    Rolling Magnet Filament Sensor Switch NO? NC?
    Filament Monitor
    • guitartoysundefined
      guitartoys
      I've got a Rolling Magnet Filament Sensor, and am in the throes of designing a bracket, which will include the physical switch.
      In looking at the documentation, I can see the switch mentioned, and it connection, but no mention if is is supposed to be Normally Open (closed when filament is present), or Normally Closed (open when filament is present). Or maybe it's programmable.
      Could I please have some guidance here.
      Michael
      • alankilianundefined
        alankilian @guitartoys
        @guitartoys My switch is closed when filament is present.
        Someone should update the documentation to reflect this.
        guitartoysundefined 1 Reply Last reply Reply Quote 0
          guitartoys @alankilian
          @alankilian Thank you for this. It of course makes sense, just wanted to confirm.
          • guitartoysundefined guitartoys has marked this topic as solved
