    BLtouch probe pin does not deploy
    461
    • imonseiundefined
      imonsei
      I cannot get the "M280 P0 S10" and "M280 P0 S160" commands working. (nor M401)
      I'm amost done assembling my Ratrig V-core 3, and I'm stumbling over this last hurdle, before I can begin stumbling over printer calibration ๐Ÿ˜„
      The board is a Duet 3 MB6HC.
      I use the ethernet connection standalone webinterface to interface with the board.
      The probe does go through the self test on power on.
      Below is the wiring of my BLtouch (original)
      The probe is connected to my io2 port on the board.
      This is the BLTouch relevant part of my config.g
      ;; BLTouch
      M950 S0 C"io2.out"                     ; Create a servo pin on io2
      M558 P9 C"io2.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
      ;M558 P9 C"io6.in" F150 H4 R0.2 T12000 A5 B0
      G31 P25 X-28.00 Y-13.00 Z0.90          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      I do have a deployprobe.g and a retractprobe.g with the relevant M280 commands. (but those shouldn't be relevant for me sending a M280 command manually)
      Other than that I have not changed any config.
      Steps I have tried:
      Two different sets of wires, and both times ensured the connections were good with a multimeter.
      Connecting a different BLTouch, which didn't get the command either.
      Connecting the wires to io6, and changing the config.g from io2 to io6.
      Disconnecting the motor for the filament.
      Is there something you can suggest for me to try?
      PCRundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • PCRundefined
        PCR @imonsei
        @imonsei can you run M98 P"config.g" and post the poutput
        imonseiundefined 1 Reply Last reply Reply Quote 0
        • imonseiundefined
          imonsei @PCR
          @pcr said in BLtouch probe pin does not deploy:
          M98 P"config.g"
          sure thing
          M98 P"config.g"
          Error: Height map file 0:/sys/heightmap.csv not found
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 470C
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 302C
          PCRundefined 1 Reply Last reply Reply Quote 0
          • PCRundefined
            PCR @imonsei
            @imonsei running latest 3.3 stable?
            • imonseiundefined
              imonsei @PCR
              @pcr yes sir. its the one it shipped with. "Duet Web Control 3.3.0" is what it says in Settings->General
              • PCRundefined
                PCR @imonsei
                @imonsei please send M122
                • imonseiundefined
                  imonsei @PCR
                  M122
                  M122
                  RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                  Board ID: 08DJM-956BA-NA3TJ-6J9DJ-3SD6R-1996T
                  Used output buffers: 1 of 40 (11 max)
                  Static ram: 150904
                  Dynamic ram: 91940 of which 112 recycled
                  Never used RAM 111236, free system stack 208 words
                  Tasks: NETWORK(ready,30.1%,212) ETHERNET(notifyWait,0.1%,117) HEAT(notifyWait,0.0%,331) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,343) TMC(notifyWait,7.4%,93) MAIN(running,61.6%,924) IDLE(ready,0.8%,29), total 100.0%
                  Owned mutexes:
                  Last reset 00:00:13 ago, cause: power up
                  Last software reset at 2021-11-19 12:36, reason: User, GCodes spinning, available RAM 111236, slot 1
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                  Error status: 0x00
                  Step timer max interval 126
                  MCU temperature: min 17.1, current 24.8, max 24.8
                  Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                  Driver 0: position 0, standstill, reads 6291, writes 15 timeouts 0, SG min/max 0/0
                  Driver 1: position 0, standstill, reads 6291, writes 15 timeouts 0, SG min/max 0/0
                  Driver 2: position 0, standstill, reads 6291, writes 15 timeouts 0, SG min/max 0/0
                  Driver 3: position 0, standstill, reads 6292, writes 15 timeouts 0, SG min/max 0/0
                  Driver 4: position 0, standstill, reads 6292, writes 15 timeouts 0, SG min/max 0/0
                  Driver 5: position 0, standstill, reads 6292, writes 15 timeouts 0, SG min/max 0/0
                  Date/time: 2021-11-19 13:44:44
                  Slowest loop: 9.18ms; fastest: 0.05ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                  DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  === AuxDDARing ===
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty.
                  === CAN ===
                  Messages queued 117, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 66/0/0
                  Tx timeouts 0,0,65,0,0,50 last cancelled message type 30 dest 127
                  === Network ===
                  Slowest loop: 16.31ms; fastest: 0.02ms
                  HTTP sessions: 1 of 8
                  - Ethernet -
                  State: active
                  Error counts: 0 0 0 0 0
                  • rjenkinsgbundefined
                    rjenkinsgb
                    Can you add a photo of the BLTouch itself with the cable attached to it?
                    There are at least three different sets of wire colours supplied with genuine BLTouch probes / kits.
                    I have one on mine connected to a 6HC and it works fine, it's just working out which wiring version you need.
                    The probe end connections are in a fixed sequence, it's just the supplied cables that vary from unit to unit.
                    Robert J.
                    Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                    • imonseiundefined
                      imonsei
                      I'm noticing that it doesn't say anything about a z-probe or an endstop in any of the info commands.
                      Should I be worrying about this, or is that normal?
                        Phaedrux Moderator @imonsei
                        @imonsei said in BLtouch probe pin does not deploy:
                        For Duet 3 MB6HC, use IO_4, IO_5 or IO_7.
                        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3
                        io2 is not a PWM capable port.
                        imonseiundefined 1 Reply Last reply Reply Quote 1
                        • imonseiundefined
                          imonsei @Phaedrux
                          @phaedrux IT'S ALIIIIIIIIIIIIVE!!!!! Thank you so much.
                          I'll write a note to the ratrig people.
                          Their documentation and config files specify that we should use the io2 port.
                          I am so excited now. Weeeeeeee ^____^
                            droftarts administrators @imonsei
                            @imonsei itโ€™s io1, io2 or io3 when using a Duet 3 Mini 5+, which might be more usual in a RatRig.
                            • imonseiundefined
                              imonsei @droftarts
                              @droftarts they have a section in their assembly instructions specifically for the 6HC that said to use io2.
                              I figure they just copied over the mini instructions without actually testing it beforehand.
