    ESP8266 NeoPixel Driver
    Accessories and Add-ons
    671
      dc42 administrators @pfn
      @pfn the PanelDuet Rx input is 5V tolerant, but the PanelDue Tx and Rx pins on the Duet are not.
      pfnundefined 1 Reply Last reply Reply Quote 0
      • pfnundefined
        pfn @dc42
        @dc42 that's interesting it hasn't caused any problems on users of this arduino sketch, I wonder why, or is it a slow spiral of death for them 😄
          deckingman @pfn
          @pfn I'm a bit confused. You started out saying that you use a Wemos D1 mini but then go on to talk about an Arduino. I'm fairy sure that the logic pins on D1 Minis are 3.3v so I don't understand the bit about 5V.
          • pfnundefined
            pfn @deckingman
            @deckingman there is a previous arduino based solution that does a similar function and is wired the same way. Metering it shows that the rx pin is driven high to 4.5v.
            There's also stuff like a cnc pendant that also uses arduino and operates similarly.
            deckingmanundefined dc42undefined 2 Replies Last reply Reply Quote 0
              deckingman @pfn
              @pfn said in ESP8266 NeoPixel Driver:
              Now I'm even more confused. Is this a topic about about using an ESP8266 NeoPixle Driver using Wemos D1 mini as the title and first sentence suggest, or is it about Arduinos or something else?
              • pfnundefined
                pfn @deckingman
                @deckingman this is about esp8266 replacing an arduino solution. (Edited original post to clarify)
                  The CNC pendant that I describe at https://github.com/Duet3D/CNC-Pendant-Firmware used a potential divider on the Arduino TxD output to reduce the voltage level.
                  • pfnundefined
                    pfn @dc42
                    @dc42 ah, it's not a concern with the cnc pendant because the arduino only connects to the duet through tx and that has a voltage divider on it
                    PCRundefined 1 Reply Last reply Reply Quote 0
                    • PCRundefined
                      PCR @pfn
                      @BLV Something for your Project?;)
                      • madedi123undefined
                        madedi123
                        Hello
                        My problem is that my pendant (the same as david's, with an arduino micro) only sends the M112 command, but does not perform any movement via the encoder. My hardware is a DUET3 6HC with SBC and without Panel DUE, Configuration CNC. The arduino sketch was uploaded with firmware 1.8.1 thank you for your help
                        1 Reply Last reply Reply Quote -1
