    Large Format Dowell to Duet conversion
    362
    36.0k
    • Charles Fraserundefined
      Charles Fraser @T3P3Tony
      @t3p3tony
      Thank you Tony, I stupidly seem to have forgotten the thermistor. If I use the thermistor that came with the extruder it's a NTC 100k. Is that easily copatible if I just change the code please? Many thanks
        T3P3Tony administrators @Charles Fraser
        @charles-fraser oops sorry i meant the PT1000 that you have bought to replace the thermistor! I thought we had determined that the extruder thermistor was faulty way earlier in this thread?
        Charles Fraserundefined 1 Reply Last reply Reply Quote 0
          @t3p3tony
          No we didnt establish that thermistor was faulty,I just didn't know what kind it was. It's type 13 in marlin, that's the type listed above. Can we edit the config.g file to use this one please?
            @charles-fraser said in Large Format Dowell to Duet conversion:
            type 13 in marlin
            13 : 100kΩ Hisens up to 300°C - for "Simple ONE" & "All In ONE" hotend - beta 3950, 1%
            https://github.com/MarlinFirmware/Marlin/blob/2.0.x/Marlin/Configuration.h
            So
            M308 S1 P"1.temp1" Y"thermistor" T100000 B3950
            this is plugging it into port temp1 on the 3HC (which you currently have setup for the PT1000 on the hotend.
            Charles Fraserundefined 3 Replies Last reply Reply Quote 0
              @t3p3tony
              Thanks, regarding PID autotune: when the extruder is extruding pellets at full flow rate through a 3mm nozzle the heating characteristics are very different then when just sat idle. Is there a way to autotune while the extruder is extruding please?
              Regarding endstops: is this okay? The z switch is so that if the bed comes so close to the nozzle and starts to push against it the switch is closed and the z motion should stop
              M574 X1 S1 P"io1.in"                                            ; configure active-high endstop for low end on X via pin io1.in
              M574 Y1 S1 P"io2.in"                                            ; configure active-high endstop for low end on Y via pin io2.in
              M574 Z1 S1 P"io0.in"
              For the z probe I have.
              M558 P9 C"^1.io1.in" H100 F120 T6000                            ; set Z probe type to switch and the dive height + speeds
              G31 P500 X0 Y0 Z2.5                                             ; set Z probe trigger value, offset and trigger height
              M556 S50 X0 Y0 Z0                                               ; set orthogonal axis compensation parameters
              M557 X15:215 Y15:195 S20                                        ; define mesh grid
              if I want to change it to io3 on the 6HC should I change it to
              M558 P9 C"^0.io3.in" H100 F120 T6000
                @t3p3tony
                Great that is working well and PID tuning now.
                  @t3p3tony
                  Just for the record
                  	Edit the M307 H1 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.
                  03/11/2021, 13:42:50	Auto tuning heater 1 completed after 3 idle and 30 tuning cycles in 1842 seconds. This heater needs the following M307 command:
                   M307 H1 B0 R1.465 C296.7:296.7 D8.30 S1.00 V24.0
                  03/11/2021, 13:42:49	Warning: Turning on the print cooling fan did not increase hot end cooling. Check that the correct fan has been configured.
                  03/11/2021, 13:38:35	Auto tune starting phase 5, tuning with fan on
                  03/11/2021, 13:38:34	Warning: heater behaviour was not consistent during tuning
                  03/11/2021, 13:18:05	Auto tune starting phase 4, tuning with fan off
                  03/11/2021, 13:14:58	Auto tune starting phase 3, heating system settling
                  03/11/2021, 13:12:11	Auto tune starting phase 2, heating up
                  03/11/2021, 13:12:07	M303 T0 S200
                  Auto tuning heater 1 using target temperature 200.0°C and PWM 1.00 - do not leave printer unattended
                  I have now wired the two fans either side of the pellet loading chamber in parallelp to out8 on the 6HC. I can't here it idling however. Maybe I should swap polarity.
                  Is it possible to wire the 3D touch to the 3HC as the wires can't reach the 6HC where it is?
                  For reference:
                  Configuration file for Duet 3 (firmware version 3.3)
                  ; generated by RepRapFirmware Configuration Tool v3.3.3 on Fri Oct 01 2021 16:59:54 GMT+0100 (British Summer Time)
                  G90                                                             ; send absolute coordinates...
                  M83                                                             ; ...but relative extruder moves
                  ; Wait a moment for the CAN expansion boards to start
                  G4 S2
                  M569 P0.0 S1                                                    ; physical drive 0.0 goes forwards
                  M569 P0.1 S1                                                    ; physical drive 0.1 goes forwards
                  M569 P0.2 S0                                                    ; physical drive 0.2 goes forwards
                  M569 P0.3 S0                                                    ; physical drive 0.3 goes forwards
                  M569 P0.4 S0                                                    ; physical drive 0.4 goes forwards
                  M569 P0.5 S0                                                    ; physical drive 0.5 goes forwards
                  M569 P1.0 S1                                                    ; physical drive 1.0 goes forwards
                  M584 X0.0 Y0.1 Z0.2:0.4:0.5:0.3 E1.0
                  M350 X16 Y128 Z16 E16  I1                                ; configure microstepping with interpolation
                  M92 X80.00 Y1280.00 Z1926.00 E420.00          ; set steps per mm
                  M566 X900.00 Y900.00 Z60.00 E120.00        ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z500.00 E1200.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00 E250.00        ; set accelerations (mm/s^2)
                  M906 X2800 Y2800 Z1200 E1200 I30                      ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                                         ; Set idle timeout
                  M208 X0 Y0 Z0 S1                                                ; set axis minima
                  M208 X1200 Y2000 Z1600 S0                                       ; set axis maxima
                  M308 S0 P"1.temp0" Y"PT1000"
                  M950 H0 C"1.out0" T0
                  M307 H0 B1 R0.138 C790.6 D13.87 S1.00 V24.0                   ; enable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                                         ; map heated bed to heater 0
                  M143 H0 S80                                                    ; set temperature limit for heater 0 to 80C
                  M308 S1 P"1.temp1" Y"thermistor" T100000 B3950                                    ; configure sensor 1 as thermistor on pin temp0
                  M950 H1 C"1.out1" T1                                              ; create nozzle heater output on out1 and map it to sensor 1
                  M307 H1 B0 S1.00                                                ; disable bang-bang mode for heater  and set PWM limit
                  M143 H1 S300                                                    ; set temperature limit for heater 1 to 300C
                  M950 F0 C"out8" Q500                                            ; create fan 0 on pin out8 and set its frequency
                  M106 P0 S0 H T45                                                ; set fan 0 value. Thermostatic control is turned on
                  M950 F1 C"out9" Q500                                            ; create fan 1 on pin out9 and set its frequency
                  M106 P1 S1 H-1                                                  ; set fan 1 value. Thermostatic control is turned off
                  M563 P0 S"lily" D0 H1 F0:1                                      ; define tool 0
                  G10 P0 X100 Y100 Z0                                             ; set tool 0 axis offsets
                  G10 P0 R0 S0                                                    ; set initial tool 0 active and standby temperatures to 0C
                    @t3p3tony the fans are not working. Not sure why I’ve tried reversing the poles
                      M307 H1 B0 R1.465 C296.7:296.7 D8.30 S1.00 V24.0 03/11/2021, 13:42:49 Warning: Turning on the print cooling fan did not increase hot end cooling. Check that the correct fan has been configured.
                      You may need to re run the tuning after fixing the issues below.
                      M106 P0 S0 H T45
                      this is wrong. I assume the fans on out8 are to cool the pellet extruder itself (not the print) in the same manner as a hotend cooling fan that cools the cold side of a heatbreak on a filament hotend? In that case this should be:
                      M106 P0 H1 T45
                      This tells the Duet that when heater sensor 1 gets over 45C, turn on fan0. It wont be on until the hotend sensor goes over 45C
                      The print cooling fan is ok, assuming you have it plugged into out 9
                      however the fan associations for the tool are not right:
                      should be
                      M563 P0 S"lily" D0 H1 F1
                      as the tool is associated with the print cooling fan (the otehr fan is alsready assoicated with the heater.
                      Charles Fraserundefined 7 Replies Last reply Reply Quote 0
                        @t3p3tony
                        Okay the "heat-break" fans are working well now. The print cooling fan is not working even if I turn the 'TOOL FAN' slider up to 100 and switch polarity of the wires. Maybe it needs to actually be printing for that to come on?
                        okay next I am gonna keep rewiring this BL touch
                        droftartsundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                          @t3p3tony
                          Oh Quick question: Is it possible to do a PID tuning while extruding because this extruder pushes out so much material it will need a different heating tuning I recon to make it work best. Also which line is the steps per mm of extruded material please? The Extruder has a 20:1 gear NEMA17 that needs to spin jolly fast to get that screw moving around.
                            @t3p3tony PS: is there no way to wire the 3D touch to the 3HC? Cables just don’t reach the 6HC
                              droftarts administrators @Charles Fraser
                              https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Caution
                              Caution
                              Fans are polarised. When connecting a fan to a fan connector, the positive wire (usually red) must be connected to the VFAN pin of that connector. The negative wire (normally black) must be connected to the FAN- pin if it is a controlled fan connector, or the GND pin if it is an always-on fan connector.
                              If you connect the fan the wrong way round, you may damage the fan, the Duet, or both.
                                @t3p3tony
                                I’m sorry it’s a bit of a fudge but I have only been able to get the 3D touch wired up (I hope correctly) with the 3HC, IO_2
                                Here is what the wiring from the touch is supposed to be:
                                But the 3D touch I have does not have a white wire, it has a blue wire though so I am guessing that’s the only difference.
                                I have to connect the BL touch to two different cables, each with four wires in them to reach the board at the other end of the printer. In one of the cables, two of the wires are already used by the NTC thermistor so it looks like this:
                                Then I can only reach IO_2 on the 3H with all that following this diagram:
                                Which looks like this:
                                I hope that’s correct! I’ll try to change the code and hope it works!
                                T3P3Tonyundefined Charles Fraserundefined 2 Replies Last reply Reply Quote 0
                                  @t3p3tony
                                  WOAH! All I did was change the IO_1 to IO_2 in the config file and now so many errors and the heaters missing and things:
                                  G4 S2
                                  M558 P9 C"^1.io2.in" H100 F120 T6000                            ; set Z probe type to switch and the dive height + speeds
                                  M106 P0 H1 T45                                             ; set fan 0 value. Thermostatic control is turned on
                                  03/11/2021, 17:00:56	Error: M143: Heater 1 does not exist
                                  03/11/2021, 17:00:56	Error: M307: Heater 1 not found
                                  03/11/2021, 17:00:56	Error: M950: Response timeout: CAN addr 1, req type 6026, RID=12
                                  03/11/2021, 17:00:53	Error: M308: Response timeout: CAN addr 1, req type 6031, RID=10
                                  03/11/2021, 17:00:51	Error: M307: Heater 0 not found
                                  03/11/2021, 17:00:51	Error: M143: Heater 0 does not exist
                                  03/11/2021, 17:00:51	Error: M950: Response timeout: CAN addr 1, req type 6026, RID=8
                                  03/11/2021, 17:00:50	Error: M308: Response timeout: CAN addr 1, req type 6031, RID=6
                                  03/11/2021, 17:00:47	Error: G31: Invalid Z probe index
                                  03/11/2021, 17:00:47	Error: M558: Response timeout: CAN addr 1, req type 6036, RID=5
                                  03/11/2021, 17:00:46	Error: Invalid remote handle
                                  03/11/2021, 17:00:46	Error: M906: Response timeout: CAN addr 1, req type 6043, RID=4
                                  03/11/2021, 17:00:45	Error: M92: Response timeout: CAN addr 1, req type 6042, RID=3
                                  03/11/2021, 17:00:45	Error: M350: Response timeout: CAN addr 1, req type 6042, RID=2
                                  03/11/2021, 17:00:45	Error: M584: Response timeout: CAN addr 1, req type 6042, RID=1
                                  03/11/2021, 17:00:44	Error: M569: Response timeout: CAN addr 1, req type 6018, RID=0
                                  03/11/2021, 17:00:39	Connection established
                                  03/11/2021, 17:00:32	Connection interrupted, attempting to reconnect...
                                  03/11/2021, 17:00:30	Emergency stop, attemping to reconnect...
                                  03/11/2021, 16:58:33	Error: M307: Heater 1 not found
                                  03/11/2021, 16:58:33	Error: M143: Heater 1 does not exist
                                  03/11/2021, 16:58:33	Error: M950: Response timeout: CAN addr 1, req type 6026, RID=12
                                  03/11/2021, 16:58:30	Error: M308: Response timeout: CAN addr 1, req type 6031, RID=10
                                  03/11/2021, 16:58:28	Error: M143: Heater 0 does not exist
                                  03/11/2021, 16:58:28	Error: M307: Heater 0 not found
                                  03/11/2021, 16:58:28	Error: M950: Response timeout: CAN addr 1, req type 6026, RID=8
                                  03/11/2021, 16:58:26	Error: M308: Response timeout: CAN addr 1, req type 6031, RID=6
                                  03/11/2021, 16:58:24	Error: G31: Invalid Z probe index
                                  03/11/2021, 16:58:24	Error: M558: Response timeout: CAN addr 1, req type 6036, RID=5
                                  03/11/2021, 16:58:23	Error: Invalid remote handle
                                  03/11/2021, 16:58:23	Error: M906: Response timeout: CAN addr 1, req type 6043, RID=4
                                  03/11/2021, 16:58:21	Error: M92: Response timeout: CAN addr 1, req type 6042, RID=3
                                  03/11/2021, 16:58:20	Error: M350: Response timeout: CAN addr 1, req type 6042, RID=2
                                  03/11/2021, 16:58:19	Error: M584: Response timeout: CAN addr 1, req type 6042, RID=1
                                  03/11/2021, 16:58:18	Error: M569: Response timeout: CAN addr 1, req type 6018, RID=0
                                  03/11/2021, 16:58:16	Connection established
                                    @t3p3tony
                                    The 3HC is not being seen any more. It no longer flashes the amber light in time with the 6HC
                                    When I send M115 B1 it just spins forever
                                      @t3p3tony
                                      I removed the 3D touch. Still Only the lily hotend shows now. No bed, no temps. WTF!!
                                        no it does not need to be printing. try connecting the fan directly to +24V and ground to test it works (assuming its a 24V fan).
                                        no - but we do plan to add extrusion look ahead in future versions of the firmware.
                                        the E value in this:
                                        you should connect it to the same board as the Z motors are on for now:
                                        https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
                                        Due to CAN latency the motors connected to expansion boards may slightly overshoot the position at which the endstop or Z probe was triggered. This would not usually matter for an endstop switch, but it does mean that if the Z motor(s) is/are connected to an expansion board then repeated probing with a Z probe (e.g. for mesh bed compensation) is not advisable. This will be fixed in a future release
                                        when you lose communication with the 3HC then you will lose communication with everything on that board.
                                        Try undoing the changes you made to config.g and then reset everything (without the 3d touch installed). Unless that damaged the board it should all come back up.
                                          @t3p3tony
                                          I undid the changes and unplugged the 3D touch and it still does not work. How can even wiring up one io wrong fry the whole board?
                                          I noticed, before all this crashed, the print cooling fan was spinning but hardly getting going then stopping again.
                                            unplug this as well - the power cycle the power to both the 6HC and the 3HC. Run M98 P"0:sys/config.g" to verify the changes are undone.
