from the console into here.
      Then look at the "settings" machine and General to get the DWC and DSF versions.
      Charles Fraserundefined 2 Replies Last reply Reply Quote 0
      • Charles Fraserundefined
        Charles Fraser @T3P3Tony
        @t3p3tony
        27/10/2021, 15:36:37 M115 B1
        Duet EXP3HC firmware version 3.4.0beta5 (2021-10-12 13:58:36)
        27/10/2021, 15:36:25 M115
        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-06-15 21:45:56
          @t3p3tony
          Duet Web Control 3.4.0-b5
          Board: Duet 3 MB6HC (MB6HC)
          DSF Version: 3.4-b5
          Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15)
            @charles-fraser ok so when you upgraded to 3.4b5 the mainboard did not get upgraded
              T3P3Tony administrators @T3P3Tony
              @Charles-Fraser take this file:
              Duet3Firmware_MB6HC.bin
              From here
              https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.0beta5
              and upgrade using the System->Upload System Files
              Charles Fraserundefined 1 Reply Last reply Reply Quote 0
                @t3p3tony
                Can you please explain exactly how - step by step. Last time I had to totally reinstall raspberry Pi and everything else!
                So if I download that file and upload it to the system folder (not the firmware folder) then send command ... what was it again?
                  @charles-fraser
                  If you get the "Duet3Firmware_MB6HC.bin" from
                  And then go to the systems page and upload that file using the Upload system Files dialog box it will prompt you to install it. Say yes.
                  The issues with the Pi before were different. everything else in your system is running 3.4b5
                    @t3p3tony
                    Okay we are beta 5 across the boards
                    28/10/2021, 10:32:41 M115 B1
                    28/10/2021, 10:32:23 M115
                    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta5 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-10-12 13:53:56
                      @charles-fraser ok, now you should not be getting a incompatibility fault and the temp sensors should be showing up. When you heat the heaters you may still get a heater fault. What is reported in the console for those heater faults? if its temperature is rising too slowly then we will fix that when you have the sensors installed in the hotend/bed and we are in a position to tune the PIDs for those heaters.
                        @t3p3tony
                        Yup all is heating up now with just a heater fault. there is nothing in the console about those faults. We could run autotune PID for the bed because that is set up but it's on bangbang mode so I wonder if that still has PID? I guess it must right?
                        I still havn't found a 3mm x 15mm p1000 but I will find one. Perhaps we can move onto the endstops now? I'm not sure which way around the wording convention indicates I have set up my end stops (again a diagram would be helpful) but perhaps there is a way I can test that is working and then start to do motor configuration after that? My thanks again!
                        Charles
                          @t3p3tony
                          In fact on closer inspection, when the bed fault comes on the bed stops heating
                            @charles-fraser
                            I would expect a report something like this in the DWC console when the bed hater faults:
                            Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
                            To tune the bed the documentation is here:
                            https://duet3d.dozuki.com/Wiki/M303
                            an example is
                            M303 H0 P1 S60
                            Send this in the console - it will take a while to run and you will see the temp cycle. once its finished the send M500 in the console to save the results to config-override.g
                            We can also look at XY endstops (Z probe is out the picture for now as you said)
                            With the Axis not at their limits where the ends tops are send M119 from the console and see what is reported. Then with each of the endstops triggered in turn, send M119 while they are triggered and see the response in the console.
                              @t3p3tony
                              Thanks, there is no report of error in terminal re noz heat failure:
                              I have completed PID tuning and I get (pls NB this is a mattress sized heated bed in a breezy tent!):
                              28/10/2021, 15:19:45	Edit the M307 H0 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.
                              28/10/2021, 15:19:45	Auto tuning heater 0 completed after 3 idle and 25 tuning cycles in 6627 seconds. This heater needs the following M307 command:
                               M307 H0 B0 R0.138 C790.6 D13.87 S1.00 V24.0
                              28/10/2021, 15:19:44	Warning: heater behaviour was not consistent during tuning
                              28/10/2021, 13:51:14	Auto tune starting phase 4, tuning with fan off
                              28/10/2021, 13:37:00	Auto tune starting phase 3, heating system settling
                              28/10/2021, 13:29:22	Auto tune starting phase 2, heating up
                              28/10/2021, 13:29:18	M303 H0 P1 S60
                              Auto tuning heater 0 using target temperature 60.0°C and PWM 1.00 - do not leave printer unattended
                                @t3p3tony
                                When I send M500 I get
                                28/10/2021, 16:15:14	M500
                                Warning: M500: No M501 command was executed in config.g
                                  @charles-fraser said in Large Format Dowell to Duet conversion:
                                  For now replace the M307 H0 command in config.g with that command, except change to bang bang
                                  M307 H0 B1 R0.138 C790.6 D13.87 S1.00 V24.0
                                  Charles Fraserundefined 3 Replies Last reply Reply Quote 0
                                    @charles-fraser thats fine for now. we can enable config-override later.
                                      @t3p3tony said in Large Format Dowell to Duet conversion:
                                      okay thanks it syas
                                      28/10/2021, 16:18:02	M307 H0 B1 R0.138 C790.6 D13.87 S1.00 V24.0
                                      Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 134C
                                        Oh wait I added that as a command in the console
                                        How do I change to bangbang?
                                        Just add this?
                                          @t3p3tony
                                          Like this?)
                                          M308 S0 P"1.temp0" Y"PT1000"
                                          M950 H0 C"1.out0" T0
                                          M307 H0 B1 R0.138 C790.6 D13.87 S1.00 V24.0                   ; enable bang-bang mode for the bed heater and set PWM limit
                                          M140 H0                                                         ; map heated bed to heater 0
                                          M143 H0 S80                                                    ; set temperature limit for heater 0 to 80C
                                          M308 S1 P"1.temp1" Y"PT1000"                                    ; configure sensor 1 as thermistor on pin temp0
                                          M950 H1 C"1.out1" T1                                              ; create nozzle heater output on out1 and map it to sensor 1
                                          M307 H1 B0 S1.00                                                ; disable bang-bang mode for heater  and set PWM limit
                                          M143 H1 S300                                                    ; set temperature limit for heater 1 to 300C
                                            @charles-fraser yes that looks good.
