BLTouch will not deploy with M401
1.2k
    Inno 3D
    I have a Problem with my BLTouch. It will not deploy!
    I have checked the wiring. It is definitely connected right.
    I have not a config-override.g file inside the system. I have also updatet the firmware to the latest release 3.3.
    With the M401 Code, the BLTouch will not deploy. Do you have any Idea, why?
    Thanks for your help!
    Config.g
    ; Configuration file for Duet WiFi (firmware version 3.3)
    ; generated by RepRapFirmware Configuration Tool v3.3.5 on Fri Oct 29 2021 19:26:34 GMT+0200 (Mitteleuropäische Sommerzeit)
    M550 P"Printer" ; set printer name
    M551 P"*****" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P7 R0 S0 T3.33:3.33:5:0 ; physical drive 0 goes forwards
    M569 P8 R0 S0 T3.33:3.33:5:0 ; physical drive 1 goes forwards
    M584 X8 Y7 Z2 E3 ; set drive mapping
    M350 X16 Y16 Z64 I0 ; configure microstepping without interpolation
    M350 E16 I1 ; configure microstepping with interpolation
    M92 X100.00 Y200.00 Z1280.00 E418.50 ; set steps per mm
    M906 X1400 Y1400 Z1400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X610 Y610 Z600 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
    M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
    M950 S0 C"exp.heater6" ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    M557 X15:595 Y15:595 S20 ; define mesh grid
    M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
    M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
    Board ID: 0JD0M-9P6M2-NW4SN-6J9DG-3SJ6N-TAU7K
    Used output buffers: 3 of 24 (11 max)
    Static ram: 23876
    Dynamic ram: 74972 of which 0 recycled
    Never used RAM 15568, free system stack 184 words
    Tasks: NETWORK(ready,10.5%,252) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.4%,443) IDLE(ready,4.1%,29), total 100.0%
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:00:24 ago, cause: power up
    Last software reset at 2021-10-30 15:37, reason: User, GCodes spinning, available RAM 15568, slot 2
    Error status: 0x00
    Aux0 errors 0,0,0
    Step timer max interval 0
    MCU temperature: min 30.9, current 32.6, max 32.8
    Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: position 0, standstill, SG min/max not available
    Driver 1: position 0, standstill, SG min/max not available
    Driver 2: position 0, standstill, SG min/max not available
    Driver 3: position 0, standstill, SG min/max not available
    Driver 4: position 0, standstill, SG min/max not available
    Driver 5: position 0
    Driver 6: position 0
    Driver 7: position 0
    Driver 8: position 0
    Driver 9: position 0
    Driver 10: position 0
    Driver 11: position 0
    Date/time: 2021-10-30 15:58:50
    Cache data hit count 897316776
    Slowest loop: 6.52ms; fastest: 0.16ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 4.1ms, write time 0.0ms, max retries 0
    === MainDDARing ===
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 16.07ms; fastest: 0.00ms
    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is active
    WiFi firmware version 1.23
    WiFi MAC address e0:98:06:a4:5f:af
    WiFi Vcc 3.34, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 24368
    WiFi IP address 192.168.178.116
    WiFi signal strength -50dBm, mode none, reconnections 0, sleep mode modem
    Clock register ffffffff
    deployprobe.g
    ; deployprobe.g
    ; called to deploy a physical Z probe
    M280 P0 S10 ; deploy BLTouch
    retractprobe.g
    ; retractprobe.g
    ; called to retract a physical Z probe
    M280 P0 S90 ; retract BLTouch
    undefined undefined undefined 3 Replies Last reply 30 Oct 2021, 14:34 Reply Quote 0
      Inno 3D @T3P3Tony
      @t3p3tony yes, I saw the solution at the other thread.
      Many Thanks @T3P3Tony and @Gixxerfast !!!
      This solved my Problem!
        T3P3Tony administrators @Inno 3D
        @inno-3d
        Your configuration looks correct. Does the BL touch carry out its self test when powered on?
        I know you have checked the wiring but please share a photograph.
        undefined 1 Reply Last reply 30 Oct 2021, 15:15 Reply Quote 0
          Inno 3D @T3P3Tony
          @t3p3tony yes, the bltouch does its self test when powered on.
          20211030_171245.jpg 20211030_171111.jpg ![20211030_171132.jpg](/assets/uploads/files/1635606877270-
          undefined 1 Reply Last reply 30 Oct 2021, 15:16 Reply Quote 0
            Inno 3D @Inno 3D
            undefined 1 Reply Last reply 30 Oct 2021, 15:21 Reply Quote 0
              @inno-3d that looks correct as well.
              What happens when you send
              M280 P0 S10
              Directly?
              undefined 1 Reply Last reply 30 Oct 2021, 15:39 Reply Quote 0
                Inno 3D @T3P3Tony
                @t3p3tony nothing happend!
                Do you have another idea?
                Many Thanks for your help!
                undefined 1 Reply Last reply 30 Oct 2021, 15:50 Reply Quote 0
                  JoergS5 @Inno 3D
                  @inno-3d said in BLTouch will not deploy with M401:
                  one thing to mention is that your setting are ((595-15)/20+1)*((595-15)/20+1)= 30 * 30 points = 900 points, which are more than the 441 allowed.
                  And the G31 P500 X0 Y0 Z2.5 the XY offsets are probably incorrect (unless the BLTouch is at the nozzle position).
                  undefined 1 Reply Last reply 30 Oct 2021, 15:55 Reply Quote 0
                    @inno-3d that port on the expansion breakout board is at 5V signalling level so should be fine with even older BL touches. Can you try the other PWM port on the expansion break out board (heater 6)
                    undefined 1 Reply Last reply 30 Oct 2021, 15:56 Reply Quote 0
                      Inno 3D @JoergS5
                      @joergs5 Yes this is right. I haven not changed the settings yet, becuase first I would like to home the printer.
                      undefined 1 Reply Last reply 30 Oct 2021, 15:57 Reply Quote 0
                        Inno 3D @T3P3Tony
                        @t3p3tony I have tested it with the other port, but there was the same result.
                        undefined 1 Reply Last reply 30 Oct 2021, 16:04 Reply Quote 0
                          JoergS5 @Inno 3D
                          This post is deleted!
                            JoergS5 @Inno 3D
                            @inno-3d the core at the top of the BLTouch (allen key rotatable) needs correct position, is the pin movable?
                            https://cdn-3d.niceshops.com/upload/file/BLTouch_Manual.pdf page 3 image at bottom.
                            undefined 1 Reply Last reply 30 Oct 2021, 16:11 Reply Quote 0
                              Inno 3D @JoergS5
                              @joergs5 The BLTouch should work fine. At the start, the BLTouch does it's self test.
                              The BLTouch worked at another borad fine. So i think, that is not the problem.
                                JoergS5
                                @inno-3d I have no more ideas, only rechecking wiring, and using only the mainboard pins.
                                undefined 1 Reply Last reply 31 Oct 2021, 11:49 Reply Quote 0
                                  Inno 3D @JoergS5
                                  @joergs5 Ok, thanks for your help!
                                  undefined 1 Reply Last reply 31 Oct 2021, 18:37 Reply Quote 0
                                    Alex.cr @Inno 3D
                                    @inno-3d
                                    I’ve had a similar issue where the BLtouch would not deploy even though everything was set up correctly. My issue turned out to be the stepper motor cables creating noise on the servo wire and interfering with communication to the BLtouch.
                                    Have you tried sending M401 with the stepper motors disabled vs with them powered on?
                                    Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                                      @inno-3d I see you started another thread, I had not noticed that the port should be inverted with the EBOB, as @Gixxerfast suggested on the other thread, try adding a ! to invert the pin definition:
                                      M950 S0 C"!exp.heater6"
                                      undefined 1 Reply Last reply 1 Nov 2021, 11:27 Reply Quote 0
                                        Inno 3D @T3P3Tony
                                        10 out of 18
