Solved Mini5 no terminal via USB
Hi guys,
Once again my Mini 5 will not work with me. Printer was up and running a few days ago. got a clogged hotend so a bit of maintanence has to be done. Now I can not get any WiFi working as I have no connection via YAT USB terminal. Been searching for answers on how to but can not find.
So help would be much appreciated.
Does the mini show up on USB as a device at all?
Can you try going through the usb firmware update for the mini?
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_EthernetDo any lights turn on? You can work through this guide.
https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond -
@phaedrux said in Mini5 no terminal via USB:
https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respondHi there, long time no see
Nothing in YAT
I'd pull it from the case and disconnect everything and go through the what to do if it won't respond guide.
Did the reset button and yes I get files showing up in windows
@tecno said in Mini5 no terminal via USB:
A reset did the trick, so my Mini 5 is working again.
@tecno
Still wondering how a simple nozzle change can cause such a behaviour? Static discharge or what else will you avoid next time? -
Well, it is getting colder and low humidity so static discharge might be a candidate to this.
