Lines on LCD
@modix2021 yes the LCD screen is faulty and needs replacing.
@t3p3tony
Modix is sending one. Any idea why my wifi and LCD would mess up at the same time? Then wifi came back whether or not the faulty LCD was connected. Hoping to learn how to keep this from happening again. Will have been down for a month sorting this out.
You have been most helpful when I post.
L -
@modix2021 I have also seen lines like that when the voltage on the 5V rail is too low.
@dc42 Thank you. Would that happen spontaneously after months and months of intermittent use or soon after installation? We've been good for quite a while then wham.
@modix2021 said in Lines on LCD:
No, unless something else in the system has caused the 5V rail voltage to drop.
If the problem is caused by the 5V rail being low, then pressing the reset button on the PanelDue sometimes gets the display working. The reset button is behind the hole to the right of the screen that is not close to the USB port. Don't push the button near to the USB port - that erases the PanelDue firmware!
Thank you. I'll try that.
L -
I see what looks like a button with Reset above it. Is that it? I also see a button with Erase above it.
Obviously that is not the correct button. I can post a picture of the front of the unmounted PanelDue
is that helps.
L -
@modix2021 the one with reset
@jay_s_uk
Thank you!
L -
@jay_s_uk
Well, same result. Vertical line patterns as before.
So I guess this LCD is toast.
Thank you for that information. Could come in handy in the future.
L -
@t3p3tony
LLikely that the Duet and PanelDue were damaged at the same time from shorting 24v to 3.3v or 5v.
