    Rotating Magnetic Sensor - Keeps Pausing Printer
    Filament Monitor
    9
    151
    9.5k
    • alankilianundefined
      alankilian @T3P3Tony
      @t3p3tony
      Here's the test file: CalciumCup.gcode
      I'll adjust and try printing a few more times on Monday.
      My sensor is just below the extruder and moves around a little bit with the bowden movement.
      I should probably move it above the extruder.
      I'll also try that on Monday after getting the AGC in a better range.
        alankilian @dc42
        Unfortunately, I can't get the AGC under about 115 without the pointy-bits of the brass roller starting to scratch the surface of the sensor chip and not moving all the time.
        You mentioned stronger magnets. Are they available?
        Otherwise I may try sanding the top surface of the sensor chip a little.
        I figure there's enough plastic above the sensor I can get the tiny amount of space I need to get a better AGC value.
          T3P3Tony administrators @alankilian
          @alankilian yes if you drop me a line (info@duet3d.com) i can look at arranging a replacement assembly.
          • wouldstainundefined
            wouldstain @T3P3Tony
            @t3p3tony im actually still running 3.3 but I will upgrade today to 3.4b5 and 3.4b5+1 progressively.
            I just wanted to confirm the file(s) I needed. Should I be using the combined version?
            thank you!
              T3P3Tony administrators @wouldstain
              @wouldstain the instructions i posted above for alankilian should work for you if you are using Duet 2. do Duet 3 substitute the appropriate firmware binary for your board.
                T3P3Tony administrators @T3P3Tony
                I have done a quite a few tests now and over the short print snippets I have been using I have got consistently good results (wider window than 90%-105%) until PA gets greater than 0.4, with higher pressure advance i see drops down to 70% but still nothing like the 10%, 0% -n% that we were seeing before.
                I have more tests to do with different retraction distances and print speeds but this is looking very promising. I would be interested in gcode files (preferably short!) that still get poor results with the new build of firmware (3.4b5+1) where all other factors are limited (i.e. good mag readings, short filament path between the extruder and the sensor).
                wouldstainundefined 1 Reply Last reply Reply Quote 0
                  @t3p3tony Updated firmware and DWC as requested. Printed up a batch of those drywall anchors today with no problem out of PETG.
                  As soon as I switched to PLA it started happening again:
                  Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 130 agc 75, measured sensitivity 30.28mm/rev, min 0% max 121% over 97.7mm
                  m572 d0
                  Extruder pressure advance: 0.070
                  PLA_Test-xyzCalibration_cube.gcode
                  Ran again:
                  m591 d0
                  Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 130 agc 75, measured sensitivity 40.48mm/rev, min -1% max 154% over 33.8mm
                  T3P3Tonyundefined dc42undefined 3 Replies Last reply Reply Quote 0
                    @wouldstain thanks for the report.
                    Other than the temperature is the only difference between your PETG prints and PLA prints the pressure advance?
                    You may have already posted it but please post your config.g so i can use those settings in my test.
                      dc42 administrators @wouldstain
                      @wouldstain is the only difference between the PLA and PETG prints is the hot end and bed temperatures? If so, then it's likely that your extruder is skipping steps or losing its grip on the filament, and the filament monitor is reporting correctly. PLA is harder for the extruder to push through the nozzle then PETG is.
                      You could test this by printing at a high temperature, to make it easier for the extruder to push the filament through. It may result in rubbish print quality, but if it improves the filament monitor readings then it will have identified the problem.
                        @wouldstain also what results were you getting with PETG on the drywall insert?
                        Also looking at the PLA gcode you share, you are printing it at 235C.. have you had success with that temp for PLA in the past?
                          @t3p3tony I have had good results with PLA at higher temps.
                          I have tried printing at lower temps. the only difference on test / calibration prints seems to be the strength of interlayer adhesion.
                          I can certainly dial it down if you think it would make a difference.
                            wouldstain @dc42
                            @dc42 I normally have higher retraction distance and speed settings to reduce stringing on PETG, so aside from decreasing both while using PLA, really no difference.
                            I've tried printing PLA with higher temps (accounting for either toolsteel or hardened steel nozzle) but it doesnt seem to matter.
                            @JohnOCFII has the following in his prusa config:
                            {if printer_notes=~/.PRINTER_VENDOR_PRUSA3D./}M900 K45{else}M572 D0 S0.06{endif} ; Filament-specific Linear Advance or Pressure Advance
                            but I've also tried slicing with this commented out and gotten the same results.
                              @t3p3tony
                              about to run test @250C. Will post console output (assuming it pauses)
                              config.g attached. modified slightly from previous to account for addition of garolite sheet on build plate.
                              WS_110321_config.g
                                @wouldstain said in Rotating Magnetic Sensor - Keeps Pausing Printer:
                                no i don't - that was just an question seeing it at 235.
                                  @t3p3tony gotcha.
                                  Just ran it at 250C. got this at less than 6%:
                                  Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 130 agc 75, measured sensitivity 26.29mm/rev, min 1% max 107% over 136.1mm
                                  same cube.
                                    @wouldstain I printed that on the test rig:
                                    That was before I got your config so i need to change to your config.
                                    Can you try printing one of the drywall anchors in PLA with the PLA settings to see if you get the same issue (trying to see if its related to the PA/retract settings which are different). Also a short print to recreate the issue would be good.
                                    T3P3Tonyundefined wouldstainundefined 3 Replies Last reply Reply Quote 0
                                      I also need to switch the test rig back to Duet 2 from Duet 3 mini.
                                        @t3p3tony
                                        Drywall anchor @ 250C:
                                        Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 130 agc 75, measured sensitivity 219.24mm/rev, min 6% max 128% over 19.5mm
                                        only got about 2% into it before stopping.
                                        PLA_250C_Drywall_Anchor.gcode
                                        FYI also have PETG printing at -.15 offset via babysteps so I did reset it for PLA.
                                          alankilian @wouldstain
                                          @wouldstain
                                          My printer has (0,0) in the center.
                                          Is there an easy way for me to provide an offset so I can try printing your .gcode?
                                          Or can you slice it centered on (0,0) for me to test with?
                                          wouldstainundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                            wouldstain @alankilian
                                            @alankilian
                                            Not sure how that would be possible as slicer is set up for my railcore rig.
                                            Center is somewhere around 150,150.
