    Laser stopped working after RRF3 upgrade
    1.0k
    • FelixHundefined
      FelixH
      Hi there,
      I commented the issue on another thread but it was not the main topic and I think, this issue needs a thread on its own.
      I have a CNC which until two days ago, it was running RRF2 (with the Ooznest overlay). On the CNC I attached a laser, which needs 12v. So I added a 12v PSU which I can turn on/off with a relay and the FAN2 output. I already asked help for the laser installation and, as usually people of this forums delivered. To be clear, I am using the recommended Laser-breakout boards explained here.
      The laser stopped working after I upgraded to RRF3. I re-read the instructions many times, and I just can warp my head around it.
      I have a macro, which switched to Laser mode, which looks like this:
      M106 P2 S255  ; turn on 12v PSU
      M550 P"WorkBee LASER" ; change name for awareness
      M452 C"exp.heater3" F200    ; Enable Laser mode, on output 3 (heater 3), with max intensity being 255, and a PWM frequency of 200
      Here is what happens and what I have done:
      • when I execute this macro, the laser turns on full blast.
      • sending M5 doesn't turn it off
      • I haven' find any command that dims the power.
      • I tried inverting the pin by adding the exclamation mark: M452 C"!exp.heater3" F200. In this instance, the laser doesn't turn on, and I cannot turn it on via code.
      • I tried using other pins such as "exp.heater4" and "exp.heater6". It doesn't change anything.
      • I tried using "exp8" instead of "exp.heater3". It doesn't change anything either.
      At this point I only can think of downgrading to RRF2 (the Ooznest version, that is) and see if the laser works again on that.
      Either that, or I am missing a crucial bit of information somewhere.
      I though about a hardware problem, but I don't know how likely is for the three pins I tried to fail at once.
      I would appreciate any further troubleshooting idea.
      Thanks in advance.
      • FelixHundefined
        FelixH
        Well, I furthered my research this afternoon...
        I took a clone Duet2 I had for testing purposes in which I already had installed the "Ooznest firmware" (RRF2 with their web overlay). I set up the laser and I tested it. It worked without problems. I was able to turn it on and off and set the intensity, for focusing for example.
        The I upgraded to the latest "Ooznest firmware" (RRF 3.2.2 with their web overlay). I tried the laser and it didn't work either. However there was a difference, which is the laser didn't turn on at all. I couldn't turn it on, whatever I did. So exactly the same, but different.
        As I said, the Duet in which I run the CNC is an original one and the one I did the test is a cloned one, just to be crystal clear about things.
        Given the tests I've done, I would say it is either a firmware bug or something I haven't set up correctly on the firmware, although I followed the instructions at the best of my abilities.
        Again, any brainstorming, would be appreciated.
        • FelixHundefined
          FelixH
          A bit more of research...
          As it turns out, the Laser behaves exactly the same, no matter the board. It's always on and no way to turn it off. There was a weak connection on my test setup.
          Additionally, I have installed the latest Firmware (RRF 3.3) from the Duet GitHub directly. The problem remains the same. I was thinking maybe the "Ooznest" release was bugged, but doesn't seem so.
          • o_lampeundefined
            o_lampe @FelixH
            @felixh
            I think it's time to post your new config.g
            There were many things to change in the tool definitions between RRF2 and RRF3.x
            Very important! If you use M452 to put your machine into Laser mode and are running Firmware 2.02 or above,
            you must replace all S parameters in G0/G1 commands in homing files etc. by H parameters.
            This is because S is now used to control laser power.
            Did you check your homing macros?
            FelixHundefined 1 Reply Last reply Reply Quote 0
            • FelixHundefined
              FelixH @o_lampe
              @o_lampe thanks for your feedback!
              I didn't share my config file, because I am pretty confident it has nothing to do with the problem at hand, but you are right, sure is sure, so here it is:
              ; Configuration file for Duet
              ; WorkBee Firmware Version 1.1
              global systemSettingsVersion={1.2}
              ; Network configuration executed by config.g
              ; Configure Connection - ENABLE ONLY ONE OF THE BELOW THREE
              M552 S1 ; Enable Wifi Network
              ;M552 S2 ; Enable Access Point Mode
              ;M552 S1 P192.168.251.2 ; Enable Ethernet - Change IP Address to suit
              ; Network settings
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              ; Network machine name
              M550 P"WorkBee Test" ; Set machine name
              ; Drive configuration executed by config.g
              M569 P0 S0 ; Drive 0 goes forwards
              M569 P2 S0 ; Drive 2 goes forwards
              ; Axes configuration executed by config.g
              M584 X0 Y1 Z2 U3 ; Apply drive mapping to axes
              M584 P3
              M906 X2400 Y2400 Z2400 U2400 I100 ; Set motor currents (mA)
              M92 X400 Y400 Z400 U400 ; Set steps per mm
              M350 X16 Y16 Z16 U16 I1 ; Configure microstepping
              M203 X2500 Y2500 Z2500 U2500 ; Set maximum speeds (mm/min)
              M201 X150 Y150 Z150 U150 ; Set accelerations (mm/s^2)
              M566 X500 Y500 Z500 U500 ; Set maximum instantaneous speed changes (mm/min)
              M669 K0 X1:0:0:0 Y0:1:0:1 Z0:0:1:0
              ; Axes Limits configuration executed by config.g
              M208 X270 Y270 Z88 S0 ; Set axis maxima
              ; Axes Calibration configuration executed by config.g
              M92 X400 Y400 Z400 ; Set steps per mm
              ; Endstop configuration executed by config.g
              M574 X2 P"xstop" S1 ; Set active low X endstop
              M574 Y2 P"ystop" S1 ; Set active low Y endstop
              M574 Z2 P"zstop" S1 ; Set active low Z endstop
              ; Other Settings
              M453 ; Put the machine into CNC Modes
              G90 ; Set absolute coordinates
              M140 H-1 ; Disable heated bed
              M564 S1 H1 ; Disable jog commands when not homed
              M911 S21.0 R23 P"G91 G1 Z3 F1000" ; Configure power loss resume
              ; User Configuration files
              M98 P"config-user-settings.g"
              M501 ; Load Stored Parameters
              In order to switch to Laser mode, I have the macro I posted earlier on the thread.
              I have not been able to test it on movements because, as I said, when I execute the macro, the laser turns on full blast.
              It seems like the pin is doing absolutely nothing.
              Once I get it working, I will take care that my Laser engraving software generates the adequate G-Code, but first things first... I have to be able to control the laser
                Phaedrux Moderator @FelixH
                @felixh said in Laser stopped working after RRF3 upgrade:
                What do you have in this macro?
                If you send M452 by itself after running your macro, what does it respond with?
                If you send M452 S0 does it disable the laser?
                Have you taken note of this change?
                Very important! If you use M452 to put your machine into Laser mode and are running Firmware 2.02 or above, you must replace all S parameters in G0/G1 commands in homing files etc. by H parameters. This is because S is now used to control laser power.
                • FelixHundefined
                  FelixH @Phaedrux
                  @phaedrux
                  on that macro I have nothing
                  if I send the M452 the machine does change to laser mode
                  if I send M542 S0 by itself, I don't know what happens because I haven't tried it yet
                  I did take note of that, but as I said I haven't had the chance to do movements with it
                  • FelixHundefined
                    FelixH
                    well I've done some "progress", if I can tell it that...
                    The good news is that now everything is working as expected. Router, RPM, Laser, etc...
                    The bad news is that, in order to do that, I had to downgrade the firmware to the latest RRF2 available with the Ooznest web overlay. So now I have everything as it used to be.
                    That confirms that there is no problem with the board, as far as I understand it.
                    Now I have two boards, one with RRF2 and one with RRF3. I have order some components to put together another Laser breakout board and do some experiments. I will borrow an oscilloscope from work and see if I can find something out here, although my skills with the oscilloscope are worse than minimal...
                    It would be great if somebody with time on their hands could try to replicate this setup, just to compare.
                      Yes we are looking into it. As far as I can tell your config is correct for RRF3.
                      FelixHundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                      • FelixHundefined
                        FelixH @Phaedrux
                        @phaedrux well, it‘s comforting to know that. At least it seems that the whole thing was not because some oversight on my part…
                        • o_lampeundefined
                          o_lampe @Phaedrux
                          @phaedrux said in Laser stopped working after RRF3 upgrade:
                          I wonder where and when " P2" was defined?
                          Is it a good idea to power up the laser before declaring the control pin for Laser mode?
                          What's in "config-user-setting.g"? (you call it at the end of config.g)
                          • FelixHundefined
                            FelixH @o_lampe
                            @o_lampe
                            The M106 turns on the PSU for the laser, as it is a separate 12v PSU, which does not need to be powered on when I am on CNC mode, for example. So I turn it ON and OFF with a solid state relay using a FAN port I declared somewhere.
                            The config-user-setting.g does not contain anything.
                            o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            • o_lampeundefined
                              o_lampe @FelixH
                              @felixh
                              That's understood, but why do you switch it ON before you have the Laser-pin under control? There might be an internal pullup or something on the Laser breakout board? (I don't know)
                                dc42 administrators @FelixH
                                @felixh you should use this line for RRF3:
                                The laser will turn on when you execute a G1 move with an appropriate S parameter to set the laser power.
                                FelixHundefined 2 Replies Last reply Reply Quote 0
                                • FelixHundefined
                                  FelixH @dc42
                                  @dc42 and so I did, but doesn‘t work. The laser goes full blast as soon as I power it on.
                                  I will give it another go this afternoon, however. Just to make extra sure.
                                  • FelixHundefined
                                    FelixH @dc42
                                    @dc42 said in Laser stopped working after RRF3 upgrade:
                                    I just tested it again. It doesn't make any difference.
                                    I just had two boards side, by side. One with RRF 3.3 and the other with RRF2.x (don't remember which one it is). On the RRF3, the laser turns ON as soon as I power up, no matter if C"exp.heater3" or C"!exp.heater3".
                                    I even skipped the macro all together and I added the
                                    M452 C"exp.heater3" F200 (with and without the ! on the config.g file...
                                    I am willing to to a video if needed.
                                      Being able to see what you see couldn't hurt. Photos of the wiring perhaps help.
                                      • FelixHundefined
                                        FelixH @Phaedrux
                                        @phaedrux I will do just that, but it will have to wait until I get the parts to prepare another breakout board for the laser, otherwise it is a mess and it would complicate things even more
                                        • FelixHundefined
                                          FelixH @Phaedrux
                                          @phaedrux
                                          So this is my setup. For testing purposes I am using a 12v PSU which powers both the laser and the Duet.
                                          The small PCB in the middle is the Laser breakout board recommended for controlling a Laser with the Duet.
                                          The thin wire between both boards connect the PWM input on the breakout board and the pin "exp.heater3" on the Duet.
                                          If I am running FFR2.x the setup works as expected:
                                          • I can switch between Laser and CNC mode without problems
                                          • I can turn ON the laser with M3 Sx commands (I am aware this doesn't work on RRF3)
                                          • I can turn OFF the laser with the M5 command
                                          If I run RRF3.x the very same setup:
                                          • I can switch between Laser and CNC modes
                                          • The Laser powers up immediately when I turn on the PSU
                                          • Sending M5 does NOT switch OFF the Laser
                                          • changing C"exp.heater3" for C"!exp.heater3" or C"exp.8" or C"!exp.8" doesn't change anything of the above
                                          • FelixHundefined
                                            FelixH
                                            well, good news everyone.
                                            After many tests done on a spare Duet2 (clone) board I finally got it to work. However, I cannot explain why. The only thing I did was to re-flash the firmware again, wire everything again (including putting terminals on some cables) and test.
                                            hopefully my experience will be of some use to someone with the same experience...
                                            EDIT: of course, many thanks at everyone who brainstormed with me! It is really appreciated!
